    Creating Spheres
    31 Posts 0 Posters 16.6k Views
      On 10/11/2009 at 20:28, xxxxxxxx wrote:
      Here's what I have so far.. Everything is doing what I want and almost everything is going well..   My problem is, when I try to delete the object or when I click on any control other than ENABLE_ATMOSPHERE, C4D freezes up and crashed..   Can anyone tell me why this is happening?
      Here's my code
      // Planet
      #include "c4d.h"
      #include "c4d_symbols.h"
      #include "oplanet.h"
      #include "c4d_basetag.h"
      #include "c4d_basematerial.h"
      #define ID_PLANET_OBJECT 1024532
      class Planet : public ObjectData
                virtual Bool GetDEnabling(GeListNode *node, const DescID &id;,GeData &t;_data,LONG flags,const BaseContainer *itemdesc);
                virtual Bool Message(GeListNode *node, LONG type, void *t_data);
                          Bool CreatePlanet(DescriptionCommand* dc, BaseObject* op);
                          Bool UpdatePlanet(DescriptionCommand* dc, BaseObject* op);
                          static NodeData *Alloc(void) { return gNew Planet;}
                TextureTag* surfaceTextTag;
                TextureTag* cloudsTextTag;
                TextureTag* atmTextTag;
                BaseObject* surface;
                Material* surfaceMat;
                BaseObject* clouds;
                Material* cloudsMat;
                BaseObject* atmosphere;
                Material* atmosphereMat;
                Bool planetCreated;
                LONG test;
      // initialize settings
      Bool Planet::Init(GeListNode *node)
      {     //Called when a new instance of the node plugin has been allocated. You can use this function to for example fill the BaseContainer of the connected node with default values:
           BaseContainer* bc = ((BaseObject* )node)->GetDataInstance();
           if (!bc)
           return false;
           bc->SetBool(ENABLE_CRATERS, TRUE);
           bc->SetBool(ENABLE_ATMOSPHERE, TRUE);
           bc->SetBool(HAS_RINGS, FALSE);
           planetCreated = FALSE;
           test = 0;
      Bool Planet::GetDEnabling(GeListNode *node, const DescID &id;,GeData &t;_data,LONG flags,const BaseContainer *itemdesc)
           // Enable/disable our parameters
           BaseContainer *bc=((BaseList2D* )node)->GetDataInstance();
           BaseObject* op = static_cast<BaseTag*>(node)->GetObject();
           switch (id[0].id)
                case SURFACE_PRESETS:
                     if (op)
                     {     if (bc->GetBool(USE_PRESET)==TRUE)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case CRATER_AMOUNT:
                     if (op)
                     {     if (bc->GetBool(ENABLE_CRATERS)==TRUE&&bc-;>GetBool(USE_PRESET)==FALSE)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case CRATER_SIZE:
                     if (op)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case SURFACE_MAP:
                     if (op)
                     {     if (bc->GetBool(USE_PRESET)==FALSE)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case ELEVATION_MAP:
                     if (op)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case ELEVATION_STRENGTH:
                     if (op)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case ENABLE_CRATERS:
                     if (op)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case CLOUD_MAP:
                     if (op)
                     {     if (bc->GetBool(USE_PRESET2)==FALSE)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case CLOUD_BRIGHTNESS:
                     if (op)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case CLOUD_THICKNESS:
                     if (op)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case CLOUD_PRESETS:
                     if (op)
                     {     if (bc->GetBool(USE_PRESET2)==TRUE)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case ATMOSPHERIC_COLOR:
                     if (op)
                     {     if (bc->GetBool(ENABLE_ATMOSPHERE)==TRUE)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case ATMOSPHERIC_BRIGHTNESS:
                     if (op)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case ATMOSPHERIC_GLOW:
                     if (op)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case RING_COLOR:
                     if (op)
                     {     if (bc->GetBool(HAS_RINGS)==TRUE)
                     {    return TRUE;
                     else
                     {    return FALSE;
                case CREATE_PLANET:
                     if (op)
                     {     if (planetCreated == FALSE)
                     {    return TRUE;
                     else
                     {    return FALSE;
      Bool Planet::Message(GeListNode *node, LONG type, void *t_data)
           if (!node)     return FALSE;
           if (type == MSG_DESCRIPTION_COMMAND)
                return CreatePlanet(static_cast<DescriptionCommand*>(t_data), static_cast<BaseObject*>(node));
            if (type == MSG_DESCRIPTION_CHECKUPDATE)
                 return UpdatePlanet(static_cast<DescriptionCommand*>(t_data), static_cast<BaseObject*>(node));
      Bool Planet::CreatePlanet(DescriptionCommand* dc, BaseObject* op)
          if (!dc)
           if (!op)
                return FALSE;
          LONG id =     dc->id[0].id;
                //declarations
                surfaceTextTag = TextureTag::Alloc();
                cloudsTextTag = TextureTag::Alloc();
                atmTextTag = TextureTag::Alloc();
                atmosphere = BaseObject::Alloc(Osphere);
                atmosphereMat = Material::Alloc();
                clouds = BaseObject::Alloc(Osphere);
                cloudsMat = Material::Alloc();
                surface = BaseObject::Alloc(Osphere);
                surfaceMat = Material::Alloc();
                BaseDocument* doc = op->GetDocument();
                doc->StartUndo();
                if (!doc)
                     return FALSE;
                BaseObject* prnt = doc->GetActiveObject();
                BaseTag* tp = BaseTag::Alloc(Tphong);
           //If Create Planet button is pressed...
           if (id == CREATE_PLANET)
          /////////create the atmosphere sphere//////////////////////////////////////////////////////
                atmosphere->SetName("Atmosphere");
                atmosphereMat->SetName ("Atmosphere");
                atmosphere->SetParameter(PRIM_SPHERE_RAD,200.8,NULL);
          /////////create and insert the clouds sphere///////////////////////////////////////////////
                clouds->SetName("Clouds");
                cloudsMat->SetName ("Clouds");
                clouds->SetParameter(PRIM_SPHERE_RAD,200.4,NULL);
                clouds->InsertTag(tp,0);//phong tag
                clouds->InsertTag(cloudsTextTag,0);
                cloudsTextTag->SetMaterial(cloudsMat);
                doc->InsertMaterial(cloudsMat,NULL,TRUE);
                if (clouds) doc->InsertObject(clouds, prnt, NULL, FALSE);
                GePrint("Clouds Created");
          /////////create and insert the surface sphere///////////////////////////////////////////////
                surface->SetName("Surface");
                surfaceMat->SetName ("Surface");
                surface->SetParameter(PRIM_SPHERE_RAD,200,NULL);
                surface->InsertTag(tp,0);//phong tag
                surface->InsertTag(surfaceTextTag,0);
                surfaceTextTag->SetMaterial(surfaceMat);
                doc->InsertMaterial(surfaceMat,NULL,TRUE);
                if (surface) doc->InsertObject(surface, prnt, NULL, FALSE);
                GePrint("Surface Created");
                //A planet was created
                planetCreated = TRUE;
              doc->EndUndo();
      Bool Planet::UpdatePlanet(DescriptionCommand* dc, BaseObject* op)
               if (!dc)
                if (!op)
                     return FALSE;
                doc->StartUndo();
                if (!doc)
                     return FALSE;
           //Enable-Disable Atmosphere/////////////////////////////////////////////////////////
           if (op->GetDataInstance()->GetBool(ENABLE_ATMOSPHERE)==TRUE)
                atmosphere->InsertTag(tp,0); //phong tag
                atmosphere->InsertTag(atmTextTag,0);
                atmTextTag->SetMaterial(atmosphereMat);
                doc->InsertMaterial(atmosphereMat,NULL,TRUE);
                if (atmosphere) doc->InsertObject(atmosphere, prnt, NULL, FALSE);
                GePrint("Atmosphere Created");
                atmosphereMat->SetChannelState(CHANNEL_TRANSPARENCY,TRUE);
                atmosphereMat->SetChannelState(CHANNEL_GLOW,TRUE);
                atmosphereMat->Update(TRUE,TRUE);
                GePrint("Atmosphere Enabled");
           else
                atmosphereMat->SetChannelState(CHANNEL_GLOW,FALSE);
                GePrint("Atmosphere Disabled");
                if (atmosphere) atmosphere->Remove();
                if (atmosphereMat) atmosphereMat->Remove();
                if (atmTextTag) atmTextTag->Remove();
           atmosphereMat->SetParameter(MATERIAL_GLOW_OUTERSTRENGTH,op->GetDataInstance()->GetReal(ATMOSPHERIC_BRIGHTNESS),NULL);
      Bool RegisterPlanet(void)
           // decide by name if the plugin shall be registered - just for user convenience
           GePrint("-----------------------------------------------------------------------------------------");
           GePrint("Planet X Generator 1.0 - Copyright 2009 - Shawn Foster");
           String name=GeLoadString(IDS_PLANET_OBJECT); if (!name.Content()) return TRUE;
           return RegisterObjectPlugin(ID_PLANET_OBJECT,name,OBJECT_GENERATOR|OBJECT_INPUT,Planet::Alloc,"oplanet","Planet.tif",0);
      Thanks in advance....
      ~Shawn
        On 12/11/2009 at 09:23, xxxxxxxx wrote:
        Does anyone see any problems that would cause C4D to crash in my code?
        ~Shawn
          On 12/11/2009 at 11:43, xxxxxxxx wrote:
          I'd do it this way. Note the allocation checks, checks for existence, and the check for 'doc' before doc->StartUndo(). Also, not sure if this is your intention, but once you remove the objects from the document, if they are no longer necessary, you still need to free them - otherwise subsequent allocations into those pointers will leave unfreed/unreferenced objects in memory!
          Unfortunately, this is one reason that I don't have a great love of C/C++ - the programmer takes control of all memory management as well as tracking pointer validation.
          // Planet
          #include "c4d.h"
                    BaseObject* clouds;
                    Bool planetCreated;
                    LONG test;
               if (!bc)     return false;
               test = 0;
               if (!op)          return FALSE;
               switch (id[0].id)
                         return bc->GetBool(USE_PRESET);
                    case CRATER_AMOUNT:
                         if (bc->GetBool(ENABLE_CRATERS)&&!bc->GetBool(USE_PRESET))     return TRUE;
                    case CRATER_SIZE:
                    case SURFACE_MAP:
                         return !bc->GetBool(USE_PRESET);
                    case ELEVATION_MAP:
                    case CLOUD_MAP:
                         return !bc->GetBool(USE_PRESET2);
                    case CLOUD_PRESETS:
                         return bc->GetBool(USE_PRESET2);
                         return bc->GetBool(ENABLE_ATMOSPHERE);
                    case RING_COLOR:
                         return bc->GetBool(HAS_RINGS);
                    case CREATE_PLANET:
                         return !planetCreated;
               if (!dc)      return TRUE;
               //declarations
               if (!surfaceTextTag)     return FALSE;
               if (!cloudsTextTag)     return FALSE;
               if (!atmTextTag)     return FALSE;
               if (!atmosphere)     return FALSE;
               if (!atmosphereMat)     return FALSE;
               if (!clouds)     return FALSE;
               if (!cloudsMat)     return FALSE;
               if (!surface)     return FALSE;
               if (!surfaceMat)     return FALSE;
               if (!doc)     return FALSE;
               doc->StartUndo();
               if (!tp)          return FALSE;
                    doc->EndUndo();
               doc->StartUndo();
                    if (atmTextTag)
                         if (atmosphere)     atmosphere->InsertTag(atmTextTag,0);
                    if (atmosphereMat)
                    if (atmosphere)
               else
                    if (atmosphereMat)
               if (atmosphereMat)     atmosphereMat->SetParameter(MATERIAL_GLOW_OUTERSTRENGTH,op->GetDataInstance()->GetReal(ATMOSPHERIC_BRIGHTNESS),NULL);
            On 12/11/2009 at 12:14, xxxxxxxx wrote:
            I also notice that there is no doc->EndUndo() in UpdatePlanet() and no AddUndo()s either. Maybe you should comment out the doc->StartUndo() until it is needed.
              On 12/11/2009 at 15:53, xxxxxxxx wrote:
              Thanks Robert,,, I have decided that in the UpdatePlanet function I am going to use GetDown, GetNext, and GetFirstMaterial to reference the materials and objects in the scene.
              I am running in to one problem though...
              The GetFirstMaterial() function is derived from the BaseMaterial, but my materials are from the Material Class.. Is it possible to use GetFirstMaterial on materials from the Material class?
              ~Shawn
                On 12/11/2009 at 16:14, xxxxxxxx wrote:
                You should be able to up-cast the BaseMaterial* returned by GetFirstMaterial() to Material* without any issues. Just use a C cast (Material* ) or a C++ one static_cast_<_material*_>_
                  On 12/11/2009 at 19:38, xxxxxxxx wrote:
                  Could you give me a code snippet of how that would look?
                  ~Shawn
                    On 12/11/2009 at 19:54, xxxxxxxx wrote:
                    // supposing that we're looking for the surfaceMat
                    for (BaseMaterial* mat = doc->GetFirstMaterial(); mat; mat = mat->GetNext())
                         if (mat->GetName() == "whatever")
                              surfaceMat = static_cast<Material*>(mat);
                              break;
                      On 13/11/2009 at 06:49, xxxxxxxx wrote:
                      great thanks Robert...
                      Now I need to change the fresnel settings of the color channel on a material.    so I am trying to use
                      atmosphereMat->SetParameter(MATERIAL_COLOR_SHADER,?,NULL);
                      But i am not sure what to put in the ? part....     or do I need to use a different constant other than MATERIAL_COLOR_SHADER?
                      ~Shawn
                        On 13/11/2009 at 15:48, xxxxxxxx wrote:
                        I would expect that you should be able to get away with:
                        atmosphereMat->SetParameter(MATERIAL_COLOR_SHADER,GeData(shader),NULL);
                        where shader is a pointer to the shader being added to the SHADERLINK.
                          On 13/11/2009 at 15:53, xxxxxxxx wrote:
                          so would that shader be (Xfresnel) ?
                          ~Shawn
                            On 13/11/2009 at 16:01, xxxxxxxx wrote:
                            This is what I tried.. and I still get nothing in the TEXTURE field of the Color Channel.
                            atmosphereMat->SetParameter(MATERIAL_COLOR_SHADER,GeData(Xfresnel),NULL);
                            Any other thoughts?
                            Thanks a lot for your help. 🙂
                            ~Shawn
                              On 13/11/2009 at 16:04, xxxxxxxx wrote:
                              No, I think it will need to be an actual allocated shader:
                              PluginShader* shader = PluginShader::Alloc(Xfresnel);
                              Also, there is another way from c4d_basechannel using HandleShaderPopup(). No experience with it though.
                                On 13/11/2009 at 16:08, xxxxxxxx wrote:
                                I will try it out and let you know.
                                Thanks again Robert.
                                ~Shawn
                                  On 13/11/2009 at 16:14, xxxxxxxx wrote:
                                  declared with ...
                                  PluginShader* fresnel = PluginShader::Alloc(Xfresnel);
                                  then used ...
                                  atmosphereMat->SetParameter(MATERIAL_COLOR_SHADER,GeData(fresnel),NULL);
                                  and got this error..
                                  c:\users he fosters\desktop\cinema4dr11010\plugins\#planet\source\object\planet.cpp(318) : error C2440: '<function-style-cast>' : cannot convert from 'PluginShader *' to 'GeData'
                                  2>        No constructor could take the source type, or constructor overload resolution was ambiguous
                                    On 13/11/2009 at 16:53, xxxxxxxx wrote:
                                    You might want to try going through the BaseContainer then:
                                    atmosphereMat->GetDataInstance()->SetLink(MATERIAL_COLOR_SHADER, fresnel);
                                    GeData() can't handle general pointers (only BaseLink* ).
                                      On 13/11/2009 at 17:11, xxxxxxxx wrote:
                                      hmmm... well it comiles fine but still nothing shows up in the texture field.... that stinks.
                                      ~Shawn
                                        On 13/11/2009 at 17:49, xxxxxxxx wrote:
                                        I think you may be stuck with HandleShaderPopup() then. I couldn't find anything here, in the docs, or in the cinema4dsdk that describes how to set a channel shader.
                                        It is also possible that you need to insert the shader into the material:
                                        atmosphereMat->InsertShader(fresnel, NULL);
                                        Then try to set the link. Again, I don't see any examples or more explicit information on this.
                                          that worked,,    WOO HOO!    Now I jus tneed to figure out how to change the colors in the shader..   LOL...
                                          Thanks a million Robert.
                                          ~Shawn
                                            On 13/11/2009 at 19:54, xxxxxxxx wrote:
                                            LOL.. okay so after a few hours of searching a trying, I am at somewhat of a loss again..   How would I change the color of the knots that are in the fresnel shader?
                                            ~Shawn
