    some C.O.F.F.E.E questions
    6 Posts 0 Posters 717 Views
    • H Offline
      Helper
      On 03/03/2009 at 07:20, xxxxxxxx wrote:
      Cinema 4D Version:   R10
      Platform:   Windows  ;
      Hey,
      I hope to get some answers to these C.O.F.F.E.E questions:
      1, Syntax Problem:
      > \> var myvar=6; \> hmm#ID_USERDATA:6=ob; //works fine \> hmm#ID_USERDATA:myvar=ob; //doesn't work \>
      How can I add myvar instead of 6?
      2, Add a gradient to material:
      > \> var channel = mat->GetChannel(CHANNEL_BUMP); \> var container = channel->GetContainer(); \> container->SetData(CH_TEXTURE, "blabla.tif"); \> channel->SetContainer(container); \>
      Its not possible to add a gradient instead of the tif, is it?
      3, I have several Drag&Drop; Fields in my Layout:
      > AddStaticText(4002,BFH_SCALEFIT,260,0,"Objekt einfügen",BORDER_THIN_IN);
      > \> if(msg->GetId() == BFM_DRAGRECEIVE) { \>           if(CheckDropArea(4002, msg, TRUE, TRUE)) { \>                SetDragDestination(MOUSE_POINT_HAND); \>                if(msg->GetData(BFM_DRAG_FINISHED)) { \>                     object = GetDragObject(msg); \>                     SetString(4002, object->GetName()); \>
      I want the Object's Icon shown in the Layout, not only the Object's Name. How can I add them? Probably it's not possible with AddStaticText but maybe in a different way.
      Thanks in advance
      • H Offline
        Helper
        On 05/03/2009 at 01:58, xxxxxxxx wrote:
        Still hoping for an early answer!
        Thanks in advance
        • H Offline
          Helper
          On 05/03/2009 at 02:14, xxxxxxxx wrote:
          I hope the following answers are correct (so without garantee) :
          1. I guess does not work.
          2. Gradients cannot be access by Coffee
          3. Don't know if there is a "GetIcon()" method.
          • H Offline
            Helper
            On 05/03/2009 at 08:01, xxxxxxxx wrote:
            THX Shawni
            well, I found a workaround for Problem 1 and 2.
            But I'm still wondering why this simple combination of variables in question 1 isn't working ...
            For question 3:
            I think I can access the icon with:
            > msg->GetData(DRAGTYPE_ICON)
            But I have no idea how to get it into the Drag &Drop; area.
            Maybe someone has a working Coffee Plugin including a LinkBox. I would be really grateful to get some code snippets...
            • H Offline
              Helper
              On 05/03/2009 at 08:08, xxxxxxxx wrote:
              1. Not possible but you can do something like this:
              > \> var myvar = 1; \> \> switch(myvar) \> { \>      case 1: \>           op#ID_USERDATA:1 = TRUE; \>           break; \>      case 2: \>           op#ID_USERDATA:2 = TRUE; \>           break; \> } \>
              2. Currently it's not possible to insert shaders.
              3. You have to add a user area to your dialog for each icon. See GeUserArea and AddUserArea().
              cheers,
              Matthias
              • H Offline
                Helper
                On 06/03/2009 at 01:47, xxxxxxxx wrote:
                tyvm
