    User plugin serial number issue
    35 Posts 0 Posters 18.8k Views
      On 22/10/2010 at 18:34, xxxxxxxx wrote:
      Howdy,
      OK, hold on I think I'm getting it. 🙂
      Adios,
      Cactus Dan
        On 23/10/2010 at 12:21, xxxxxxxx wrote:
        Could you finally figure it out dan?
          On 23/10/2010 at 12:25, xxxxxxxx wrote:
          Howdy,
          Well, I think so, but I'll have to wait to hear from the user to see if it worked. 😉
          Adios,
          Cactus Dan
            On 28/10/2010 at 06:24, xxxxxxxx wrote:
            Howdy,
            The user is saying it's still not working.
            Here's what I did. I created my own function calls like this:
            Bool myReadPluginInfo(LONG pluginid, void *buffer, LONG size)
            SerialInfo si;
            GeGetSerialInfo(SERIAL_MULTILICENSE, &si);
            if(si.nr.Content())
            	return ReadRegInfo(pluginid,buffer,size); // multi license
            else
            	return ReadPluginInfo(pluginid,buffer,size); // single license
            Bool myWritePluginInfo(LONG pluginid, void *buffer, LONG size)
            SerialInfo si;
            if(si.nr.Content())
            	return WriteRegInfo(pluginid,buffer,size); // multi license
            else
            	return WritePluginInfo(pluginid,buffer,size); // single license
            Seems like that should work, shouldn't it?
            Adios,
            Cactus Dan
              On 28/10/2010 at 06:36, xxxxxxxx wrote:
              yep, looks right to me. Did he provide you with the license server serial number?
                On 28/10/2010 at 06:45, xxxxxxxx wrote:
                Howdy,
                He provided the normal Cinema 4D serial number, BUT in my routine for checking the Cinema 4D serial number I use this:
                SerialInfo si;
                GeGetSerialInfo(SERIAL_CINEMA4D,&si);
                So, the previous code I posted is simply using
                to check if it's a mult license or single license and then calling the appropriate c4d function to fill the buffer.
                Adios,
                Cactus Dan
                  On 28/10/2010 at 07:21, xxxxxxxx wrote:
                  Well, that might be the problem. If the c4d license is in a license server environment then afaik you should use the license server serial number (as not the c4d serial number is used for running that c4d license in that case) which at the same time means you must license the amount of seats to them and you cannot license individual seats or a limited number of seats. So if they have 20 seats they must buy 20 licenses from you (of course you could trust them that they will only use your plugin with that one c4d seat but well...really?).
                  But I think only Matthias can give you an official answer on this.
                    On 28/10/2010 at 07:42, xxxxxxxx wrote:
                    Howdy,
                    I've sent Matthias a private message asking him to look at this thread.
                    This whole multi license thing has been confusing to me. I never really cared to make a customer pay for using the plugin on each seat in their multi license, so I thought if I just left the old code as is, looking for the Rx.0 number, everything would be fine. Up until now, everything has been fine (no customers with multi licenses), but it looks like it has turned around and bitten me in the upholstery. :frowning2:
                    Adios,
                    Cactus Dan
                      On 28/10/2010 at 08:14, xxxxxxxx wrote:
                      Don't know if this helps but from earlier threads I use
                      SysGetUserInfo(6) for MLS and
                      SysGetUserInfo(0) for main app running local number.
                      I've asked the MLS users I have with R12, and it seems to be ok.
                      Lennart
                      var eleven; // the app serials
                      var licensetype;
                      if(SysGetUserInfo(6) && sizeof(SysGetUserInfo(6)) > 0 )
                      eleven = SysGetUserInfo(6);
                      licensetype = "LICENSE SERVER";
                      if(SysGetUserInfo(0) && sizeof(SysGetUserInfo(0)) > 0 )
                      eleven = SysGetUserInfo(0);
                      licensetype = "Cinema R12";
                        On 28/10/2010 at 08:22, xxxxxxxx wrote:
                        Howdy,
                        But that is coffee code. 😕
                        Adios,
                        Cactus Dan
                          On 28/10/2010 at 08:39, xxxxxxxx wrote:
                          Yup, but I just wondered if SysGetUserInfo() might be useful / available for C++ as well,
                          but that I can't tell....
                          Lennart
                            On 28/10/2010 at 09:20, xxxxxxxx wrote:
                            Howdy,
                            Well, no that function isn't in the C++ SDK.
                            The code I posted was based on the example code in the R11.5 C++ SDK documentation:
                            void GeGetSerialInfo(LONG type, SerialInfo[URL-REMOVED]* si)_<_h4_>_
                            Get the registration information for CINEMA 4D.
                            A multi-license has the following formating:
                            201 **[100]** 00519-ABCDEF
                            The third, fourth and fifth digits equal the number of licenses, in the above example it's 100 licenses.
                            Example:
                            SerialInfo si;
                            if(si.nr.Content())
                              //multi-license, do something
                            else
                              GeGetSerialInfo(SERIAL_CINEMA4D, &si);
                            //single-license, do something
                            That's basically what I was doing in my code, except that my code was only using that to find out whether to call Read/WritePluginInfo() or Read/WriteRegInfo().
                            Edit:
                            Well, I reckon the problem is that I don't have a beta tester who is on a multi license, who can check to see if it's working. 😠
                            Adios,
                            Cactus Dan
                              On 03/11/2010 at 03:12, xxxxxxxx wrote:
                              Your code seems to work fine here. I tested it with and without license server.
                              I only slightly modified the code.
                                SerialInfo si;
                                if(si.nr.Content())
                                else
                                    if(si.nr.Content())
                                return FALSE;
                                SerialInfo si;
                                if(si.nr.Content())
                                else
                                    if(si.nr.Content())
                                return FALSE;
                                On 03/11/2010 at 06:40, xxxxxxxx wrote:
                                Howdy,
                                Thanks Matthias.
                                But the question in my mind is if the user is under a multi license,  is the main Cinema 4D license number still accessable?
                                The code I posted only decides where to read and write the plugin info, but then in the calling function, it's comparing the plugin serial number to the main Cinema 4D license with:
                                GeGetSerailInfo(SERIAL_CINEMA4D, &si);
                                Under a multi license, does the above code still get the 101xxxxxxxx license?
                                Adios,
                                Cactus Dan
                                  On 03/11/2010 at 07:04, xxxxxxxx wrote:
                                  Calling GeGetSerialInfo(SERIAL_CINEMA4D, &si) with a multi license will return the license server client number. On the other hand if you call GeGetSerialInfo(SERIAL_MULTILICENSE, &si) with a single license will result in an empty string. This way you can differenciate between multi and single license.
                                  hope that helps
                                    On 03/11/2010 at 07:12, xxxxxxxx wrote:
                                    Howdy,
                                    ...Calling GeGetSerialInfo(SERIAL_CINEMA4D, &si) with a multi license will return the license server client number...
                                    So, is that the 201xxxxxxxx or the 101xxxxxxxx number? I'm only really interested in the 101xxxxxxxx number.
                                    Adios,
                                    Cactus Dan
                                      On 03/11/2010 at 07:17, xxxxxxxx wrote:
                                      The 101xxxxxxxx is the license server client number. This is different for each of the running licenses of one multi license. GeGetSerialInfo(SERIAL_CINEMA4D, &si) under a multi license will return 101xxxxxxxx.
                                        On 03/11/2010 at 07:30, xxxxxxxx wrote:
                                        Howdy,
                                        OK, so does that mean by using:
                                        ... to get the 101xxxxxxxx serial number and comparing it to the plugin serial number retrieved from my posted function code, the plugin will still register, but every seat on the multi license will be able to register and use the same plugin serial number?
                                        Adios,
                                        Cactus Dan
                                          On 03/11/2010 at 08:01, xxxxxxxx wrote:
                                          As far as I see it you need no to be concerned about the 101xxx number.
                                          Just check if it's a multi or single license (mulit will result in an empty string).
                                          If multi use the string returned with GeGetSerialInfo(SERIAL_MULTILICENSE, &si) to bind your plugin serial to. This is a 20xxxxxxxxxxx number (201xxxxxxxxxx for <R12, 202xxxxxxxxxx for R12 afaik).
                                          If it's a single license use the string returned by GeGetSerialInfo(SERIAL_CINEMA4D, &si) to bind your plugin serial to.
                                          Make sure to use Read/WriteRegInfo for multi licenses and Read/WritePluginInfo for single licenses.
                                            On 03/11/2010 at 08:17, xxxxxxxx wrote:
                                            Howdy,
                                            Well, I wanted to allow 1 plugin serial number to be used for all of the seats in a multi license, instead of making each seat pay for a separate plugin license. That's why I'm so interested in getting the 101xxxxxxxx number from within each seat. 😉
                                            Adios,
                                            Cactus Dan
