    Export Objects
    4 Posts 0 Posters 445 Views
      On 31/03/2011 at 05:38, xxxxxxxx wrote:
      Cinema 4D Version:   R10-12
      Hi there,
      i want to duplicate some Objects if they are exported. Is where a way to do this?
      Maybe its possible to get the Message: Scene should be exported?
      Could i get such an information?
      If yes: Whats the proposed plugin to use?
      Regards
      Ralf
        On 31/03/2011 at 06:04, xxxxxxxx wrote:
        Sorry, I don't understand your question. What exactly do you want to achieve?
          On 31/03/2011 at 06:14, xxxxxxxx wrote:
          well my suggested workflow should be:
          - the user starts the export
          - the exporter trys to export an object
          - then my plugin should be called
          - my plugin delete this object and creates some other objects instead of the deleted
          its just to export the cams from an videopost effect (which moves the cam around) for external renderers (mybe maxwell)
            On 31/03/2011 at 10:37, xxxxxxxx wrote:
            I would think that deleting a user's objects would be a bit upsetting to the user. 🙂
            Maybe the Message MSG_DOCUMENTINFO_TYPE_SAVE_BEFORE can be used for the export.   I would highly recommend making a clone of the document and manipulating that for the cams instead of working on the original (!).
