    GeGetFileTime / LocalFileTime
    3 Posts 0 Posters 236 Views
      On 17/06/2009 at 11:10, xxxxxxxx wrote:
      Cinema 4D Version:   r11
      Hi there,
      i am having a problem with LocalFileTime.. i get an error that ft is not initialized.
      \>            LocalFileTime *ft;
      \>            ft->Init();
      \>            GeGetFileTime(GeGetPluginPath() + Filename(fn),GE_FILETIME_CREATED,ft);
      would be cool if someone can push me into the right direction..
      thanks and cheers,
      ello
        On 17/06/2009 at 12:05, xxxxxxxx wrote:
        You can't call a method from the pointer without allocating an instance of the class. I'd simply use a heap instance:
        LocalFileTime ft;
        ft.Init();
        GeGetFileTime(....,&ft;);
        If that doesn't work for some reason, then allocate an instance:
        LocalFileTime* ft = gNew LocalFileTime;
        // And then free it when done!
        gDelete(ft);
          On 17/06/2009 at 13:35, xxxxxxxx wrote:
          thank you! allocating works...
