    point normals
    23 Posts 0 Posters 13.9k Views
      On 18/03/2010 at 13:52, xxxxxxxx wrote:
      yes, exactly.. so do you think i should go the way using the Neighbours ?
        On 19/03/2010 at 01:04, xxxxxxxx wrote:
        Well you can still use CreatePhongNormals() and average these normals for each point.
        -build the point normals per polygon array with CreatePhongNormals()
        -iterate through all the points, GetPointR(), GetPointCount()
        -get the adjacent polygons for each point with GetPointPolys()
        -for each adjacent polygon get the point normal for the common point
        -average these normals
        alternatively
        -calculate the polygon normal for each adjacent polygon (or create an polygon normal array in advance)
        Since there is no "correct" way you have to try which works better for you.
          On 19/03/2010 at 01:29, xxxxxxxx wrote:
          thank you.. after looking again at my code i found why i got that error message. i wrote Neighbour instead of Neighbor..
          kind regards,
          ello
            On 19/03/2010 at 12:38, xxxxxxxx wrote:
            Hi, i am still having a problem here.
                              neighbor.GetPointPolys(i,&dadr,&dcnt);
                              GePrint(LongToString(dcnt));
            dcnt is always 0, but how can this be? there are actually quite a lot of points and polygons in the base mesh..
            i dont understand this.
            thanks for any input.
            ello
              On 19/03/2010 at 12:49, xxxxxxxx wrote:
              Sorry these two lines of code don't say much 🙂 Please post a bigger portion of your code, for instance how you initialized the Neighbor class.
                On 19/03/2010 at 12:58, xxxxxxxx wrote:
                oh, ok.. i placed the neighbor.Init(...) in a condition which wasnt true..
                it works now. thanks for all your help 🙂
                ello
                  On 11/06/2010 at 09:42, xxxxxxxx wrote:
                  hi again,
                  i am still struggling and i thought before further hijacking the other thread i bring this thead up again:
                  here is my code for averaging.. polygonNormal returns the right polygon normals, as seen in this screen:
                        padr = cloneOfBase->GetPointR();
                        pol = cloneOfBase->GetPolygonR();
                        numberofclones = cloneOfBase->GetPointCount();
                        maxcount = cloneOfBase->GetPolygonCount();
                                if (neighbor.Init(numberofclones, pol, maxcount, NULL))
                                    neighbor.GetPointPolys(i, &dadr, &dcnt);
                                    if (dcnt)
                                        for (int j=0;j<dcnt;j++)
                                            if (dadr[j]<=maxcount)
                                                polyNormal += polygonNormal(nCalc1,nCalc2,padr,pol,dadr[j]);
                                        polyNormal /= dcnt;
                  any ideas??
                  ello
                    On 11/06/2010 at 10:18, xxxxxxxx wrote:
                    I see that you're still not normalizing the result of polygonNormal() or of polyNormal, after you've divided it... have you tried that?
                      On 11/06/2010 at 10:25, xxxxxxxx wrote:
                      yes, that gave me even stranger results. what i dont understand is that it works for most of the points
                        On 11/06/2010 at 11:30, xxxxxxxx wrote:
                        Ok, here is some verified working code that I've stripped out to be stand-alone callable routines...
                        // GetVertexNormals()
                        Vector *GetVertexNormals(PolygonObject *pObj)
                             LONG numVerts = pObj->GetPointCount();
                             LONG numPolys = pObj->GetPolygonCount();
                             const Vector *pVerts = pObj->GetPointR();
                             const CPolygon *pPolys = pObj->GetPolygonR();
                             // initialize neighbor class... this is used to compute m_SrcvNorms
                             Neighbor neighbor;
                             if( !neighbor.Init(numVerts, pPolys, numPolys, NULL) )
                                  return NULL;
                             // Allocate array of Normal Vectors to fill in and return
                             Vector *pNormals = (Vector * )GeAlloc(numVerts * sizeof(Vector));
                             if( !pNormals )     return NULL;
                             // Determine a Normal for each vertex of mesh
                             LONG i, j, faceCnt, *pFaces = NULL;
                             Vector vNorm;
                             for(i=0; i<numVerts; i++)
                                  vNorm = Vector();          // (re)intitialize
                                  neighbor.GetPointPolys(i, &pFaces;, &faceCnt;);
                                  if( faceCnt )
                                       for(j=0; j<faceCnt; j++)
                                            Vector n = CalcFaceNormal(pVerts, pPolys[pFaces[j]]);
                                            vNorm += !n;
                                       vNorm /= faceCnt;          // average the normal(s)
                                       pNormals[i] = !vNorm;     // normalize and store
                                  else
                                       pNormals[i] = Vector(0.0,1.0,0.0);     // default case = Up for any stray verts
                             return pNormals;
                        // AddNormSplineObject()
                        void AddNormSplineObject(PolygonObject *pObj, LONG splineLen)
                             Vector *pNormals = GetVertexNormals(pObj);
                             if( !pNormals )     return;
                             LONG numNorms = pObj->GetPointCount();
                             // allocate spline object large enough for all points
                             SplineObject *splineOp = SplineObject::Alloc(2*numNorms,Tlinear);
                             if( !splineOp || !splineOp->MakeVariableTag(Tsegment,numNorms) )
                                  MessageDialog(String("Spline Object Allocation Failed"));
                                  GeFree(pNormals);
                                  return;
                             splineOp->SetName(String("NormSplines"));
                             Vector *padr = splineOp->GetPointW();
                             Segment *sadr = splineOp->GetSegmentW();
                             if( !padr || !sadr )
                                  MessageDialog(String("Spline Object Data Setup Failed"));
                                  GeFree(pNormals);
                                  SplineObject::Free(splineOp);
                                  return;
                             Matrix mg = pObj->GetMgn();
                             LONG normCnt = 0;
                             LONG vertCnt = 0;
                             LONG i;
                             for(i=0; i<numNorms; i++)
                                  sadr[normCnt].cnt = 2;
                                  sadr[normCnt++].closed = false;
                                  padr[vertCnt++] = pVerts[i] * mg;
                                  padr[vertCnt++] = (pVerts[i] + (pNormals[i] * splineLen)) * mg;
                             splineOp->GetDataInstance()->SetBool(SPLINEOBJECT_CLOSED,false);
                             GeFree(pNormals); // done with this now
                             BaseDocument *pBaseDoc = pObj->GetDocument();
                             pBaseDoc->InsertObject(splineOp,NULL,NULL);
                             splineOp->Message(MSG_UPDATE);
                        ...just cut/paste that into your code and call the AddNormSplineObject() routine with your PolygonObject. Once you've verified that it's working, you can either use it as-is, or reference it to figure out why yours is not working.
                          On 11/06/2010 at 11:31, xxxxxxxx wrote:
                          If you have any compile errors or trouble with include files, let me know.
                            On 11/06/2010 at 12:08, xxxxxxxx wrote:
                            thank you very much.. after first crash, i passed my doc to the function like this,
                            void AddNormSplineObject(PolygonObject *pObj, LONG splineLen,BaseDocument *doc)
                            and it works.. now i need to understand why it does 🙂
                            again, thank you very very much for your help!
                            ello
                              On 11/06/2010 at 12:14, xxxxxxxx wrote:
                              D'oh! I guess that your PolygonObject wasn't yet attached to the scene :). I usually test all results before using pointers like that, but I kinda threw that in there at the last minute when I was stripping out my old Class member code.
                              Anyway... if you want, you can just use that GetVertexNormals() routine as-is (just be sure to GeFree() the array when you're done with it).
                              Good luck!
                                On 11/06/2010 at 12:18, xxxxxxxx wrote:
                                i now used the pNormals to rotate my clones and now it looks like when i told you how it looked after i used the normalised normals:
                                any idea? how can this be?? i'll have to recheck my code after the rotation. i just dont understand why it works for polygons, but not for points. very strange
                                  On 11/06/2010 at 12:21, xxxxxxxx wrote:
                                  I'd need to see the rest of your code (where/how you are using the normals), but my guess is that it's something to do with the Matrices.
                                    On 11/06/2010 at 12:34, xxxxxxxx wrote:
                                    can i send you the code via mail?
                                      On 11/06/2010 at 13:19, xxxxxxxx wrote:
                                      Sure... typhoon [at] jetbroadband [dot] com
