    Receiving Plugin Messages
    7 Posts 0 Posters 675 Views
      On 29/12/2009 at 14:25, xxxxxxxx wrote:
      Cinema 4D Version:   11+
      I have two plugins I am trying to get to talk to each other. I have a command plugin that needs to draw to the editor when the user toggles a button. I am using a SceneHookData plugin to accomplish the actual drawing. So, I want to send a message to the SceneHook to tell it what state the toggle button is in to activate the drawing in the Draw function.
      I can successfully pass the message from my Command Plugin to main.cpp, but my question is how to get this information into my SceneHookData plugin. How can I receive that message inside the SceneHookData?
      Thanks!
        On 30/12/2009 at 02:21, xxxxxxxx wrote:
        With BaseDocument::FindSceneHook(PluginID) you can get your scene hook and change for instance a value in its BaseContainer according to toggle button. In the scene hooks draw function read out the container value. You can trigger a redraw from within the CommandData with DrawViews().
          On 30/12/2009 at 09:13, xxxxxxxx wrote:
          I would rather use a message data plugin and use SpecialEventAdd to send out a message to all plugins and accordingly catch the message and react (fcourse you should also be able to catch the message in a SHP). Just an idea.
            On 30/12/2009 at 19:10, xxxxxxxx wrote:
            Great. Thanks for the suggestions!
              On 06/07/2010 at 01:15, xxxxxxxx wrote:
              "With BaseDocument::FindSceneHook(PluginID) you can get your scene hook and change for instance a value in its BaseContainer"
              could someone give a bit more info on this? maybe how it looks in code.
              thanks alot
                On 07/07/2010 at 03:27, xxxxxxxx wrote:
                Here is a little example how to change a container value for a scene hook from within a CommandData plugin for example.
                PluginSceneHook *sh = doc->FindSceneHook(ID_MYSCENEHOOK);
                if (sh)
                  BaseContainer *data = sh->GetDataInstance();
                  data->SetLong(MYSCENEHOOK_VALUE, 100);
                  EventAdd();
                  On 08/07/2010 at 16:54, xxxxxxxx wrote:
                  Thanks!
