    crash after moving timeline
    14 Posts 0 Posters 976 Views
      On 14/09/2009 at 08:53, xxxxxxxx wrote:
      Cinema 4D Version:   R11
      Language(s) :     C++  ;  XPRESSO  ;
      i wrote a xpresso node to write converted C4D-Geometry in the geo-file-format. The node works fine and the node only executes if, the geometry is "dirty" (dirtycount has changed). Now my problem. If the frame changes, the system crashs.
      At the moment i don't understand the context between the operations in the Calculation-method and the timeline. Is every frame treated like a own scene or "instance" and so i need for every frame a new thread and have to synchronize them???
      Oli
        On 15/09/2009 at 03:13, xxxxxxxx wrote:
        To write the data in the geo-file, i use the C++-STL ofstream instead of the hyperflile class.
        Could this cause the crash?
        Oli
          On 15/09/2009 at 03:21, xxxxxxxx wrote:
          Are you writing files during realtime playback?
          Also if possible post some simplified code.
            On 15/09/2009 at 05:01, xxxxxxxx wrote:
            It should write during realtime playback (to save whole sequences) or after manual frame change.
            So here is some code
            > <code>
            > //Calculate
            > Bool AixWrite::Calculate(GvNode *bn, GvPort *port, GvRun *run, GvCalc *calc){
            >      BaseContainer* data = bn->GetOpContainerInstance();
            >      if(!data){
            >           //gib FALSE zurueck
            >           return FALSE;
            >         //own Geometrystructure (Cinema4D-Objects can be converted to
            >         //this one)-->works
            >         AixGeometry toWrite = AixGeometry();
            >        GeData inputFilename = GeData();
            >        toWrite = *(AixGeometry* ) AixGvCheckAndGetPortGeData(bn, port, run, calc, ports, GVAIXWRITE_INPUT_GEOMETRY_INDEX).GetCustomDataType(CUSTOMDATATYPE_AIXGEOMETRY);
            >      inputFilename = AixGvCheckAndGetPortGeData(bn, port, run, calc, ports, GVAIXWRITE_INPUT_FILENAME_INDEX);
            >         //get actual frame
            >      BaseDocument* doc = bn->GetDocument();
            >      BaseTime time = doc->GetTime();
            >      LONG fps = doc->GetFps();
            >      LONG frame = time.GetFrame(fps);
            > //if DirtyCount is not equal or frame changed, then write geo-File
            >      if(toWrite.GetDirtyCount() != this->inputPorts[0].GetLong() || frame != this->currenFrame){
            >                //cashes the data
            >           this->inputPorts[0].SetLong(toWrite.GetDirtyCount());
            >           this->currenFrame = frame;
            >           if(on){
            >                //FileStream
            >                ofstream out;
            >                //Wenn eine Pfadangabe vorliegt
            >                if(inputFilename != GeData(NOTOK)){
            >                     //open FileStream
            >                              out.open(inputFilename.GetFilename().
            >                              GetString().GetCStringCopy());
            >                else if(inputFilename == GeData(NOTOK)){
            >                     return FALSE;
            >                //geo-File
            >                out << "PGEOMETRY V5" << endl;
            >                //if there are polys
            >                if(!toWrite.GetNgonArray().empty()){
            >                     //write
            >                     out << "NPoints " << toWrite.GetPointArray().size() << " NPrims " << toWrite.GetNgonArray().size() << endl;
            >                //only points
            >                else{
            >                     out << "NPoints " << toWrite.GetPointArray().size() << " NPrims 0" << endl;
            >                out << "NPointGroups 0 NPrimGroups 0" << endl;
            >                       //write points, polys etc........
            >                out << "beginExtra" << endl;
            >                out << "endExtra" << endl;
            >                //close FilesStream
            >                out.close();
            >      return TRUE;
            > </code>
            Oli
              On 15/09/2009 at 07:02, xxxxxxxx wrote:
              One additional question.
              What is the ident-parameter in the hyperfile Open-method and what have i to declare?
              Oli
                On 16/09/2009 at 05:42, xxxxxxxx wrote:
                New approach.
                I use now the Cinema4D-BaseFile to write the geo-file. As i thought, the STL causes the crash. So far so godd, but now i have an new problem.
                In one line of the geo-file Cinema writes a number previous to the entry.
                > <code>
                > AutoAlloc<BaseFile> bf;
                >           if(on){
                >                     bf->Open(inputFilename.GetFilename().GetString(), GE_WRITE, 0, 0, 0, 0);
                >             bf->WriteString("PGEOMETRY V5\n");
                >                 bf->WriteString("NPoints " + LongToString(toWrite.GetPointArray().size()) + " NPrims " + LongToString(toWrite.GetNgonArray().size()) + "\n");
                >                else{
                >                     bf->WriteString("NPoints " + LongToString(toWrite.GetPointArray().size()) + " NPrims 0\n");
                >                bf->WriteString("NPointGroups 0 NPrimGroups 0\n");
                >                bf->WriteString("NPointAttrib " + LongToString(toWrite.GetAixAttributeArray(AIXPOINT).size()) + " NVertexAttrib " + LongToString(toWrite.GetAixAttributeArray(AIXNLINE).size()) + " NPrimAttrib " + LongToString(toWrite.GetAixAttributeArray(AIXNGON).size()) + " NAttrib 1\n");
                > bf->Close();
                > </code>
                This is a snip of what i get:
                PGEOMETRY V5
                NPoints 8 NPrims 6
                8NPointAttrib 0 NVertexAttrib 0 NPrimAttrib 0 NAttrib 1
                Why is there number 8 in front of NPointAttrib
                Thanks, Oli
                  On 16/09/2009 at 05:52, xxxxxxxx wrote:
                  To write ASCII text files I usally use my own WriteString function since the BaseFile::WriteString() seems a bit strange to me.
                  My own WriteString()
                  > \> Bool WriteString(const String line, BaseFile\* file) \> { \>      if(!file) return FALSE; \> \>      CHAR \*charline = NULL; \>      LONG strlength = line.GetCStringLen(St7bithex); \>      charline = (CHAR\* )GeAlloc(strlength+1); \> \>      if(!charline) return FALSE; \> \>      strlength = line.GetCString(charline, strlength+1, St7bithex); \> \>      LONG i; \>      for(i=0; i<strlength; i++) \>      { \>           if(!file->WriteChar(charline[i])) return FALSE; \>      } \> \>      GeFree(charline); \>       \>      return TRUE; \> } \>
                  > \> Bool BaseFile::WriteString(const String &v;) \> { \>      Bool ok; \>      LONG len = v.GetCStringLen()+1; \>      CHAR \*mem = (CHAR\* ) GeAlloc(sizeof(CHAR)\*len); \>      if (!mem) \>      { \>           SetError(FILEERROR_MEMORY); \>           return FALSE; \>      } \> \>      v.GetCString(mem,len); \>      ok = WriteLong(len) && WriteBytes(mem,len); \>      GeFree(mem); \> \>      return ok; \> } \>
                    On 16/09/2009 at 06:13, xxxxxxxx wrote:
                    Thanks Matthias, your WriteString() works fine and solves my problem.
                    Oli
                      On 17/09/2009 at 07:22, xxxxxxxx wrote:
                      Now i have nearly the same problem as before. But now i can change the frame on teh timeline between 3 and 11 times before the system crahs.
                      I thought it crahs during the calculation. But the node calculates and writes a "perfect" geo-file and then the system cashs.
                      Any ideas?
                      Oli
                        On 18/09/2009 at 07:02, xxxxxxxx wrote:
                        no ideas or a guess? i am glad about every proposal.
                        cheers Oli
                          On 18/09/2009 at 07:07, xxxxxxxx wrote:
                          Sorry, I had not the time yet to dig deeper into it. Does this only happen from within a XPresso node? What about expressions or generators? This may be something to look into. I will try to find a solution but I have to discuss this with our developers.
                            On 18/09/2009 at 07:20, xxxxxxxx wrote:
                            It happens only in this XPresso Node. The other nodes works fine if i change the frame on the timeline. My generator works too.
                            Thanking you in anticipation,
                            Oli
                              On 21/09/2009 at 06:33, xxxxxxxx wrote:
                              Ok, I tried to confirm this. I am not sure if the problem is really in the node. Here is the code of a simple node that writes out geometry of a polygon object. It seems to work fine without any crashes. Maybe this helps.
                              > \> #include "c4d.h" \> #include "c4d_operatordata.h" \> \> #include "print_node.h" \> \> \> class PrintNode : public GvOperatorData \> { \>           INSTANCEOF(PrintNode,GvOperatorData) \> \>      private: \>           BaseList2D \*result; \>           GvValue \*v1; \>                 \>      public: \>           virtual Bool Init(GeListNode \*node); \> \>           virtual const String     GetDetailedText(GvNode \*bn); \>           virtual const String     GetText(GvNode \*bn); \> \>           virtual Bool               iCreateOperator(GvNode \*bn); \> \>           virtual Bool               AddToCalculationTable(GvNode \*bn, GvRun \*r); \> \>           virtual Bool               InitCalculation(GvNode \*bn, GvCalc \*c, GvRun \*r); \>           virtual void               FreeCalculation(GvNode \*bn, GvCalc \*c); \>           virtual Bool               Calculate(GvNode \*bn, GvPort \*port, GvRun \*r, GvCalc \*c); \> \>           static NodeData\*          Alloc(void) { return gNew PrintNode; } \> }; \> \> Bool PrintNode::Init(GeListNode \*node) \> { \>      result = NULL; \>      return TRUE; \> } \> \> Bool PrintNode::iCreateOperator(GvNode \*bn) \> { \>      bn->SetShowPortNamesState(FALSE); \>      BaseContainer \*bc = bn->GetOpContainerInstance(); if (!bc) return FALSE; \>      return SUPER::iCreateOperator(bn); \> } \> \> const String PrintNode::GetDetailedText(GvNode \*bn) \> { \>      return GvGetOperatorDetailedText(this,bn); \> } \> \> const String PrintNode::GetText(GvNode \*bn) \> { \>      if (result) \>           return result->GetName(); \> \>      return "NULL"; \> } \> \> Bool PrintNode::AddToCalculationTable(GvNode \*bn, GvRun \*r) \> { \>      return r->AddNodeToCalculationTable(bn); \> } \> \> Bool PrintNode::InitCalculation(GvNode \*bn, GvCalc \*c, GvRun \*r) \> { \>      v1 = bn->AllocCalculationHandler(PRINT_NODE_INPUT,c,r,0); if (!v1) return FALSE; \>      return TRUE; \> } \> \> void PrintNode::FreeCalculation(GvNode \*bn, GvCalc \*c) \> { \>      bn->FreeCalculationHandler(v1); \> } \> \> Bool PrintNode::Calculate(GvNode \*bn, GvPort \*port, GvRun \*r, GvCalc \*c) \> { \>      if (!v1->Calculate(bn,GV_PORT_INPUT,r,c)) return FALSE; \> \>      LONG index; \>      if (!v1->GetPort()->GetInstance(result, r, &index;)) return FALSE; \> \>      if (result && c->document && result->GetType() == Opolygon) \>      { \>           AutoAlloc<BaseFile> file; \>           if (!file) return FALSE; \> \>           BaseTime time = c->document->GetTime(); \>           Real fps = c->document->GetFps(); \>           String frame = "c:\ est"+LongToString(time.GetFrame(fps)); \>           Filename fn(frame); \>            \>           if (!file->Open(fn, GE_WRITE, FILE_IGNOREOPEN, GE_INTEL)) return FALSE; \> \>           const Vector \*points = ToPoly(result)->GetPointR(); \>           LONG pcnt = ToPoly(result)->GetPointCount(); \> \>           for (LONG i=0; i<pcnt; i++) \>           { \>                if (!file->WriteVector(points[i])) return FALSE; \>           } \>      } \> \>      return TRUE; \> } \> \> //////////////////////////////// \> \> #define GVPRINTNODE_ID 1010815 \> \> Bool RegisterPrintNode() \> { \>      return GvRegisterOperatorPlugin(GVPRINTNODE_ID, "Print Node", 0, PrintNode::Alloc, "print_node", 0, ID_GV_OPCLASS_TYPE_GENERAL, ID_GV_OPGROUP_TYPE_GENERAL, 0, NULL); \> } \>
                                On 22/09/2009 at 03:38, xxxxxxxx wrote:
                                Thanks Matthias,
                                i got it. But it is realy awkward :-).
                                I allocate a LONG-array to save the polygoninformation temporarily.
                                And there was the problem.
                                > \> LONG\* polygon = (LONG\* ) GeAlloc(4 + sizeof(LONG)); //+ instead of \* \>
                                Anyway thanks for your help.
                                Oli
