    Data type conflicts
    6 Posts 0 Posters 642 Views
      On 25/09/2010 at 14:06, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      I need to include <windows.h> in my Melange source code files, however, "c4d_system.h" is not very friendly
      with it.  I'm getting hundreds of errors:
      c:\melange\commandline\source\alien_def.h(29) : error C2872: 'LONG' : ambiguous symbol
              could be 'C:\Program Files\Microsoft SDKs\Windows\v6.0A\\include\winnt.h(278) : long LONG'
              or       'c:\melange\_melange\includes\c4d_system.h(85) : _melange_::LONG'
      .\source est.cpp(2252) : error C2872: 'LONG' : ambiguous symbol
      .\source est.cpp(2253) : error C2872: 'CHAR' : ambiguous symbol
              could be 'C:\Program Files\Microsoft SDKs\Windows\v6.0A\\include\winnt.h(276) : char CHAR'
              or       'c:\melange\_melange\includes\c4d_system.h(95) : _melange_::CHAR'
      .\source est.cpp(2264) : error C2872: 'UCHAR' : ambiguous symbol
      .\source est.cpp(2264) : fatal error C1003: error count exceeds 100; stopping compilation
      How can I resolve these data type conflicts?  I absolutely need to use <windows.h>.
      I'm using the commandline example from the Melange library.
      My header looks like:
      #include <windows.h>
      #include "C4DImportExport.h"
      And if I comment out this line in alien_def.h
      //using namespace _melange_;
      I still get hundreds of errors.
        On 25/09/2010 at 18:13, xxxxxxxx wrote:
        It appears as though the Windows API is using the same data type as C4D...    LONG..    Is there a a way to use "long" (the C++ type) instead of LONG (the c4d type)?  probably not as many of the functions probably rely on LONG.    hmmmm....  Why do you need the Windows.h ?
        ~Shawn
          On 25/09/2010 at 18:20, xxxxxxxx wrote:
          The problem isn't me using LONG.  It's the Melange library using it.
          There's also conflicts with INT, UINT, CHAR, and UCHAR, all over the place.
          I'm using functions from <windows.h>, so it's absolutely necessary that it's included.
            On 25/09/2010 at 18:24, xxxxxxxx wrote:
            EDIT:  Sorry read your post after I posted.
              On 29/09/2010 at 11:28, xxxxxxxx wrote:
              to avoid those type conflicts you could include windows.h in your test.cpp file only.
              if you need it in your header file e.g. alien_def.h please change the line
              to
              namespace _melange_
              -> this at the end of the file
              in C4DImportExport.cpp add the same lines after #include "C4DImportExport.h" (the "}" at the end of the file again)
              then you have to move the following definitions outside the namespace definition:
              GetWriterInfo()
              AllocAlienTagData()
              AllocAlienObjectData()
              AllocAlienRootMaterial()
              AllocAlienRootObject()
              AllocAlienRootLayer()
              AllocAlienRootRenderData()
              AllocC4DRootViewPanel()
              AllocAlienLayer()
              move these to the last line after the _melange_ namespace and add the namespace name before the types like this:
              __melange_::RootMaterial *AllocAlienRootMaterial()                { return gNew _melange_::AlienRootMaterial; }
              _melange_::RootObject *AllocAlienRootObject()                         { return gNew _melange_::AlienRootObject; }
              _melange_::RootLayer *AllocAlienRootLayer()                              { return gNew _melange_::AlienRootLayer; }
              _melange_::RootRenderData *AllocAlienRootRenderData()     { return gNew _melange_::AlienRootRenderData; }
              _melange_::RootViewPanel *AllocC4DRootViewPanel()               { return gNew _melange_::RootViewPanel; }
              _melange_::LayerObject *AllocAlienLayer()                                   { return gNew _melange_::AlienLayer; }
              _melange_::NodeData *AllocAlienObjectData(_melange_::LONG id, _melange_::Bool &known;)
                   _melange_::NodeData *m_data = NULL;
                   known = TRUE;
                   switch (id)
                        //supported element types
                   case Ocamera:                    m_data = gNew _melange_::AlienCameraObjectData; break;
              _melange_::NodeData *AllocAlienTagData(_melange_::LONG id, _melange_::Bool &known;)
              void GetWriterInfo(_melange_::LONG &id;, _melange_::String &appname; )
              _
              hope this helps!
              cheers
              jens
                On 29/09/2010 at 12:16, xxxxxxxx wrote:
                I found a more simple solution.  Melange must use data types provided by Windows.
                I had to replace _melange_::LONG with LONG, and I commented out all these typedefs:
                //typedef long   LONG;
                //typedef unsigned long  ULONG;
                //typedef int   INT;
                //typedef unsigned int  UINT;
                //typedef char   CHAR;
                //typedef unsigned char  UCHAR;
                Or, if you want to leave them in, you can do this:
                // check for "windows.h" header
                #ifndef _WINDOWS_
                typedef long   LONG;
                typedef int   INT;
                typedef char   CHAR;
                #endif // _WINDOWS_
