    Using PriorityList?
    5 Posts 0 Posters 547 Views
      On 28/05/2010 at 09:03, xxxxxxxx wrote:
      Cinema 4D Version:   r11
      Hi there,
      can someone tell me how i can use PriorityLists?? I'd like to set Priority of my Plugin to somewhat value for testing purposes.. but the forum search returns nothing on "PriorityList"
      anyone??
      thanks and cheers,
      ello
        On 31/05/2010 at 02:04, xxxxxxxx wrote:
        Please always specify what kind of plugin you are creating (TagData, ObjectData etc.).
          On 31/05/2010 at 02:21, xxxxxxxx wrote:
          I am creating a Generator Plugin.. The reason is that somehow my plugin works only if the linked objects are below the PluginObject in the object manager. so i had the idea that maybe it would help if my plugin gets a higher priority...
          thanks and cheers,
          ello
            On 31/05/2010 at 02:53, xxxxxxxx wrote:
            I guess you are using link fields to link to other objects in the scene in your scene? MoGraph is facing the exact same issue, sometimes you have to place effectors above or below the cloner object. This is a limitation of Cinema 4D. So I don't think adding a priority to your generator will help. Anyway here is a link to a thread how to add a priority list to generators.
            https://developers.maxon.net/forum/topic/4115/3655_adding-priority-to-objects-am
              On 31/05/2010 at 03:23, xxxxxxxx wrote:
              thank you for clearing this up. at least i can tell its a cinema limitation if someone asks 😉
              and thanks for the link which i'll check out anyways
              ello
