    Accessing Custom Elements
    7 Posts 0 Posters 483 Views
      On 16/03/2009 at 14:05, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Hi guys,
      I really got stuck, maybe you can help me out.
      In ResEdit, I created a Custom Element(TEXTURNAME [1000484]).
      Now, how can I access its Container or at least the Properties like the image, the user has chosen? I read the SDK Docu up and down and vice versa, even the customgui_texturename.h did not give any usable info, as well as this forum.
      What I want to do is, let the User choose a Bitmap and pass this relative path to a variable.
      Best Regards, Robert...
        On 17/03/2009 at 08:41, xxxxxxxx wrote:
        Appendix:
        Based on the CPP SDK Docs, I found some useful Info, but it's still not enough. I really wish, there would be more examples for particular Elements, especially for Custom-Elements.
        Maybe, it's just a simple mistake, but the println never puits something out...
        > \> var filedata = new(BaseContainer); \> filedata->GetData(IDC_COLORMAP); \> var texstr = filedata->GetString(CUSTOMGUI_TEXTURENAME); \> println(texstr); // always nothing? \>
        greetings, Robert
          On 17/03/2009 at 08:46, xxxxxxxx wrote:
          You can't access custom GUI elements in COFFEE. For some there exist workarounds, but in general not.
            On 17/03/2009 at 08:58, xxxxxxxx wrote:
            Oh, thanks.
            But could you eventually point me to a workaround then?
            Would be very kind 😉
              On 17/03/2009 at 09:02, xxxxxxxx wrote:
              In dialogs you can't access custom GUI elements in general. An exception is the link field which receives a drag message if you drag something into into it. See following thread:
              Question to LinkBox
                On 17/03/2009 at 09:05, xxxxxxxx wrote:
                Also you can access some parts of custom description elements. But this depends on the internal datatype structure of the elements.
                Matthias.
                  On 17/03/2009 at 09:11, xxxxxxxx wrote:
                  Hey, that really helped me out.
                  Thanks Matthias...
