    Creating Spheres
    31 Posts 0 Posters 17.2k Views
      On 12/11/2009 at 19:54, xxxxxxxx wrote:
      // supposing that we're looking for the surfaceMat
      for (BaseMaterial* mat = doc->GetFirstMaterial(); mat; mat = mat->GetNext())
           if (mat->GetName() == "whatever")
                surfaceMat = static_cast<Material*>(mat);
                break;
        On 13/11/2009 at 06:49, xxxxxxxx wrote:
        great thanks Robert...
        Now I need to change the fresnel settings of the color channel on a material.    so I am trying to use
        atmosphereMat->SetParameter(MATERIAL_COLOR_SHADER,?,NULL);
        But i am not sure what to put in the ? part....     or do I need to use a different constant other than MATERIAL_COLOR_SHADER?
        ~Shawn
          On 13/11/2009 at 15:48, xxxxxxxx wrote:
          I would expect that you should be able to get away with:
          atmosphereMat->SetParameter(MATERIAL_COLOR_SHADER,GeData(shader),NULL);
          where shader is a pointer to the shader being added to the SHADERLINK.
            On 13/11/2009 at 15:53, xxxxxxxx wrote:
            so would that shader be (Xfresnel) ?
            ~Shawn
              On 13/11/2009 at 16:01, xxxxxxxx wrote:
              This is what I tried.. and I still get nothing in the TEXTURE field of the Color Channel.
              atmosphereMat->SetParameter(MATERIAL_COLOR_SHADER,GeData(Xfresnel),NULL);
              Any other thoughts?
              Thanks a lot for your help. 🙂
              ~Shawn
                On 13/11/2009 at 16:04, xxxxxxxx wrote:
                No, I think it will need to be an actual allocated shader:
                PluginShader* shader = PluginShader::Alloc(Xfresnel);
                Also, there is another way from c4d_basechannel using HandleShaderPopup(). No experience with it though.
                  On 13/11/2009 at 16:08, xxxxxxxx wrote:
                  I will try it out and let you know.
                  Thanks again Robert.
                  ~Shawn
                    On 13/11/2009 at 16:14, xxxxxxxx wrote:
                    declared with ...
                    PluginShader* fresnel = PluginShader::Alloc(Xfresnel);
                    then used ...
                    atmosphereMat->SetParameter(MATERIAL_COLOR_SHADER,GeData(fresnel),NULL);
                    and got this error..
                    c:\users he fosters\desktop\cinema4dr11010\plugins\#planet\source\object\planet.cpp(318) : error C2440: '<function-style-cast>' : cannot convert from 'PluginShader *' to 'GeData'
                    2>        No constructor could take the source type, or constructor overload resolution was ambiguous
                      On 13/11/2009 at 16:53, xxxxxxxx wrote:
                      You might want to try going through the BaseContainer then:
                      atmosphereMat->GetDataInstance()->SetLink(MATERIAL_COLOR_SHADER, fresnel);
                      GeData() can't handle general pointers (only BaseLink* ).
                        On 13/11/2009 at 17:11, xxxxxxxx wrote:
                        hmmm... well it comiles fine but still nothing shows up in the texture field.... that stinks.
                        ~Shawn
                          On 13/11/2009 at 17:49, xxxxxxxx wrote:
                          I think you may be stuck with HandleShaderPopup() then. I couldn't find anything here, in the docs, or in the cinema4dsdk that describes how to set a channel shader.
                          It is also possible that you need to insert the shader into the material:
                          atmosphereMat->InsertShader(fresnel, NULL);
                          Then try to set the link. Again, I don't see any examples or more explicit information on this.
                            that worked,,    WOO HOO!    Now I jus tneed to figure out how to change the colors in the shader..   LOL...
                            Thanks a million Robert.
                            ~Shawn
                              On 13/11/2009 at 19:54, xxxxxxxx wrote:
                              LOL.. okay so after a few hours of searching a trying, I am at somewhat of a loss again..   How would I change the color of the knots that are in the fresnel shader?
                              ~Shawn
                                On 13/11/2009 at 20:38, xxxxxxxx wrote:
                                Here's what I have so far..   This inserts the fresnel shader in to the material for both the color channel and the transparency channel.   And with the current code it completely removes the color knots from the gradient in both fresnel shaders. So I feel like I'm on the right track.. any help would be greatly appreciated. 🙂
                                          atmosphereMat->InsertShader(fresnelColor, NULL);
                                          atmosphereMat->InsertShader(fresnelTrans, NULL);
                                          atmosphereMat->GetDataInstance()->SetLink(MATERIAL_COLOR_SHADER, fresnelColor);
                                          atmosphereMat->GetDataInstance()->SetLink(MATERIAL_TRANSPARENCY_SHADER, fresnelTrans);
                                          fresnelColor->SetParameter(SLA_FRESNEL_GRADIENT,ATMOSPHERIC_COLOR, 0);
                                          fresnelTrans->SetParameter(SLA_FRESNEL_GRADIENT,Vector (0,0,0), 1);
                                  On 15/11/2009 at 07:25, xxxxxxxx wrote:
                                  Does anyone know how I would add color knots to the gradient in the fresnel shader that I have added with the above code?
                                  ~Shawn
