    Prevent recalculation while moving
    14 Posts 0 Posters 1.5k Views
      On 31/01/2009 at 14:04, xxxxxxxx wrote:
      Hm, OK, I will explain more detailled...
      Some of the function in my plugin depend from the camera. That may be the Editor camera, the active scene camera object, or a camera that has been linked (dragged into a link field of my plugin) by the user. If a camera has been linked, it must be used instead of editor/active scene camera.
      I get the camera like this:
      > CameraObject \*Cam = (CameraObject\* ) bc->GetObjectLink(SURFACESPREAD_FILTER_PERFORMANCECAM, doc); \> if (!Cam) Cam = GetCurrentCamera(doc); \>
      The function GetCurrentCamera() looks like this:
      > CameraObject \*GetCurrentCamera(BaseDocument \*doc) \> { \>      // Get active/Editor camera \>      if (doc->GetRenderBaseDraw()->HasCameraLink()) \>           return (CameraObject\* ) doc->GetRenderBaseDraw()->GetSceneCamera(doc); \>      else \>           return (CameraObject\* ) doc->GetRenderBaseDraw()->GetEditorCamera(); \> } \>
      So now I definitely have a camera. Either the editor camera, the active scene camera, or a linked camera object.
      I now want to check if that camera has been moved or if its parameters have changed. If so, I must recalculate my plugin instead of using the cache.
      > \> Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA) || Cam->IsDirty(DIRTY_DATA) || Cam->IsDirty(DIRTY_MATRIX); \> if (!dirty) return op->GetCache(hh); \>
      The strange thing is: This ONLY works with the Editor camera. With a camera object in the document (active scene camera or linked camera), I never get anything.
      I tried to set a dependency by doing:
      > Cam->AddDependence(hh, op);
      But that didn't change anything.
      How can I detect changes in the Matrix or the Attributes of a camera object?
      Thanks for any help!
      Greetings,
      Jack
        On 01/02/2009 at 03:42, xxxxxxxx wrote:
        Aha, I found out that it only works, if the camera object comes AFTER my plugin object in the Object Manager. Otherwise, the Dirty status seems to be cleared before my plugin object is called.
        Is there any way to change that?
        Greetings,
        Jack
          On 02/02/2009 at 09:00, xxxxxxxx wrote:
          Adding the camera to the dependence list seems to work.
          > \> Bool dirty; \> \> if(cam) \> { \>      op->NewDependenceList(); \>      op->AddDependence(hh, cam); \>      dirty = !op->CompareDependenceList(); \> } \> else \>      dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA); \> \> if (!dirty) return op->GetCache(hh); \>
            On 02/02/2009 at 09:13, xxxxxxxx wrote:
            Yes 🙂 🙂
            You're the best, Matthias!
            Anyway, the entry "BaseObject::NewDependenceList()" in the SDK documentation should be changed. It sais: "Note: The object must be children of your object." but it turns out, it also works fine with objects that are not children.
            Thanks!!
            Greetings,
            Jack
              On 02/02/2009 at 09:46, xxxxxxxx wrote:
              Actually that is something I still have to get a confirmation from the developers. I am not 100 percent sure yet if it is safe to use. I will let you know when I get an answer.
                On 02/02/2009 at 10:24, xxxxxxxx wrote:
                Thanks 🙂
                  On 18/04/2009 at 17:12, xxxxxxxx wrote:
                  Well, did you get any answer from the developers yet?
                  Also, I just wonder about your code (which works fine) :
                  > Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA);
                  Does this mean that GetCache returns FALSE if the cache is valid? The SDk documentation sais, GetCache returns TRUE in that case, but wouldn't that mean the return op->GetCache(hh) is only called if the object's cache is NOT valid?
                  Greetings,
                  Jack
                    On 18/04/2009 at 21:23, xxxxxxxx wrote:
                    That makes sense. If the cache needs to be rebuilt, it would return TRUE (cache is dirty), otherwise there is a valid cache. 'dirty' would be set correctly to TRUE if either or both CheckCache() and IsDirty() return TRUE.
                    GetCache() is a different method that returns a BaseObject*. Don't confuse them.
                      On 19/04/2009 at 03:48, xxxxxxxx wrote:
                      Ah, damn, misspelled. Of course I ment CheckCache().
                      SDK documentation sais, it returns TRUE if the cache is valid. But obviously it returns TRUE if the cache is not valid, right?
                      Jack
                        On 21/04/2009 at 02:55, xxxxxxxx wrote:
                        Sorry, I have no answer yet. But seeing as this chaching stuff can be quite confusing I'll discuss this with the developers to make the documentation more complete regarding this topic.
