    Normalize FBM and RidgedMultifractal
    5 Posts 0 Posters 424 Views
      On 01/03/2009 at 06:39, xxxxxxxx wrote:
      Cinema 4D Version:   10.1
      I am having problems using the Fbm() and RidgedMultifractal() functions.
      Simply getting a noise value from them is easy, of course. But it seems they are the only noise functions that may return values > 1.0. Is there a simple way to map the result, so they are always between 0.0 and 1.0 ?
      Thanks in advance 🙂
      Greetings,
      Jack
        On 03/03/2009 at 02:30, xxxxxxxx wrote:
        Are you using the C4DNoise methods or the global noise methods?
          On 03/03/2009 at 04:09, xxxxxxxx wrote:
          Hi Matthias,
          I'm using the gobal Noise methods.
          Greetings,
          Jack
            On 03/03/2009 at 06:55, xxxxxxxx wrote:
            If I use the C4DNoise class, will the values be between 0 and 1 then?
            Jack
              On 03/03/2009 at 07:04, xxxxxxxx wrote:
              And by the way, I think the C4DNoise class doesn't offer Ridged Multifractal, does it?
              Greetings,
              Jack
