    vd->lhit.GetPolygon() and RenderInstances
    5 Posts 0 Posters 404 Views
      On 05/10/2009 at 12:49, xxxxxxxx wrote:
      Cinema 4D Version:   r11.5
      Hi there,
      after compiling my plugin for r11.5 and using render instances i found that vd->lhit.GetPolygon() doesnt work with renderinstances (i guess thats just because of what renderinstances are).. is there a way to get something similar information from those renderinstances??
      thanks,
      ello
        On 06/10/2009 at 01:23, xxxxxxxx wrote:
        What do you mean with it doesn't work? Render instances give back the same polygon ID as the instanced object.
          On 06/10/2009 at 12:04, xxxxxxxx wrote:
          hi, sorry for being not precise enough.. I have a shader which is changing the color for every polygon.
          i used this line:
          LONG id = vd->lhit.GetPolygon();
          it workes as long as i use normal instances but when i set the INSTANCEOBJECT_RENDERINSTANCE for those instances, it doesnt work anymore.. all instances have the same colors for the according faces...
          hope you understand
          ello
            On 07/10/2009 at 00:23, xxxxxxxx wrote:
            Ah, ok. That is a limitation. Render instances point all to the same polygons.
              On 08/10/2009 at 02:01, xxxxxxxx wrote:
              ok, thanks for clearing this
              Ello
