    Noise Functions
    33 Posts 0 Posters 17.6k Views
      On 05/06/2010 at 13:03, xxxxxxxx wrote:
      this is how I am attempting to subdivide
      but it keeps crashing
      		if (mdat.bc->GetBool(HYPERNURBS_SUBDIVISION, TRUE))  //If HyperNURBS is checked
      		mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, TRUE);
      		else
      		mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, FALSE);
      		mdat.bc->SetLong(MDATA_SUBDIVIDE_SUB, subAmount);
      	    mdat.bc->SetReal(MDATA_SUBDIVIDE_ANGLE, mdat.bc->GetReal(MAX_ANGLE));
      	//Subdivision Command
      	SendModelingCommand(MCOMMAND_SUBDIVIDE, mdat);
        On 05/06/2010 at 13:04, xxxxxxxx wrote:
        MAX_ANGLE is equal to pi   and subAMount is a real that the user can adjust.   🙂
          On 05/06/2010 at 13:11, xxxxxxxx wrote:
          try catching the crash with
          if(SendModelingCommand(MCOMMAND_SUBDIVIDE, mdat))
          GePrint("done");
          else
          GePrint("failed");
          just to be on the safe side..
            On 05/06/2010 at 13:44, xxxxxxxx wrote:
            Here's my subdivision code now...
            Still crashing.
            //SUBDIVISION
            		Real subAmount;
            		subAmount = mcd2.bc->GetLong(SPACEROCK_SUBDIVISIONS);
            		mcd2.mode = MODIFY_ALL;
            		mcd2.doc = hh->GetDocument();
            		if(SendModelingCommand(MCOMMAND_SUBDIVIDE, mcd2))
            			GePrint("done");
            			mcd2.bc->SetBool(MDATA_SUBDIVIDE_HYPER, TRUE);
            			mcd2.bc->SetLong(MDATA_SUBDIVIDE_SUB, subAmount);
            			mcd2.bc->SetReal(MDATA_SUBDIVIDE_ANGLE, pi);
            			SendModelingCommand(MCOMMAND_SUBDIVIDE, mcd2);
            		else
            			GePrint("failed");
            Any thoughts?
              On 05/06/2010 at 13:55, xxxxxxxx wrote:
              hey, dont call SendModelingCommand twice.. its already called in the if condition!
                On 05/06/2010 at 14:06, xxxxxxxx wrote:
                well.. that was a good thought and a good catch but unfortunately it's still crashing .. this one is a bit of a thorn today.  LOL
                  On 05/06/2010 at 14:14, xxxxxxxx wrote:
                  another thing could be worth a try, to set the Parameters for an extra BaseContainer like i did it in my example:
                  BaseContainer bc;
                            bc.SetReal(MDATA_OPTIMIZE_TOLERANCE, tolerance);
                            bc.SetReal(MDATA_OPTIMIZE_POINTS, TRUE);
                            bc.SetReal(MDATA_OPTIMIZE_POLYGONS, TRUE);
                            bc.SetReal(MDATA_OPTIMIZE_UNUSEDPOINTS, TRUE);
                            cd.bc = &bc;
                  and in the if (SendModelingCommand... call "cd.op->Message(MSG_UPDATE, NULL);"
                  Oh, wait, i didnt see you setting mcd2.op to your object, maybe thats the main problem
                    On 05/06/2010 at 14:21, xxxxxxxx wrote:
                    yeah I added that in after I sent the message..  that didn't work.. I'
                    ll try your other suggestion though.   Thanks,
                    ~Shawn
                      On 05/06/2010 at 14:31, xxxxxxxx wrote:
                      alternatively, did you try CallCommand(14047); ?? maybe that works... but i dont know how you set the parameters in this case..
                        On 05/06/2010 at 15:15, xxxxxxxx wrote:
                        Awesome..  It works.   Used your different basecontainer suggestion.
                        //SUBDIVISION
                        		Real subAmount = bc->GetReal(SPACEROCK_SUBDIVISIONS);
                        		BaseContainer bc2;
                        		bc2.SetBool(MDATA_SUBDIVIDE_HYPER, TRUE);
                        		bc2.SetLong(MDATA_SUBDIVIDE_SUB, subAmount);
                        		bc2.SetReal(MDATA_SUBDIVIDE_ANGLE, pi);
                        		mcd2.bc = &bc2;
                        		mcd2.op = polyCube;
                        			GePrint("done");
                        		else
                        			GePrint("failed");
                        Thanks again.  I'm calling it a night.   Thanks for your help.
                          On 05/06/2010 at 15:18, xxxxxxxx wrote:
                          Hi, i did a quick test on subdividing and it works here.. dont ask me why it needs to create the dependency list twice, but if i dont do it, the plugin is updating everytime something changes in the editor even if you turn the camera and such.. if someone can tell my why, i'd be happy.
                          anyways, here is what is working for me:
                          #define pluginID 1000001
                          #define pluginName "testObject"
                          #include "c4d.h"
                          #include "c4d_symbols.h"
                          class testObject : public ObjectData
                            INSTANCEOF(testObject,ObjectData);
                          private:
                            virtual BaseObject* GetVirtualObjects(PluginObject *op, HierarchyHelp *hh);
                            static NodeData *Alloc(void) { return gNew testObject; }
                          BaseObject *testObject::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
                            BaseDocument* doc = op->GetDocument();
                            ModelingCommandData cd;
                            Bool dirty;
                            BaseObject* main = BaseObject::Alloc(Onull);
                            if (!main) goto Error;
                            BaseObject* child = op->GetDown();
                            if (!child) goto Error;
                            op->NewDependenceList();
                            op->AddDependence(hh,child);
                            dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_MATRIX|DIRTY_DATA|DIRTY_CHILDREN);
                            dirty = dirty || !op->CompareDependenceList();
                            if (!dirty)
                                blDelete(main);
                                op->TouchDependenceList();
                                return op->GetCache(hh);
                            BaseObject* clone = op->GetAndCheckHierarchyClone(hh,child,HCLONE_ASPOLY,&dirty,0,false);//static_cast<PolygonObject*>(child->GetClone(0,0));
                            if (clone)
                                GePrint ("cloned");
                                if (clone->GetType()==Opolygon)
                                    GePrint("polygonobject detected");
                                    cd.doc = doc;
                                    cd.op = clone;
                                    BaseContainer bc;
                                    bc.SetBool(MDATA_SUBDIVIDE_HYPER, true);
                                    bc.SetReal(MDATA_SUBDIVIDE_ANGLE, 90);
                                    bc.SetLong(MDATA_SUBDIVIDE_SUB, 2);
                                    cd.bc = &bc;
                                    if(SendModelingCommand(MCOMMAND_SUBDIVIDE, cd))
                                        GePrint("modeling command sent: MCOMMAND_SUBDIVIDE");
                                    else
                                        GePrint("failed");
                                    clone->InsertUnderLast(main);
                                else
                                    blDelete(clone);
                            return main;
                          Error:
                            if (main) blDelete(main);
                            return NULL;
                          Bool Register_testObject(void)
                            GePrint("- testObject");
                            return RegisterObjectPlugin(pluginID,pluginName,OBJECT_GENERATOR|OBJECT_INPUT,testObject::Alloc,"OtestObject","orgaLine.tif",0);
                          hope this helps
                            On 05/06/2010 at 15:19, xxxxxxxx wrote:
                            *G i was late again 🙂
