    Selected Keys? Move Keys?
    31 Posts 0 Posters 28.0k Views
      On 24/02/2011 at 08:34, xxxxxxxx wrote:
      Let me add, that in the SkriptManager op is automatically the selected Object. 🙂
      And you don't need to overload the timeln since you don't want timeline 2,3 or 4.
      So this works too:
            offset = 15 #change this value as needed
            MoveSelectedKeys(op,offset)
        On 25/02/2011 at 03:47, xxxxxxxx wrote:
        Hi All
        Sorry for lack of contribution - yesterdays work over ran
        try to get back to this as soon as job is out of the door
          On 26/02/2011 at 02:07, xxxxxxxx wrote:
          Hi all
          Finally escaped from the last job.
          A couple of things
          Confusion
          Just to confirm - the original concept was for staggered keys on multiple objects
          Don't get me wrong - not complaining - just need to be clear what I'm seeing
          The code is there in the while loop looks like it iterates through all the tracks of a single selected object.
          If I select more than one object - nothing happens? (no provision in script so far)
          I'd assume (if you want to modify keys differently for different objects) it would be better to write a small function
          and modify the Key value before running Key.SetTime(...etc
          dependent on the number of selected tracks
          Sadly I cant see a way to return the count of selected tracks (yes Scott I now see the route) - so I guess
          the whole things needs to run in an outer loop - iterating through the selected objects?
          Another issue  - if you modify the offset inside the While track loop
          ie after
          key.SetTime..
          with something as simple as offset = offset + 10
          Assuming you have a POS ROT SCALE tracks as well
          Selecting all tracks is fine
          Selecting just one track ie POS - inserts two extra sets of keyframes
          as the while loop count is based on the total number of tracks
          Cant see a simple solution
          can't find reference to
          C4d.NBIT_TL1_SELECT in the SDK - I take it these refer to the 4 timelines
          Where did you get that info pls?
          def MoveSelectedKeys(op,offset,timeln = 1) :    # offset in frames
              if (not op) or (not offset) : return False
              if timeln == 1: timeln = c4d.NBIT_TL1_SELECT
              elif timeln == 2: timeln = c4d.NBIT_TL2_SELECT
              elif timeln == 3: timeln = c4d.NBIT_TL3_SELECT
              elif timeln == 4: timeln = c4d.NBIT_TL4_SELECT
                  import math
                  timeln = math.fmod(timeln,4)
                  MoveSelectedKeys(op,offset,timeln)
              doc = op.GetDocument()
              doc.StartUndo()
              track = op.GetFirstCTrack()
              if not track: return False
              fps = float(doc.GetFps())
              while track:
                  curve = track.GetCurve()
                  cnt = curve.GetKeyCount()
                  for i in xrange(cnt) :
                      key = curve.GetKey(i)
                      if key.GetNBit(int(timeln)) == True:
                          tme = key.GetTime()
                          doc.AddUndo(c4d.UNDOTYPE_CHANGE,op)
                          key.SetTime(curve,c4d.BaseTime(offset/fps+tme.Get()))
                  track = track.GetNext()
              doc.EndUndo()
              c4d.EventAdd(c4d.MSG_UPDATE)
              offset = 50 #change this value as needed
            On 26/02/2011 at 03:06, xxxxxxxx wrote:
            1:
            You can simply use the function in an iteration through the selected objects.
            What means staggered ? Don't know the word ^^
            2:
            Why modifieng the
            key value ? I thought it's about moving keys ?
            And what do you want to achieve with offset = offset + 10
            Don't select a track, select the keys.
            3:
            It's in the GetNBits() function. Search for it without the c4d. in front.
            I'll can answer your questions better later when im at home in about 2 hours.
            Till then,
            cheers
              All explained here
              http://forums.cgsociety.org/showthread.php?f=182&t=959094
              with sample file (first post)
              file shows example of before and after stagger
              hth
                On 26/02/2011 at 05:23, xxxxxxxx wrote:
                Ah, you mean the 2nd Cube should start moving when the 1st one finished ?
                That shouldn't be a problem.
                I'll be back in a minute with a function doing this.
                cheers
                PS: Do still only the selected keys need to be moved ?
                //So, this is a bit more complex than i thought. 😂
                But it works fine 🙂
                from c4d import documents
                overlap = 20    ## Change this to the Frame you want to let the keys beeing overlapped
                      import math
                  while track:
                              tme = key.GetTime()
                def GetLastSelectedKey(track, timeln = 1) :
                      import math
                      key = curve.GetKey(cnt-i-1)
                          return key
                def GetHNext(op) :
                  if not op: return
                  if op.GetDown() : return op.GetDown()
                  while not op.GetNext() and op.GetUp() :
                      op = op.GetUp()
                  return op.GetNext()
                def GetActiveObjects(doc) :
                  lst = list()
                  op = doc.GetFirstObject()
                  while op:
                      if op.GetBit(c4d.BIT_ACTIVE) == True: lst.append(op)
                      op = GetHNext(op)
                  return lst
                  doc.StartUndo()
                  lst = GetActiveObjects(doc)
                  op = lst[0]
                  if not op: return False
                  key = GetLastSelectedKey(op.GetFirstCTrack())
                  if not key: offset = 0
                  else: offset = key.GetTime().GetFrame(doc.GetFps())-overlap
                  for i in xrange(len(lst)) :
                      print op.GetName()
                      op = lst[i+1]
                  doc.EndUndo()
                Here a tiny Screencast to show you how to use it:
                " target="_blank" rel="noopener noreferrer nofollow ugc">
                  On 26/02/2011 at 12:08, xxxxxxxx wrote:
                  Hey Nux95
                  This is just great
                  And there's so much useful stuff here for reference
                  It's really appreciated  - many thanks
                  line 103
                  op=list[i+1]
                  is throwing an error
                  index out of range
                  I guess this is just incrementing one object too many? at the end of the selected objects
                  Not wanting to take anything away from what you've done here - far beyond the call of duty 🙂
                  I think it would be nice to have the 'processing' part of the script possibly
                  in a function
                  ie release a collection of key manipulating scripts - by just changing the function
                  stagger - by offset - as we have now
                  stagger  - by total time - total time over which to stagger all frames
                  stagger exponentially large to small
                  stagger exponentially small to large
                  etc etc
                  cheers again
                    On 26/02/2011 at 13:22, xxxxxxxx wrote:
                    line 103
                    op=list[i+1]
                    index out of range
                    Do you recieve that message every time ? It didn't appear when I was using the Script.
                    Shouldnt. 'op' is already the object with index 0, and 'i' starts with '0', so the next object for 'op' in the first iteration should be 1 => 'i+1'
                    But .. Hm, very bizarre. I didn't recieve that error, but as I think about it, that error MUST occure at the end of the loop.
                    Try it like this and tell me if the problen still exists:
                    op = lst[i+1]
                    if not op: break # Hopefully there is a 'break' expression for 'for'-loops. If not try something that stops the loop
                    etc etc
                    Why not writing a Plugin ? 😉
                    cheers, nux
                      On 27/02/2011 at 03:10, xxxxxxxx wrote:
                      Using
                      if i+1 < len(lst) :
                      	op = lst[i+1]
                      got rid of the index error
                      As far as writing a plugin. A bit beyond me at present, probably best to learn from your foundation work here Nux.
                        On 27/02/2011 at 08:05, xxxxxxxx wrote:
                        Trying to move this on in a more modular way
                        ie have a  function for each transformation on selected keys
                        just wondered if I was heading in the right direction???
                        (ignore print checkpoints just for testing)
                        Next objective to 'nudge' everything back
                        as 'everything' gets moved over by staggering process
                        ie first track shouldnt move - everything else - stagger
                        Updated version in later post
                          On 01/03/2011 at 00:42, xxxxxxxx wrote:
                          Making an effort to understand what I'm seeing
                          Line 14 function call within itself - seems incorrect?
                            On 01/03/2011 at 07:21, xxxxxxxx wrote:
                            I am sorry, I may can go to my pc this weekend, but not earlier.
                            Does the Console tell you this ? O.o
                            If A function calls itself, everything starts again. But you may have changed some values before. (Here the timeln variable)
                              On 02/03/2011 at 01:03, xxxxxxxx wrote:
                              Can anyone tell me why this message
                              doesn't pop up if NO object is selected using the function from the code above?
                                  op = lst[0]
                                  if not op:
                                      gui.MessageDialog("No objects selected")
                                      return False #leave the script if not an object
                                On 02/03/2011 at 02:37, xxxxxxxx wrote:
                                Dunnoo .. Gonna test this this weekend. Maybe it's because op = lst[0] ist not in the right column ?
                                  op = lst[0] ## here
                                    if not op:
                                  On 02/03/2011 at 03:03, xxxxxxxx wrote:
                                  Hi Nux
                                  nope, not that - must be forum paste incorrect
                                  indent is as your example
                                  appreciate you can't test at moment
                                  I think its to do with this function setting op to the first object in doc
                                  if nothing selected
                                  that way op is never NULL
                                      lst = list()
                                      while op:
                                          op = GetHNext(op)
                                      return lst
                                    On 02/03/2011 at 03:22, xxxxxxxx wrote:
                                    the list only gets appended if op is selected.
                                      On 03/03/2011 at 06:11, xxxxxxxx wrote:
                                      And this is where I'm at so far
                                      Ignore some Print items - just for console checks
                                      Still trying to make it modular
                                      ie have a function for each type of key transform - (just stagger in this one)
                                      appreciate any advice on good/bad code form
                                      added gui to take offset
                                      count selected objects - need more than 2
                                      and now first object doesnt get offset (its popped off array)
                                              import math
                                          while track:
                                                      tme = key.GetTime()
                                              import math
                                                  return key
                                      ####################################MINE
                                      def GetFirstSelectedKey(track, timeln = 1) :
                                              import math
                                          key = curve.GetKey(0)
                                              return key
                                      def GetHNext(op) :
                                          if not op: return
                                              op = op.GetUp()
                                          return op.GetNext()
                                          lst = list()
                                          while op:
                                              op = GetHNext(op)
                                          return lst
                                      #####################################MINE
                                      def Stagger(doc,op,lst,keylast,overlap) :
                                          print "Length of list before pop", len(lst)
                                          lst.pop(0)  #remove the first object as its not moved
                                          op = lst[0] #get fist active object again, less original first object
                                          print "Length of list after pop", len(lst)
                                          offset = keylast.GetTime().GetFrame(doc.GetFps())-overlap
                                          for i in xrange(len(lst)) : #increment through allthe objects selected
                                              MoveSelectedKeys(op,offset) #moves all the selected keys on a track
                                              keylast = GetLastSelectedKey(op.GetFirstCTrack())
                                              if not keylast: offset = 0
                                              # the original cal moved everything # else: offset = key.GetTime().GetFrame(doc.GetFps())-overlap
                                                  print "OS1", offset
                                                  print "OS2", offset
                                              # object namecheck # print op.GetName()
                                              if  i+1 < len(lst) : # +1 stops index going out of range ie more objects than listed
                                                  op = lst[i+1]# ok to get next object in list
                                          from c4d import gui
                                          c4d.CallCommand(1024314); # clear the python console
                                          # get a value form the user
                                          guival = gui.InputDialog("Enter a value < your max keyspan","10")
                                          print "Dialog Value =",guival
                                          overlap = int(guival)
                                          doc.StartUndo()
                                          lst = GetActiveObjects(doc) #get selected objects
                                          print "List Length = ", len(lst)
                                          if len(lst)<=1:
                                              c4d.gui.MessageDialog("You need to select at least two objects")
                                              return False #leave if not enough objects selected
                                          keyfirst = GetFirstSelectedKey(op.GetFirstCTrack())
                                          keyfirstval = keyfirst.GetTime().GetFrame(doc.GetFps())
                                          keylastval = keylast.GetTime().GetFrame(doc.GetFps())
                                          keyspanval = keylastval - keyfirstval
                                          print "Selected Keyspan 1st track = ", keyspanval
                                          print "Keytime of start key = ", keyfirstval
                                          print "Keytime of end key = ", keylastval
                                          ##### else do the stagger
                                          else: Stagger(doc,op,lst,keylast,overlap)
                                          doc.EndUndo()
                                        On 06/03/2011 at 08:05, xxxxxxxx wrote:
                                        Any feedback on programing 'form' would be appreciated.
                                        Think it would be useful to have a couple more transformations
                                        Stagger2 - enter total stagger length - x frames (rather than current overlap in frames)
                                        Accelerate - gradually space out over x frames
                                        Decelerate - reverse above
                                        Stack - thats essentially stagger with no overlap?
                                          On 06/03/2011 at 10:29, xxxxxxxx wrote:
                                          Well, works fine. If you want potential increament for eg. you need to calculate something with the offset value. 😉
                                            On 06/03/2011 at 11:09, xxxxxxxx wrote:
                                            cheers Nux
