Data type conflicts
On 25/09/2010 at 14:06, xxxxxxxx wrote:
Cinema 4D Version: R12
Platform: Windows ;
Language(s) : C++ ;---------
I need to include <windows.h> in my Melange source code files, however, "c4d_system.h" is not very friendly
with it. I'm getting hundreds of errors:
c:\melange\commandline\source\alien_def.h(29) : error C2872: 'LONG' : ambiguous symbol
could be 'C:\Program Files\Microsoft SDKs\Windows\v6.0A\\include\winnt.h(278) : long LONG'
or 'c:\melange\_melange\includes\c4d_system.h(85) : _melange_::LONG'
.\source est.cpp(2252) : error C2872: 'LONG' : ambiguous symbol
.\source est.cpp(2253) : error C2872: 'CHAR' : ambiguous symbol
could be 'C:\Program Files\Microsoft SDKs\Windows\v6.0A\\include\winnt.h(276) : char CHAR'
or 'c:\melange\_melange\includes\c4d_system.h(95) : _melange_::CHAR'
.\source est.cpp(2264) : error C2872: 'UCHAR' : ambiguous symbol
.\source est.cpp(2264) : fatal error C1003: error count exceeds 100; stopping compilation
How can I resolve these data type conflicts? I absolutely need to use <windows.h>.
I'm using the commandline example from the Melange library.
My header looks like:
#include <windows.h>
#include "C4DImportExport.h"And if I comment out this line in alien_def.h
//using namespace _melange_;
I still get hundreds of errors. -
On 25/09/2010 at 18:13, xxxxxxxx wrote:
It appears as though the Windows API is using the same data type as C4D... LONG.. Is there a a way to use "long" (the C++ type) instead of LONG (the c4d type)? probably not as many of the functions probably rely on LONG. hmmmm.... Why do you need the Windows.h ?
~Shawn
On 25/09/2010 at 18:20, xxxxxxxx wrote:
The problem isn't me using LONG. It's the Melange library using it.
There's also conflicts with INT, UINT, CHAR, and UCHAR, all over the place.
I'm using functions from <windows.h>, so it's absolutely necessary that it's included. -
On 25/09/2010 at 18:24, xxxxxxxx wrote:
EDIT: Sorry read your post after I posted.
On 29/09/2010 at 11:28, xxxxxxxx wrote:
to avoid those type conflicts you could include windows.h in your test.cpp file only.
if you need it in your header file e.g. alien_def.h please change the line
to
namespace _melange_
} -> this at the end of the filein C4DImportExport.cpp add the same lines after #include "C4DImportExport.h" (the "}" at the end of the file again)
then you have to move the following definitions outside the namespace definition:
GetWriterInfo()
AllocAlienTagData()
AllocAlienObjectData()
AllocAlienRootMaterial()
AllocAlienRootObject()
AllocAlienRootLayer()
AllocAlienRootRenderData()
AllocC4DRootViewPanel()
AllocAlienLayer()move these to the last line after the _melange_ namespace and add the namespace name before the types like this:
__melange_::RootMaterial *AllocAlienRootMaterial() { return gNew _melange_::AlienRootMaterial; }
_melange_::RootObject *AllocAlienRootObject() { return gNew _melange_::AlienRootObject; }
_melange_::RootLayer *AllocAlienRootLayer() { return gNew _melange_::AlienRootLayer; }
_melange_::RootRenderData *AllocAlienRootRenderData() { return gNew _melange_::AlienRootRenderData; }
_melange_::RootViewPanel *AllocC4DRootViewPanel() { return gNew _melange_::RootViewPanel; }
_melange_::LayerObject *AllocAlienLayer() { return gNew _melange_::AlienLayer; }_melange_::NodeData *AllocAlienObjectData(_melange_::LONG id, _melange_::Bool &known;)
_melange_::NodeData *m_data = NULL;
known = TRUE;
switch (id)
//supported element types
case Ocamera: m_data = gNew _melange_::AlienCameraObjectData; break;
..._melange_::NodeData *AllocAlienTagData(_melange_::LONG id, _melange_::Bool &known;)
...void GetWriterInfo(_melange_::LONG &id;, _melange_::String &appname; )
_
hope this helps!cheers
jens -
On 29/09/2010 at 12:16, xxxxxxxx wrote:
I found a more simple solution. Melange must use data types provided by Windows.
I had to replace _melange_::LONG with LONG, and I commented out all these typedefs://typedef long LONG; //typedef unsigned long ULONG; //typedef int INT; //typedef unsigned int UINT; //typedef char CHAR; //typedef unsigned char UCHAR;
Or, if you want to leave them in, you can do this:
// check for "windows.h" header #ifndef _WINDOWS_ typedef long LONG; typedef unsigned long ULONG; typedef int INT; typedef unsigned int UINT; typedef char CHAR; typedef unsigned char UCHAR; #endif // _WINDOWS_
