    Trouble with SendMessage "conflict".
    13 Posts 0 Posters 1.3k Views
      On 06/05/2011 at 06:29, xxxxxxxx wrote:
      I don't think SendMessage will help in your case.
      What you probably can do is to send a custom message through SpecialEventAdd() from your thread. Then this message can be received in your dialog's overridden CoreMessage method.
      There is a small example in the docs for SpecialEventAdd().
        On 06/05/2011 at 07:51, xxxxxxxx wrote:
        Hi Matthias, thanks for your constants replies. I will try the SpecialEvent...I've already seen this method but I don't remember if I've already tested this solution. Tonight I try...this "problem" made me crazy...thanks again, I'll know if it works...
        bye
          On 06/05/2011 at 11:26, xxxxxxxx wrote:
          Definitively thanks, using SpecialEvent we can manipulate now the gedialog using threading context. Bye.
            On 06/05/2011 at 12:49, xxxxxxxx wrote:
            In any case, the SendMessage problem described stay...
              On 06/05/2011 at 13:30, xxxxxxxx wrote:
              And it will stay as long as you're calling the Windows-specific method (which you can't use in the context of Cinema's event system) instead of the GeDialog method...
              Best regards,
              Wilfried
                On 06/05/2011 at 13:41, xxxxxxxx wrote:
                Did I understand you right ? You want to to something in the dialog from another thread ?
                I don't know about C++, but maybe this helps you:
                When you want to send the message, don't send the message itself, instead create a variable the defines wether the message should be sent or not. Just some Pseudocode to clarify what I mean:
                //Pseudocode, don't copy
                class MyDialog extends GeDialog {
                    boolean sendEvent = FALSE;
                    void Set_SendMessageOnNextUpdate() {
                        sendEvent = TRUE;
                    void Do_SendMessage() {
                        SendMessage();
                        sendEvent = FALSE;
                    boolean CoreMessage(id,msg) {
                        if (sendEvent) {
                            Do_SendMessage();
                class MyThread extends Thread {
                    void doMyStuff(GeDialog *dlg) {
                        dlg.Set_SendMessageOnNextUpdate();
                I'm not sure if this will really work as you wish, but maybe it helps you 🙂
                Niklas
                  Best regards,
                  Wilfried
                  I don't call any windows specific method now...
                    Best regards,
                    Wilfried
                    [/QUOTE]
                    You do. The compiler's error message proofs it.
                    Best regards,
                    Wilfried
                      On 07/05/2011 at 13:07, xxxxxxxx wrote:
                      Bho....If I do, I don't know where I do...I've removed all "trash" includes, I've only:
                      #include "c4d.h"
                      #include "c4d_gui.h"
                      #include "c4d_symbols.h"
                      #include "c4d_general.h"
                      #include "c4d_baseplugin.h"
                      #include "C4D_Thread.h"
                      #include <string>
                      #include <sys/stat.h>
                      I don't use any windows dependent method, the Thread is C4D Sdk based, but the message is:
                      error C2039: 'SendMessageA' : is not a member of 'C4DScenePlugin'
                      Now the prototype viewed with vs intellicode is correct but the error on define still stay...
                      Bho....
                      Best regards,
                      Wilfried
                      [/QUOTE]
                      Best regards,
                      Wilfried
                      [/QUOTE]
                        On 07/05/2011 at 13:26, xxxxxxxx wrote:
                        With a redefine of method name in my plugin now compile fine...very strange for me...
