    Weird Serial Number issue
    16 Posts 0 Posters 2.0k Views
      On 25/01/2010 at 09:59, xxxxxxxx wrote:
      Cinema 4D Version:   11
      I am trying to create an algorthim using the SerialInfo
      this is what I have,   (minus the algorithm of course)
      SerialInfo si;
            String c4dSerial = si.nr;
            LONG mySN = c4dSerial.StringToLong(&err);
            LONG myAlgorithm = THIS THAT OR THE OTHER THING LOL
            String mySerial = LongToString(myAlgorithm);
            GePrint("C4D SERIAL NUMBER IS: " + si.nr);
            GePrint("USER SERIAL IS: " + mySerial);
      FOr some reason the GePrint C4D SERIAL NUMBER IS  is printing out 0.   I am doing this with my registered licensed copy of C4D so I am not sure why this is happening.
      Could anyone shed a little light on this for me?
      ~Shawn
        On 25/01/2010 at 11:28, xxxxxxxx wrote:
        You're missing out a step - you have to get the SerialInfo structure from C4D first:
        SerialInfo si;
        GeGetSerialInfo(SERIAL_CINEMA4D, &si;);
        // then the rest of your code
        Steve
          On 25/01/2010 at 13:25, xxxxxxxx wrote:
          Thank you Steve!
          ~Shawn
            On 25/01/2010 at 14:59, xxxxxxxx wrote:
            okay so here's the code now..
                  LONG err=0;
                  SerialInfo si;
                  GeGetSerialInfo(SERIAL_CINEMA4D, &si);
                  LONG myAlgorithm =  REMOVED
            the problem I am running in to is that the LONG MySN always equals zero.  My guess is that because the serial number is 11 digits, that this is too large for a long.   However, in order to use StringToLong, I need to convert it to a LONG.
            Can anyone think of a way around this?
            ~Shawn
              On 26/01/2010 at 05:05, xxxxxxxx wrote:
              just a side note: it's not recommended to use the whole 11 digits since the first ones represent the C4D version and thus you'd have to create a new s/n for each customer who updates the version.
              It's rather recommended using only the last 5 digits of the sn so maybe you want to use sn.nr.SubStr(6, 5) instead.
              There was a thread around here stating this but I'm unable to find it now...
                On 26/01/2010 at 05:51, xxxxxxxx wrote:
                ...the problem I am running in to is that the LONG MySN always equals zero.  My guess is that because the serial number is 11 digits, that this is too large for a long.   However, in order to use StringToLong, I need to convert it to a LONG.   Can anyone think of a way around this?~Shawn
                I had exactly the same problem. Three possible solutions:
                1. do as Mallard suggests - I hadn't heard this before but it sounds good, so it would be worth looking into.
                2. use a LULONG to hold the result of StringToLong(), which can take the 11 digits - but I couldn't get this to work in the R10 SDK, I don't know why; it worked OK in R11.
                3. split the 11-digit serial string into two parts and check them individually, which is what I did in the end (but method 1 might have saved time!).
                Steve
                  thanks for the info mallard.   I will try that when I get home.
                  ~Shawn
                    On 26/01/2010 at 08:00, xxxxxxxx wrote:
                    And thanks Steve!  🙂   We must have posted at the exact same time because I didn't see your reply until now.  LOL
                      On 26/01/2010 at 15:53, xxxxxxxx wrote:
                      Awesome, thanks guys.   all of your ideas and techniques have led me to a working serial number system..     Now,  I have one last question on this issue.   How do I make the plugin do nothing if the serial number isn't correct?
                      ~Shawn
                        On 27/01/2010 at 01:09, xxxxxxxx wrote:
                        Depends whether you use SNHook or Read/WritePluginInfo
                        In the first case return SN_WRONGNUMBER in the latter case just leave PluginStart() returning FALSE without calling RegisterMyPlugin()
                          On 06/02/2010 at 09:33, xxxxxxxx wrote:
                          So I set the plugin to return SN_WRONGNUMBER and I get the dialog telling me that the serial is not correct,  however, if I simply press cancel from that Dialog, I am able to go in to C4D and my plugin is available.    Does anyone know why this is happening?
                          ~Shawn
                            On 06/02/2010 at 09:49, xxxxxxxx wrote:
                            SOrry..  let me be a bit more specific...
                            Here's the code..
                                  LONG err=0;
                                  SerialInfo si;
                                  LONG mySN = si.nr.SubStr(6,5).StringToLong(&err);
                                  LONG myAlgorithm = **REMOVED**
                                  return sn == mySerial ? SN_OKAY : SN_WRONGNUMBER;
                            When the serial number doesn't match mySerial..  I get the box that says incorrect serial number..  however,  I can just cancel out of that dialog and I am able to access C4D and my plugin is available. .    This is in my full version of C4D..
                            ~Shawn
                              On 07/02/2010 at 09:02, xxxxxxxx wrote:
                              any thoughts on this?
                                On 07/02/2010 at 17:23, xxxxxxxx wrote:
                                Here's all of the code that pertains to the serialization.   Without the algorithm.
                                //SERIAL CODE/////////////////////////////////
                                class PlanetXSerial : public SNHookClass
                                  private:
                                  const String title;
                                  PlanetXSerial() : title("Planet X Generator") {}
                                  virtual LONG SNCheck(const String &c4dsn,const String &sn,LONG regdate,LONG curdate)
                                      LONG err=0;
                                      SerialInfo si;
                                      if (sn == mySerial)
                                          return SN_OKAY;
                                      else
                                          return SN_WRONGNUMBER;
                                          ///return sn == mySerial ? SN_OKAY : SN_WRONGNUMBER;
                                  virtual const String& GetTitle()
                                      return title;
                                PlanetXSerial *snhook = NULL;
                                Bool RegisterPlanetXSerial()
                                  snhook = gNew PlanetXSerial;
                                  return snhook->Register(ID_PLANET_OBJECT_SERIAL, SNFLAG_OWN);
                                  return FALSE;
                                void FreePlanetXSerial()
                                  if (snhook)
                                      gDelete(snhook);
                                And here is the main.cpp
                                // Planet
                                // Starts the plugin registration
                                #include "c4d.h"
                                #include <string.h>
                                // forward declarations
                                Bool RegisterPlanet(void);
                                Bool RegisterSun(void);
                                Bool RegisterSpace(void);
                                Bool RegisterPlanetXSerial();
                                void FreePlanetXSerial();
                                C4D_CrashHandler old_handler;
                                void SDKCrashHandler(CHAR *crashinfo)
                                  // don't forget to call the original handler!!!
                                  if (old_handler) (*old_handler)(crashinfo);
                                void EnhanceMainMenu(void)
                                  // do this only if necessary - otherwise the user will end up with dozens of menus!
                                  if (!(GeGetVersionType()&VERSION_CINEMA4D)) // only if C4D is loaded
                                      return;
                                  BaseContainer *bc = GetMenuResource(String("M_EDITOR"));
                                  if (!bc) return;
                                  // search for the most important menu entry. if present, the user has customized the settings
                                  // -> don't add menu again
                                  if (SearchMenuResource(bc,String("PLUGIN_CMD_1000472")))
                                      return;
                                  GeData *last = SearchPluginMenuResource();
                                  BaseContainer sc;
                                  sc.InsData(MENURESOURCE_SUBTITLE,String("SDK Test"));
                                  sc.InsData(MENURESOURCE_COMMAND,String("IDM_NEU")); // add C4D's new scene command to menu
                                  sc.InsData(MENURESOURCE_SEPERATOR,TRUE);
                                  sc.InsData(MENURESOURCE_COMMAND,String("PLUGIN_CMD_1000472")); // add ActiveObject dialog to menu
                                  if (last)
                                      bc->InsDataAfter(MENURESOURCE_STRING,sc,last);
                                  else // user killed plugin menu - add as last overall entry
                                      bc->InsData(MENURESOURCE_STRING,sc);
                                Bool PluginStart(void)
                                  // example of installing a crashhandler
                                  old_handler = C4DOS.CrashHandler; // backup the original handler (must be called!)
                                  C4DOS.CrashHandler = SDKCrashHandler; // insert the own handler
                                  // Planet Object
                                  if (!RegisterPlanet()) return FALSE;
                                  // Sun Object
                                  if (!RegisterSun()) return FALSE;
                                  // Space Object
                                  if (!RegisterSpace()) return FALSE;
                                  //SERIAL NUMBER
                                  if (!RegisterPlanetXSerial()) return FALSE;
                                  return RegisterPlanet() && RegisterSun() && RegisterSpace();
                                void PluginEnd(void)
                                Bool PluginMessage(LONG id, void *data)
                                  //use the following lines to set a plugin priority
                                  switch (id)
                                      case C4DPL_INIT_SYS:
                                          if (!resource.Init()) return FALSE; // don't start plugin without resource
                                      case C4DPL_ENDACTIVITY:
                                          FreePlanetXSerial(); return TRUE;
                                      case C4DMSG_PRIORITY:
                                      case C4DPL_BUILDMENU:
                                          //EnhanceMainMenu();
                                          break;
                                      case C4DPL_COMMANDLINEARGS:
                                              C4DPL_CommandLineArgs *args = (C4DPL_CommandLineArgs* )data;
                                              LONG i;
                                              for (i=0;i<args->argc;i++)
                                                  if (!args->argv[i]) continue;
                                                  if (!strcmp(args->argv[i],"--help") || !strcmp(args->argv[i],"-help"))
                                                      // do not clear the entry so that other plugins can make their output!!!
                                                      GePrint("\x01-SDK is here :-)");
                                                  else if (!strcmp(args->argv[i],"-SDK"))
                                                      args->argv[i] = NULL;
                                                      GePrint("\x01-SDK executed:-)");
                                                  else if (!strcmp(args->argv[i],"-plugincrash"))
                                                      *((LONG* )0) = 1234;
                                          break;
                                      case C4DPL_EDITIMAGE:
                                              GePrint("Something Changed");
                                              C4DPL_EditImage *editimage = (C4DPL_EditImage* )data;
                                              if (!data) break;
                                              if (editimage->return_processed) break;
                                              GePrint("C4DSDK - Edit Image Hook: "+editimage->imagefn->GetString());
                                              // editimage->return_processed = TRUE; if image was processed
                                          return FALSE;
                                  return FALSE;
                                I'm a bit frustrated because I can't see why the user would be able to see the plugin when the serial number is not valid.  If I start up C4D I get a message that say's WRONG SERIAL NUMBER for PLanet X Generator.    Then I click cancel to bypass the serial number dialog and I go in to C4D and I am still able to use the plugin.
                                This is all I lack to finish before the release of my plugin so you can imagine my frustration that this is not playing nice.  Does anyone see anything wrong with my code?
                                Thanks a million to the person who solves this and I will owe you a large PINT.
                                ~Shawn
                                  On 08/02/2010 at 06:01, xxxxxxxx wrote:
                                  The SNHookClass will not prevent automatically the loading of plugins if a wrong or empty keyis entered. It only establishes a hook to the Personalize dialog. You have to check for the key independently from the dialog.
                                  here is an example that illustrates this:
                                  main.cpp
                                  #include "c4d.h"
                                  Bool RegisterExampleSNHook();
                                  void FreeExampleSNHook();
                                  Bool IsSerialOKExampleHook();
                                  Bool RegisterMenuTest(void);
                                    if (!IsSerialOKExampleHook()) return FALSE; //don't load plugins if key is wrong
                                    if (!RegisterMenuTest()) return FALSE;
                                    switch (id)
                                            // important, the serial hook must be registered before PluginStart(), best in C4DPL_INIT_SYS
                                            if (!RegisterExampleSNHook()) return FALSE;
                                    return FALSE;
                                  serial_hook.cpp
                                  #include "c4d_resource.h"
                                  #include "lib_sn.h"
                                  #include "c4d_symbols.h"
                                  class ExampleSNHookClass : public SNHookClass
                                        ExampleSNHookClass()
                                            name = GeLoadString(IDS_SERIAL_HOOK);
                                            if(!name.Content())
                                                name = "C++ SDK - Example Serial Hook";
                                            sn_ok = FALSE;
                                            if (sn.Content() && sn == String("123456789-abcdef"))
                                                sn_ok = TRUE;
                                                return SN_OKAY;
                                            sn_ok = FALSE;
                                            return name;
                                        Bool IsSerialOK() const { return sn_ok; }
                                    private:
                                        String name;
                                        Bool sn_ok;
                                  ExampleSNHookClass *snhook = NULL;
                                    snhook = gNew ExampleSNHookClass;
                                    if (!snhook->Register(450000241, SNFLAG_OWN))
                                        return FALSE;
                                    if (snhook)
                                        gDelete(snhook);
                                    if (snhook)
                                        return snhook->IsSerialOK();
                                    return FALSE;
                                    On 08/02/2010 at 06:30, xxxxxxxx wrote:
                                    Thanks a million Matthias.    You've saved me yet again!   I truly appreciate your efforts here at the plugin cafe.    Top notch!
                                    ~Shawn
