    Selected Keys? Move Keys?
    31 Posts 0 Posters 28.0k Views
      On 26/02/2011 at 02:07, xxxxxxxx wrote:
      Hi all
      Finally escaped from the last job.
      A couple of things
      Confusion
      Just to confirm - the original concept was for staggered keys on multiple objects
      Don't get me wrong - not complaining - just need to be clear what I'm seeing
      The code is there in the while loop looks like it iterates through all the tracks of a single selected object.
      If I select more than one object - nothing happens? (no provision in script so far)
      I'd assume (if you want to modify keys differently for different objects) it would be better to write a small function
      and modify the Key value before running Key.SetTime(...etc
      dependent on the number of selected tracks
      Sadly I cant see a way to return the count of selected tracks (yes Scott I now see the route) - so I guess
      the whole things needs to run in an outer loop - iterating through the selected objects?
      Another issue  - if you modify the offset inside the While track loop
      ie after
      key.SetTime..
      with something as simple as offset = offset + 10
      Assuming you have a POS ROT SCALE tracks as well
      Selecting all tracks is fine
      Selecting just one track ie POS - inserts two extra sets of keyframes
      as the while loop count is based on the total number of tracks
      Cant see a simple solution
      can't find reference to
      C4d.NBIT_TL1_SELECT in the SDK - I take it these refer to the 4 timelines
      Where did you get that info pls?
      def MoveSelectedKeys(op,offset,timeln = 1) :    # offset in frames
          if (not op) or (not offset) : return False
          if timeln == 1: timeln = c4d.NBIT_TL1_SELECT
          elif timeln == 2: timeln = c4d.NBIT_TL2_SELECT
          elif timeln == 3: timeln = c4d.NBIT_TL3_SELECT
          elif timeln == 4: timeln = c4d.NBIT_TL4_SELECT
              import math
              timeln = math.fmod(timeln,4)
              MoveSelectedKeys(op,offset,timeln)
          doc = op.GetDocument()
          doc.StartUndo()
          track = op.GetFirstCTrack()
          if not track: return False
          fps = float(doc.GetFps())
          while track:
              curve = track.GetCurve()
              cnt = curve.GetKeyCount()
              for i in xrange(cnt) :
                  key = curve.GetKey(i)
                  if key.GetNBit(int(timeln)) == True:
                      tme = key.GetTime()
                      doc.AddUndo(c4d.UNDOTYPE_CHANGE,op)
                      key.SetTime(curve,c4d.BaseTime(offset/fps+tme.Get()))
              track = track.GetNext()
          doc.EndUndo()
          c4d.EventAdd(c4d.MSG_UPDATE)
          offset = 50 #change this value as needed
          MoveSelectedKeys(op,offset)
        On 26/02/2011 at 03:06, xxxxxxxx wrote:
        1:
        You can simply use the function in an iteration through the selected objects.
        What means staggered ? Don't know the word ^^
        2:
        Why modifieng the
        key value ? I thought it's about moving keys ?
        And what do you want to achieve with offset = offset + 10
        Don't select a track, select the keys.
        3:
        It's in the GetNBits() function. Search for it without the c4d. in front.
        I'll can answer your questions better later when im at home in about 2 hours.
        Till then,
        cheers
          All explained here
          http://forums.cgsociety.org/showthread.php?f=182&t=959094
          with sample file (first post)
          file shows example of before and after stagger
          hth
            On 26/02/2011 at 05:23, xxxxxxxx wrote:
            Ah, you mean the 2nd Cube should start moving when the 1st one finished ?
            That shouldn't be a problem.
            I'll be back in a minute with a function doing this.
            cheers
            PS: Do still only the selected keys need to be moved ?
            //So, this is a bit more complex than i thought. 😂
            But it works fine 🙂
            from c4d import documents
            overlap = 20    ## Change this to the Frame you want to let the keys beeing overlapped
                  import math
              while track:
                          tme = key.GetTime()
            def GetLastSelectedKey(track, timeln = 1) :
                  import math
                  key = curve.GetKey(cnt-i-1)
                      return key
            def GetHNext(op) :
              if not op: return
              if op.GetDown() : return op.GetDown()
              while not op.GetNext() and op.GetUp() :
                  op = op.GetUp()
              return op.GetNext()
            def GetActiveObjects(doc) :
              lst = list()
              op = doc.GetFirstObject()
              while op:
                  if op.GetBit(c4d.BIT_ACTIVE) == True: lst.append(op)
                  op = GetHNext(op)
              return lst
              doc.StartUndo()
              lst = GetActiveObjects(doc)
              op = lst[0]
              if not op: return False
              key = GetLastSelectedKey(op.GetFirstCTrack())
              if not key: offset = 0
              else: offset = key.GetTime().GetFrame(doc.GetFps())-overlap
              for i in xrange(len(lst)) :
                  print op.GetName()
                  op = lst[i+1]
              doc.EndUndo()
            Here a tiny Screencast to show you how to use it:
            " target="_blank" rel="noopener noreferrer nofollow ugc">
              On 26/02/2011 at 12:08, xxxxxxxx wrote:
              Hey Nux95
              This is just great
              And there's so much useful stuff here for reference
              It's really appreciated  - many thanks
              line 103
              op=list[i+1]
              is throwing an error
              index out of range
              I guess this is just incrementing one object too many? at the end of the selected objects
              Not wanting to take anything away from what you've done here - far beyond the call of duty 🙂
              I think it would be nice to have the 'processing' part of the script possibly
              in a function
              ie release a collection of key manipulating scripts - by just changing the function
              stagger - by offset - as we have now
              stagger  - by total time - total time over which to stagger all frames
              stagger exponentially large to small
              stagger exponentially small to large
              etc etc
              cheers again
                On 26/02/2011 at 13:22, xxxxxxxx wrote:
                line 103
                op=list[i+1]
                index out of range
                Do you recieve that message every time ? It didn't appear when I was using the Script.
                Shouldnt. 'op' is already the object with index 0, and 'i' starts with '0', so the next object for 'op' in the first iteration should be 1 => 'i+1'
                But .. Hm, very bizarre. I didn't recieve that error, but as I think about it, that error MUST occure at the end of the loop.
                Try it like this and tell me if the problen still exists:
                op = lst[i+1]
                if not op: break # Hopefully there is a 'break' expression for 'for'-loops. If not try something that stops the loop
                etc etc
                Why not writing a Plugin ? 😉
                cheers, nux
                  On 27/02/2011 at 03:10, xxxxxxxx wrote:
                  Using
                  if i+1 < len(lst) :
                  	op = lst[i+1]
                  got rid of the index error
                  As far as writing a plugin. A bit beyond me at present, probably best to learn from your foundation work here Nux.
                    On 27/02/2011 at 08:05, xxxxxxxx wrote:
                    Trying to move this on in a more modular way
                    ie have a  function for each transformation on selected keys
                    just wondered if I was heading in the right direction???
                    (ignore print checkpoints just for testing)
                    Next objective to 'nudge' everything back
                    as 'everything' gets moved over by staggering process
                    ie first track shouldnt move - everything else - stagger
                    Updated version in later post
                      On 01/03/2011 at 00:42, xxxxxxxx wrote:
                      Making an effort to understand what I'm seeing
                      Line 14 function call within itself - seems incorrect?
                        On 01/03/2011 at 07:21, xxxxxxxx wrote:
                        I am sorry, I may can go to my pc this weekend, but not earlier.
                        Does the Console tell you this ? O.o
                        If A function calls itself, everything starts again. But you may have changed some values before. (Here the timeln variable)
                          On 02/03/2011 at 01:03, xxxxxxxx wrote:
                          Can anyone tell me why this message
                          doesn't pop up if NO object is selected using the function from the code above?
                              op = lst[0]
                              if not op:
                                  gui.MessageDialog("No objects selected")
                                  return False #leave the script if not an object
                            On 02/03/2011 at 02:37, xxxxxxxx wrote:
                            Dunnoo .. Gonna test this this weekend. Maybe it's because op = lst[0] ist not in the right column ?
                              op = lst[0] ## here
                                if not op:
                              On 02/03/2011 at 03:03, xxxxxxxx wrote:
                              Hi Nux
                              nope, not that - must be forum paste incorrect
                              indent is as your example
                              appreciate you can't test at moment
                              I think its to do with this function setting op to the first object in doc
                              if nothing selected
                              that way op is never NULL
                                  lst = list()
                                  while op:
                                      op = GetHNext(op)
                                  return lst
                                On 02/03/2011 at 03:22, xxxxxxxx wrote:
                                the list only gets appended if op is selected.
                                  On 03/03/2011 at 06:11, xxxxxxxx wrote:
                                  And this is where I'm at so far
                                  Ignore some Print items - just for console checks
                                  Still trying to make it modular
                                  ie have a function for each type of key transform - (just stagger in this one)
                                  appreciate any advice on good/bad code form
                                  added gui to take offset
                                  count selected objects - need more than 2
                                  and now first object doesnt get offset (its popped off array)
                                          import math
                                      while track:
                                                  tme = key.GetTime()
                                          import math
                                              return key
                                  ####################################MINE
                                  def GetFirstSelectedKey(track, timeln = 1) :
                                          import math
                                      key = curve.GetKey(0)
                                          return key
                                  def GetHNext(op) :
                                      if not op: return
                                          op = op.GetUp()
                                      return op.GetNext()
                                      lst = list()
                                      while op:
                                          op = GetHNext(op)
                                      return lst
                                  #####################################MINE
                                  def Stagger(doc,op,lst,keylast,overlap) :
                                      print "Length of list before pop", len(lst)
                                      lst.pop(0)  #remove the first object as its not moved
                                      op = lst[0] #get fist active object again, less original first object
                                      print "Length of list after pop", len(lst)
                                      offset = keylast.GetTime().GetFrame(doc.GetFps())-overlap
                                      for i in xrange(len(lst)) : #increment through allthe objects selected
                                          MoveSelectedKeys(op,offset) #moves all the selected keys on a track
                                          keylast = GetLastSelectedKey(op.GetFirstCTrack())
                                          if not keylast: offset = 0
                                          # the original cal moved everything # else: offset = key.GetTime().GetFrame(doc.GetFps())-overlap
                                              print "OS1", offset
                                              print "OS2", offset
                                          # object namecheck # print op.GetName()
                                          if  i+1 < len(lst) : # +1 stops index going out of range ie more objects than listed
                                              op = lst[i+1]# ok to get next object in list
                                      from c4d import gui
                                      c4d.CallCommand(1024314); # clear the python console
                                      # get a value form the user
                                      guival = gui.InputDialog("Enter a value < your max keyspan","10")
                                      print "Dialog Value =",guival
                                      overlap = int(guival)
                                      doc.StartUndo()
                                      lst = GetActiveObjects(doc) #get selected objects
                                      print "List Length = ", len(lst)
                                      if len(lst)<=1:
                                          c4d.gui.MessageDialog("You need to select at least two objects")
                                          return False #leave if not enough objects selected
                                      keyfirst = GetFirstSelectedKey(op.GetFirstCTrack())
                                      keyfirstval = keyfirst.GetTime().GetFrame(doc.GetFps())
                                      keylastval = keylast.GetTime().GetFrame(doc.GetFps())
                                      keyspanval = keylastval - keyfirstval
                                      print "Selected Keyspan 1st track = ", keyspanval
                                      print "Keytime of start key = ", keyfirstval
                                      print "Keytime of end key = ", keylastval
                                      ##### else do the stagger
                                      else: Stagger(doc,op,lst,keylast,overlap)
                                      doc.EndUndo()
                                    On 06/03/2011 at 08:05, xxxxxxxx wrote:
                                    Any feedback on programing 'form' would be appreciated.
                                    Think it would be useful to have a couple more transformations
                                    Stagger2 - enter total stagger length - x frames (rather than current overlap in frames)
                                    Accelerate - gradually space out over x frames
                                    Decelerate - reverse above
                                    Stack - thats essentially stagger with no overlap?
                                      On 06/03/2011 at 10:29, xxxxxxxx wrote:
                                      Well, works fine. If you want potential increament for eg. you need to calculate something with the offset value. 😉
                                        On 06/03/2011 at 11:09, xxxxxxxx wrote:
                                        cheers Nux
