point normals
On 16/03/2010 at 09:21, xxxxxxxx wrote:
Cinema 4D Version: r11
Language(s) : C++ ;---------
hi there,how can i create a normal direction for a point? i suppose that i need to calculate the sum of the normals of all polygons which use that point and than divide it by the number of polygons used. but 1. how do i find out which polygons use a certain point and 2. would that be a performance issue (if i would cycle thru all polygons for every point and check if the point is used by that polygon)?
thanks and cheers,
ello -
On 16/03/2010 at 16:42, xxxxxxxx wrote:
Howdy,
Have a look at the Neighbor class.
Adios,
Cactus Dan -
On 16/03/2010 at 22:44, xxxxxxxx wrote:
Thank you! Thats exactly what i need
Ello -
On 18/03/2010 at 11:48, xxxxxxxx wrote:
Of course you could also just let C4D tell you what they are - look at: PolygonObject::CreatePhongNormals() - the advantage to that is that phong-break edges are also taken into account.
Keith
On 18/03/2010 at 13:24, xxxxxxxx wrote:
thank you.. now i did this:
Vector n; Vector* phongNormal = myMesh->CreatePhongNormals(); for (int i=0;i<pointcount;i++) { n=phongNormal[i] _; }
Is there anything wrong with my assumption that this should return the normal for point i ? somehow it looks a bit screwed up..
thanks for your input,
ello
_ -
On 18/03/2010 at 13:48, xxxxxxxx wrote:
CreatePhongNormals() creates normals for each of a polygon's points. For a cube for instance it will create 6*4 point normals. This is necessary to describe phong breaks. Depending on what you want to achieve this is maybe not really what you are looking for. I am guessing that you are looking for a way to obtain average point normals, right?
Matthias -
On 18/03/2010 at 13:52, xxxxxxxx wrote:
yes, exactly.. so do you think i should go the way using the Neighbours ?
On 19/03/2010 at 01:04, xxxxxxxx wrote:
Well you can still use CreatePhongNormals() and average these normals for each point.
-build the point normals per polygon array with CreatePhongNormals()
-iterate through all the points, GetPointR(), GetPointCount()
-get the adjacent polygons for each point with GetPointPolys()
-for each adjacent polygon get the point normal for the common point
-average these normalsalternatively
-calculate the polygon normal for each adjacent polygon (or create an polygon normal array in advance)
-average these normalsSince there is no "correct" way you have to try which works better for you.
Matthias -
On 19/03/2010 at 01:29, xxxxxxxx wrote:
thank you.. after looking again at my code i found why i got that error message. i wrote Neighbour instead of Neighbor..
kind regards,
ello -
On 19/03/2010 at 12:38, xxxxxxxx wrote:
Hi, i am still having a problem here.
neighbor.GetPointPolys(i,&dadr,&dcnt); GePrint(LongToString(dcnt));
dcnt is always 0, but how can this be? there are actually quite a lot of points and polygons in the base mesh..
i dont understand this.thanks for any input.
ello -
On 19/03/2010 at 12:49, xxxxxxxx wrote:
Sorry these two lines of code don't say much
Please post a bigger portion of your code, for instance how you initialized the Neighbor class.
Matthias -
On 19/03/2010 at 12:58, xxxxxxxx wrote:
oh, ok.. i placed the neighbor.Init(...) in a condition which wasnt true..
it works now. thanks for all your helpcheers,
ello -
On 11/06/2010 at 09:42, xxxxxxxx wrote:
hi again,
i am still struggling and i thought before further hijacking the other thread i bring this thead up again:
here is my code for averaging.. polygonNormal returns the right polygon normals, as seen in this screen:
padr = cloneOfBase->GetPointR(); pol = cloneOfBase->GetPolygonR(); numberofclones = cloneOfBase->GetPointCount(); maxcount = cloneOfBase->GetPolygonCount(); ... if (neighbor.Init(numberofclones, pol, maxcount, NULL)) { neighbor.GetPointPolys(i, &dadr, &dcnt); if (dcnt) { for (int j=0;j<dcnt;j++) { if (dadr[j]<=maxcount) { polyNormal += polygonNormal(nCalc1,nCalc2,padr,pol,dadr[j]); } } polyNormal /= dcnt; } }
any ideas??
ello -
On 11/06/2010 at 10:18, xxxxxxxx wrote:
I see that you're still not normalizing the result of polygonNormal() or of polyNormal, after you've divided it... have you tried that?
On 11/06/2010 at 10:25, xxxxxxxx wrote:
yes, that gave me even stranger results. what i dont understand is that it works for most of the points
On 11/06/2010 at 11:30, xxxxxxxx wrote:
Ok, here is some verified working code that I've stripped out to be stand-alone callable routines...
//--------------------------------------------------------------------------------------- //*************************************************************************************** // GetVertexNormals() //*************************************************************************************** //--------------------------------------------------------------------------------------- Vector *GetVertexNormals(PolygonObject *pObj) { LONG numVerts = pObj->GetPointCount(); LONG numPolys = pObj->GetPolygonCount(); const Vector *pVerts = pObj->GetPointR(); const CPolygon *pPolys = pObj->GetPolygonR(); // initialize neighbor class... this is used to compute m_SrcvNorms Neighbor neighbor; if( !neighbor.Init(numVerts, pPolys, numPolys, NULL) ) return NULL; // Allocate array of Normal Vectors to fill in and return Vector *pNormals = (Vector * )GeAlloc(numVerts * sizeof(Vector)); if( !pNormals ) return NULL; // Determine a Normal for each vertex of mesh LONG i, j, faceCnt, *pFaces = NULL; Vector vNorm; for(i=0; i<numVerts; i++) { vNorm = Vector(); // (re)intitialize neighbor.GetPointPolys(i, &pFaces;, &faceCnt;); if( faceCnt ) { for(j=0; j<faceCnt; j++) { Vector n = CalcFaceNormal(pVerts, pPolys[pFaces[j]]); vNorm += !n; } vNorm /= faceCnt; // average the normal(s) pNormals[i] = !vNorm; // normalize and store } else pNormals[i] = Vector(0.0,1.0,0.0); // default case = Up for any stray verts } return pNormals; } //--------------------------------------------------------------------------------------- //*************************************************************************************** // AddNormSplineObject() //*************************************************************************************** //--------------------------------------------------------------------------------------- void AddNormSplineObject(PolygonObject *pObj, LONG splineLen) { Vector *pNormals = GetVertexNormals(pObj); if( !pNormals ) return; LONG numNorms = pObj->GetPointCount(); // allocate spline object large enough for all points SplineObject *splineOp = SplineObject::Alloc(2*numNorms,Tlinear); if( !splineOp || !splineOp->MakeVariableTag(Tsegment,numNorms) ) { MessageDialog(String("Spline Object Allocation Failed")); GeFree(pNormals); return; } splineOp->SetName(String("NormSplines")); Vector *padr = splineOp->GetPointW(); Segment *sadr = splineOp->GetSegmentW(); if( !padr || !sadr ) { MessageDialog(String("Spline Object Data Setup Failed")); GeFree(pNormals); SplineObject::Free(splineOp); return; } const Vector *pVerts = pObj->GetPointR(); Matrix mg = pObj->GetMgn(); LONG normCnt = 0; LONG vertCnt = 0; LONG i; for(i=0; i<numNorms; i++) { sadr[normCnt].cnt = 2; sadr[normCnt++].closed = false; padr[vertCnt++] = pVerts[i] * mg; padr[vertCnt++] = (pVerts[i] + (pNormals[i] * splineLen)) * mg; } splineOp->GetDataInstance()->SetBool(SPLINEOBJECT_CLOSED,false); GeFree(pNormals); // done with this now BaseDocument *pBaseDoc = pObj->GetDocument(); pBaseDoc->InsertObject(splineOp,NULL,NULL); splineOp->Message(MSG_UPDATE); }
...just cut/paste that into your code and call the AddNormSplineObject() routine with your PolygonObject. Once you've verified that it's working, you can either use it as-is, or reference it to figure out why yours is not working.
On 11/06/2010 at 11:31, xxxxxxxx wrote:
If you have any compile errors or trouble with include files, let me know.
On 11/06/2010 at 12:08, xxxxxxxx wrote:
thank you very much.. after first crash, i passed my doc to the function like this,
void AddNormSplineObject(PolygonObject *pObj, LONG splineLen,BaseDocument *doc)and it works.. now i need to understand why it does
again, thank you very very much for your help!
ello -
On 11/06/2010 at 12:14, xxxxxxxx wrote:
D'oh! I guess that your PolygonObject wasn't yet attached to the scene :). I usually test all results before using pointers like that, but I kinda threw that in there at the last minute when I was stripping out my old Class member code.
Anyway... if you want, you can just use that GetVertexNormals() routine as-is (just be sure to GeFree() the array when you're done with it).
Good luck!
On 11/06/2010 at 12:18, xxxxxxxx wrote:
i now used the pNormals to rotate my clones and now it looks like when i told you how it looked after i used the normalised normals:
any idea? how can this be?? i'll have to recheck my code after the rotation. i just dont understand why it works for polygons, but not for points. very strange
