    xcode mac compile: coreservices ?
    12 Posts 0 Posters 1.4k Views
      On 14/01/2009 at 11:06, xxxxxxxx wrote:
      Did you start your project using the cinema4dsdk.xcodeproj file as a template for your project? This will alleviate much anguish and hair loss.
        On 14/01/2009 at 11:17, xxxxxxxx wrote:
        yes i opened cinema4dsdk.xcodeproj, right-clicked the c4dsdkexample target and chose build c4dsdk..
        i just wanted to rebuild the example stuff to see if everything is setup correctly..
        it looks like the include <CoreServices/CoreServices.h> doesnt work, even though that file exists in the Developer-dir.
        I had assumed that xcode would setup itself and the os to be aware of the sdk location. maybe i sould re-install xcode ?
          On 14/01/2009 at 11:43, xxxxxxxx wrote:
          Did you do this necessary step as outlined in the SDK xcode_universalbinary_migration.pdf?
          It is important that you open the XCode preferences pane and change the path where XCode saves intermediate and build files. Choose a customized location somewhere on your hard drive, so that your project folders will stay clean. NEVER choose a path that is within C4D or the plugin directory!
          I pointed it to a location in my Users folder.
          I don't use Xcode 3.1 to build for R9.6; only R11. Otherwise, I'm using Xcode 2.4.1 for earlier C4D versions.
            On 14/01/2009 at 11:52, xxxxxxxx wrote:
            thanks for the info. i changed it but it makes no difference. neither R9.6 nor R11 can build the _api dependance.
            i'll try to get xcode 2.4.1 and see if that works better.
              On 14/01/2009 at 11:59, xxxxxxxx wrote:
              Are you trying to build within the Applications folder? This may not be a good idea since it is write protected (this is new in Leopard). Again, I copy the plugins and resource folders to a location in my Users folder and build from there. This makes it conceptually easy to track your plugin projects as well:
              Users
              ->Me
              -->C4DProjects
              --->Cinema4DR11
              ---->plugins
              ----->cinema4dsdk
              ----->myplugin
              ---->resource
              And so on. Each build by C4D version is in its relevant location with relative referencing to proper resources.
                On 14/01/2009 at 12:15, xxxxxxxx wrote:
                i unpacked the demo's into my documents folder, which is in the user folder afaik, so it shouldnt be a problem..
                when i check the sdk path in the project settings its alright also: Developer/SDKs/MacOSX10.4u_blah/..
                  On 14/01/2009 at 12:29, xxxxxxxx wrote:
                  i just changed the include in question by hand, to read "Developer/SDKs/..CoreServices.h" instead of <CoreServices/CoreServices.h> this solved the error in question, but now its cant find the next include CarbonCore.h ..
                  So it has definitely sth to do with the include paths.
                  i bet its really simple but as im new to mac its giving me a hard time. also its strange bc the default sdkexamples are supposed to work all by themselves without changing config afaik..
                  i'll poke around with the xcode settings some, maybe i find sth out..
                    On 15/01/2009 at 03:51, xxxxxxxx wrote:
                    couldnt figure it out still...
                    it fails to build the _api project, bc the include of the CoreServices Framework somehow doesnt work, even though the files are in their default position (/Developer/SDKs/..)
                    if anybody else ever had a problem with this i'd apprecciate any hints.
                    thanks,
                    Daniel
                      On 15/01/2009 at 06:20, xxxxxxxx wrote:
                      alright, i got it working now (tested with R9.6 and R11).
                      using the unchanged cinema4d sdk project, i had to do the following changes to the settings of both projects, cinema4dsdk and _api:
                      - change architecture to 'standard(32Bit Universal)'
                      - change Base SDK to 'MacOSX 10.4'
                      - change active architecture to 'ppc' (instead of i386)
                        On 15/09/2009 at 23:15, xxxxxxxx wrote:
                        Thanks for sharing.
                        research papers
