    userdata work around
    4 Posts 0 Posters 342 Views
      On 27/08/2009 at 05:57, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Platform:      Mac OSX  ;
      Hi
      I was hoping to find a way of gathering up all my userdata from a null to put into an array, but I saw from the forum that coffee might not support this
      <<"I'd like to check if an object has user data(s) , how many , and their name . Do you think it's possible in coffee ?">>
      is there a work around for this? could I make a null with one userdata field, then copy and paste as many as I need and in my coffee script loop through all the nulls of the same name to find out how many userdata fields there are, or is there a much simpler way?
      Kind regards Conor
        On 27/08/2009 at 07:27, xxxxxxxx wrote:
        Hi I've just been looking at kattkieru's post about "BaseContainer and user data". I have a null with two user data fields (one is 56 the other 24) and I've tried the code
        main(doc,op)
        var op = doc->FindObject("userdata");
        var bc = op->GetContainer();
        var i = 0;
        while (bc->GetIndexId(i) != NOTOK)
        println(bc->GetIndexData(i));
        i++;
        but I get
        0
        10.000000
        1.000000
        0
        [Object-0x17a1d32c]
        in the console window, have I completely misunderstood this code if I'm expecting it to print the contents of the user data?
        Kind regards Conor
          On 27/08/2009 at 08:01, xxxxxxxx wrote:
          It's not possible to iterate through userdata in COFFEE.
          Userdata can only be accessed directly in COFFEE, like this: var data = op#ID_USERDATA:1
          The only workaround is described in this thread:
          some COFFEE questions
          For full userdata access you have to use the C++ API.
            On 27/08/2009 at 08:12, xxxxxxxx wrote:
            Thanks Matthias, I'll give that a go.
            cheers
            Conor
