Question to LinkBox
On 12/03/2009 at 07:58, xxxxxxxx wrote:
Cinema 4D Version: R10
Platform: Windows ;
Language(s) : C.O.F.F.E.E ;---------
I was using StaticText as Drag&Drop; gadgets in my Dialog.
To reach a better layout I added a *.res file to my CreateLayout().>
\> DIALOG IDD_DIALOG1 \> { NAME IDS_DIALOG; CENTER_V; CENTER_H; \> \> LINK 900 \> { \> ALIGN_TOP; ALIGN_LEFT; SIZE 300, 0; \> } } \>I tried the same Code I used before with StaticText.
\> if(msg->GetId() == BFM_DRAGRECEIVE) \> { \> if(CheckDropArea(900, msg, TRUE, TRUE)) { \> SetDragDestination(MOUSE_POINT_HAND); \> if(msg->GetData(BFM_DRAG_FINISHED)) { \> object = GetDragObject(msg); \> SetString(900, object->GetName()); \>The problem is, when dropping a object in the LinkBox it disappears. I receive the object in the "var object" and can work with it but it isnt shown in the LinkBox. So SetString isnt working any longer. What do i have to use instead of it?
On 12/03/2009 at 08:08, xxxxxxxx wrote:
You can not simply use
\> LINK 900 \> { \> } \>You have to give it an ID and define it in the 'c4d_symbols.h' header file.
\> LINK MY_LINK_ID \> { \> } \>>
\> enum \> { \> ... \> MY_LINK_ID, \> ... \> }cheers,
Matthias -
On 12/03/2009 at 08:39, xxxxxxxx wrote:
thank u. I thought I could use 900 as ID.
Well I corrected the files, but still have the same problem...c4d_symbols.h
\> enum \> { \> \_FIRST_ELEMENT\_ = 10000, \> // Dialog definitions of IDD_DIALOG1 start here \> IDD_DIALOG1, \> MY_LINK_ID1, \> // Dialog definitions of IDD_DIALOG1 end here \> // End of symbol definition \> \_DUMMY_ELEMENT\_ \> }; \>IDD_DIALOG1.res
\> // C4D-DialogResource \> DIALOG IDD_DIALOG1 \> { \> NAME IDS_DIALOG; CENTER_V; CENTER_H; \> \> LINK MY_LINK_ID1 \> { \> ALIGN_TOP; ALIGN_LEFT; SIZE 300, 0; \> } \> } \> -
On 16/03/2009 at 02:37, xxxxxxxx wrote:
still have no idea how to make the dropped object visible!
Hope someone could help me go on.Thanks in advance
On 16/03/2009 at 04:39, xxxxxxxx wrote:
Here is a complete plugin with source code and resource files of a dialog with link field:
cheers,
Matthias -
On 16/03/2009 at 04:53, xxxxxxxx wrote:
Thank you so much Matthias!
I already had the same Code but forget to delete a "return TRUE;" at the end of my Message Funktion.
Because of that the dropped object wasn't displayed in the
Link field.without this line everythink works perfect now.
Thank you again !!!!
On 17/03/2009 at 08:42, xxxxxxxx wrote:
one more:
There is no way to predefine a Linkbox with an object in COFFEE? I remember to have read something like that in an older post.
On 17/03/2009 at 08:44, xxxxxxxx wrote:
I don't think this is possible for dialogs. It is possible for descriptions.
cheers,
Matthias
