    User plugin serial number issue
    35 Posts 0 Posters 18.8k Views
      On 23/10/2010 at 12:25, xxxxxxxx wrote:
      Howdy,
      Well, I think so, but I'll have to wait to hear from the user to see if it worked. 😉
      Adios,
      Cactus Dan
        On 28/10/2010 at 06:24, xxxxxxxx wrote:
        Howdy,
        The user is saying it's still not working.
        Here's what I did. I created my own function calls like this:
        Bool myReadPluginInfo(LONG pluginid, void *buffer, LONG size)
        SerialInfo si;
        GeGetSerialInfo(SERIAL_MULTILICENSE, &si);
        if(si.nr.Content())
        	return ReadRegInfo(pluginid,buffer,size); // multi license
        else
        	return ReadPluginInfo(pluginid,buffer,size); // single license
        Bool myWritePluginInfo(LONG pluginid, void *buffer, LONG size)
        SerialInfo si;
        if(si.nr.Content())
        	return WriteRegInfo(pluginid,buffer,size); // multi license
        else
        	return WritePluginInfo(pluginid,buffer,size); // single license
        Seems like that should work, shouldn't it?
        Adios,
        Cactus Dan
          On 28/10/2010 at 06:36, xxxxxxxx wrote:
          yep, looks right to me. Did he provide you with the license server serial number?
            On 28/10/2010 at 06:45, xxxxxxxx wrote:
            Howdy,
            He provided the normal Cinema 4D serial number, BUT in my routine for checking the Cinema 4D serial number I use this:
            SerialInfo si;
            GeGetSerialInfo(SERIAL_CINEMA4D,&si);
            So, the previous code I posted is simply using
            to check if it's a mult license or single license and then calling the appropriate c4d function to fill the buffer.
            Adios,
            Cactus Dan
              On 28/10/2010 at 07:21, xxxxxxxx wrote:
              Well, that might be the problem. If the c4d license is in a license server environment then afaik you should use the license server serial number (as not the c4d serial number is used for running that c4d license in that case) which at the same time means you must license the amount of seats to them and you cannot license individual seats or a limited number of seats. So if they have 20 seats they must buy 20 licenses from you (of course you could trust them that they will only use your plugin with that one c4d seat but well...really?).
              But I think only Matthias can give you an official answer on this.
                On 28/10/2010 at 07:42, xxxxxxxx wrote:
                Howdy,
                I've sent Matthias a private message asking him to look at this thread.
                This whole multi license thing has been confusing to me. I never really cared to make a customer pay for using the plugin on each seat in their multi license, so I thought if I just left the old code as is, looking for the Rx.0 number, everything would be fine. Up until now, everything has been fine (no customers with multi licenses), but it looks like it has turned around and bitten me in the upholstery. :frowning2:
                Adios,
                Cactus Dan
                  On 28/10/2010 at 08:14, xxxxxxxx wrote:
                  Don't know if this helps but from earlier threads I use
                  SysGetUserInfo(6) for MLS and
                  SysGetUserInfo(0) for main app running local number.
                  I've asked the MLS users I have with R12, and it seems to be ok.
                  Lennart
                  var eleven; // the app serials
                  var licensetype;
                  if(SysGetUserInfo(6) && sizeof(SysGetUserInfo(6)) > 0 )
                  eleven = SysGetUserInfo(6);
                  licensetype = "LICENSE SERVER";
                  if(SysGetUserInfo(0) && sizeof(SysGetUserInfo(0)) > 0 )
                  eleven = SysGetUserInfo(0);
                  licensetype = "Cinema R12";
                    On 28/10/2010 at 08:22, xxxxxxxx wrote:
                    Howdy,
                    But that is coffee code. 😕
                    Adios,
                    Cactus Dan
                      On 28/10/2010 at 08:39, xxxxxxxx wrote:
                      Yup, but I just wondered if SysGetUserInfo() might be useful / available for C++ as well,
                      but that I can't tell....
                      Lennart
                        On 28/10/2010 at 09:20, xxxxxxxx wrote:
                        Howdy,
                        Well, no that function isn't in the C++ SDK.
                        The code I posted was based on the example code in the R11.5 C++ SDK documentation:
                        void GeGetSerialInfo(LONG type, SerialInfo[URL-REMOVED]* si)_<_h4_>_
                        Get the registration information for CINEMA 4D.
                        A multi-license has the following formating:
                        201 **[100]** 00519-ABCDEF
                        The third, fourth and fifth digits equal the number of licenses, in the above example it's 100 licenses.
                        Example:
                        SerialInfo si;
                        if(si.nr.Content())
                          //multi-license, do something
                        else
                          GeGetSerialInfo(SERIAL_CINEMA4D, &si);
                        //single-license, do something
                        That's basically what I was doing in my code, except that my code was only using that to find out whether to call Read/WritePluginInfo() or Read/WriteRegInfo().
                        Edit:
                        Well, I reckon the problem is that I don't have a beta tester who is on a multi license, who can check to see if it's working. 😠
                        Adios,
                        Cactus Dan
                          On 03/11/2010 at 03:12, xxxxxxxx wrote:
                          Your code seems to work fine here. I tested it with and without license server.
                          I only slightly modified the code.
                            SerialInfo si;
                            if(si.nr.Content())
                            else
                                if(si.nr.Content())
                            return FALSE;
                            SerialInfo si;
                            if(si.nr.Content())
                            else
                                if(si.nr.Content())
                            return FALSE;
                            On 03/11/2010 at 06:40, xxxxxxxx wrote:
                            Howdy,
                            Thanks Matthias.
                            But the question in my mind is if the user is under a multi license,  is the main Cinema 4D license number still accessable?
                            The code I posted only decides where to read and write the plugin info, but then in the calling function, it's comparing the plugin serial number to the main Cinema 4D license with:
                            GeGetSerailInfo(SERIAL_CINEMA4D, &si);
                            Under a multi license, does the above code still get the 101xxxxxxxx license?
                            Adios,
                            Cactus Dan
                              On 03/11/2010 at 07:04, xxxxxxxx wrote:
                              Calling GeGetSerialInfo(SERIAL_CINEMA4D, &si) with a multi license will return the license server client number. On the other hand if you call GeGetSerialInfo(SERIAL_MULTILICENSE, &si) with a single license will result in an empty string. This way you can differenciate between multi and single license.
                              hope that helps
                                On 03/11/2010 at 07:12, xxxxxxxx wrote:
                                Howdy,
                                ...Calling GeGetSerialInfo(SERIAL_CINEMA4D, &si) with a multi license will return the license server client number...
                                So, is that the 201xxxxxxxx or the 101xxxxxxxx number? I'm only really interested in the 101xxxxxxxx number.
                                Adios,
                                Cactus Dan
                                  On 03/11/2010 at 07:17, xxxxxxxx wrote:
                                  The 101xxxxxxxx is the license server client number. This is different for each of the running licenses of one multi license. GeGetSerialInfo(SERIAL_CINEMA4D, &si) under a multi license will return 101xxxxxxxx.
                                    On 03/11/2010 at 07:30, xxxxxxxx wrote:
                                    Howdy,
                                    OK, so does that mean by using:
                                    ... to get the 101xxxxxxxx serial number and comparing it to the plugin serial number retrieved from my posted function code, the plugin will still register, but every seat on the multi license will be able to register and use the same plugin serial number?
                                    Adios,
                                    Cactus Dan
                                      On 03/11/2010 at 08:01, xxxxxxxx wrote:
                                      As far as I see it you need no to be concerned about the 101xxx number.
                                      Just check if it's a multi or single license (mulit will result in an empty string).
                                      If multi use the string returned with GeGetSerialInfo(SERIAL_MULTILICENSE, &si) to bind your plugin serial to. This is a 20xxxxxxxxxxx number (201xxxxxxxxxx for <R12, 202xxxxxxxxxx for R12 afaik).
                                      If it's a single license use the string returned by GeGetSerialInfo(SERIAL_CINEMA4D, &si) to bind your plugin serial to.
                                      Make sure to use Read/WriteRegInfo for multi licenses and Read/WritePluginInfo for single licenses.
                                        On 03/11/2010 at 08:17, xxxxxxxx wrote:
                                        Howdy,
                                        Well, I wanted to allow 1 plugin serial number to be used for all of the seats in a multi license, instead of making each seat pay for a separate plugin license. That's why I'm so interested in getting the 101xxxxxxxx number from within each seat. 😉
                                        Adios,
                                        Cactus Dan
                                          Howdy,
                                          Adios,
                                          Cactus Dan
                                          The 20xxxxxxxxxxx stays same for every seat. This is the number your customer is sending you. It tells you how many licenses he owns. What you do with that number is up to you 🙂
                                            On 03/11/2010 at 10:36, xxxxxxxx wrote:
                                            Howdy,
                                            OK, let me see if I have this straight.
                                            Say a customer has a 5 seat multi license, then his first 11 digits would be 201005xxxxx, each seat would return that number using:
                                            GeGetSerialInfo(SERIAL_MULTILICENSE,&si);
                                            ... and the "xxxxx" part of the number would be the same for each seat, so my plugin's serial number needs to be generated from that 201005xxxxx number?
                                            Sorry for all the nit picky questions, but I don't have access to a multi license for testing. Confused
                                            Adios,
                                            Cactus Dan
