    Collision within a Radius
    17 Posts 0 Posters 1.4k Views
      On 07/04/2011 at 08:14, xxxxxxxx wrote:
      You cold try using PointLineDistance instead. If the distance from the handle to the ray is less than the desired radius, you have a hit.
        On 07/04/2011 at 09:35, xxxxxxxx wrote:
        So if I wanted to use PointLineDistance()...
        Would it be like this?
        PointLineDistance(wtail, whead, res.hitpos);
        Also, is the Vector that is returned by this function the distance fromt the point to the ray?
          On 07/04/2011 at 09:44, xxxxxxxx wrote:
          Or would I instead do:
          PointLineDistance(wtail, oray, res.hitpos);
            On 07/04/2011 at 13:32, xxxxxxxx wrote:
            okay using the last code i posted the res.hitpos always returns 0,0,0
            Anyone have any idea why?
              On 07/04/2011 at 14:52, xxxxxxxx wrote:
              (0,0,0) is correct.
              Because you calculate the distance between your 'intersection line' and a hit point of the intersection.
              A Point at a line = distance = 0. 😉
              You should do it maybe with points of a polygon near the hit point.
                On 07/04/2011 at 16:16, xxxxxxxx wrote:
                Like this?
                Vector distance = PointLineDistance(wtail, oray, pObj->GetMg().off);
                  On 07/04/2011 at 16:25, xxxxxxxx wrote:
                  How does the vector returned by PointLineDistance() represent the distance,,,  what does each Real in the Vector represent?
                  for example   when I use the above line I get a bunch of different numbers and those numbers do not seem to be the same when the camera is in different places..
                  Hopefully that makes sense..  lol
                  ~Shawn
                    On 07/04/2011 at 16:44, xxxxxxxx wrote:
                    The ray should be in the same space as the object and the shortest distance is the length of the returned vector.
                      On 07/04/2011 at 17:27, xxxxxxxx wrote:
                      okay I've got it work using
                      Vector distance = PointLineDistance(wtail, whead, pObj->GetMg().off);
                        Real disX = distance.x;
                        Real disY = distance.y;
                        Real disZ = distance.z;
                        //if (cRay->GetNearestIntersection(&res))
                        if((disX > -20 && disX < 20) && (disY > -20 && disY < 20) && (disZ > -20 && disZ < 20))
                            //GePrint("A COLLISION HAS OCCURRED");
                      now in order to make this whole thing work the right way I need to be able to capture the initial mouse location when the mouse is clicked and dragged and then not get the mouse location while it is dragging..   So basically I want the mouse location where the user clicks but then I don't want the location while the mouse is dragging.
                      Is this possible...  I currently use BFM_INPUT_X & BFM_INPUT_Y  to get the mouse location but this value changes as the mouse is dragging.
                      Shawn
                        On 07/04/2011 at 18:24, xxxxxxxx wrote:
                        Just use GetLength(), e.g.
                        const Real threshold = 10.0;
                        Real dist = result.GetLength();
                        if(dist <= threshold) return TRUE;
                          On 07/04/2011 at 18:35, xxxxxxxx wrote:
                          Thank you David that is much cleaner..  🙂
                            const Real threshold = 20.0;
                            Real dist = distance.GetLength();
                                //GePrint("A COLLISION HAS OCCURED");
                          Anyone know about getting the mouse position of the initial click when doing a mouse drag?
                          Shawn
                            On 07/04/2011 at 23:12, xxxxxxxx wrote:
                            a question where you perform this?
                            if you hare in mouse input you can use ViewPortSelect::PickObject()
                            this will fill a c4dobjectlist with all obj in the radius in z order.
                            it will have not very good performance but can solve the situation.
                            try it
                            all the best
                            Franz
                              On 08/04/2011 at 02:50, xxxxxxxx wrote:
                              Hi Franz.   Thanks,   I am able to select within a set radius now.  See the last code I posted.  Now I am trying to figure out how to capture the screen coordinates of the first initial mouse click when the user drags the mouse.  I do not want to keep storing the mouse position after that first click so I need to figure out how to store only that first click.  🙂
                              Shawn
                                On 08/04/2011 at 07:40, xxxxxxxx wrote:
                                This is from the liquid draw example in the SDK.
                                Seems to work.
                                Real mx = msg.GetReal(BFM_INPUT_X);
                                Real my = msg.GetReal(BFM_INPUT_Y);
                                GePrint(RealToString(mx));
                                GePrint(RealToString(my));
                                  On 08/04/2011 at 08:27, xxxxxxxx wrote:
                                  Howdy,
                                  ...Now I am trying to figure out how to capture the screen coordinates of the first initial mouse click when the user drags the mouse.  I do not want to keep storing the mouse position after that first click so I need to figure out how to store only that first click....
                                  If you store the mouse x and y in local variables startx and starty, and do that before the while loop, those variables won't change during the dragging.  😉
                                  Adios,
                                  Cactus Dan
