    Triangulate Polygon object
    9 Posts 0 Posters 694 Views
      On 02/01/2009 at 05:40, xxxxxxxx wrote:
      Cinema 4D Version:   10.1
      Platform:   Windows  ; Mac  ;
      since I got the same problem as fused (see this thread), I tried to get a correctly triangulated model like this:
      > \> void TriangulatePolygonObject(PolygonObject \*op, BaseDocument \*doc, PolygonObject \*res) \> { \>      PolygonObject \*cObj = (PolygonObject\* )(op->GetClone(COPY_NO_BRANCHES|COPY_NO_BITS|COPY_NO_INTERNALS, NULL)); \>      cObj->SetMg(op->GetMg()); \> \>      ModelingCommandData cd; \>      cd.doc = doc; \>      cd.op = cObj; \>      if (SendModelingCommand(MCOMMAND_TRIANGULATE, cd)) \>      { \>           PolygonObject \*result = (PolygonObject\* )(cd.result->GetIndex(0)); \>           if(result) \>           { \>                result->CopyTo(res, COPY_NO_BRANCHES|COPY_NO_BITS|COPY_NO_INTERNALS, NULL); \>                PolygonObject::Free(result); \>           } \>      } \>      PolygonObject::Free(cObj); \> }
      But it doesn't work. SendModelingCommand() always returns TRUE, indicating the command was executed. But result is always NULL. Where's the problem? I call the function like this:
      > PolygonObject \*OrgObj = ToPoly(op); \> PolygonObject \*TriObj = PolygonObject::Alloc(OrgObj- >GetPointCount(), OrgObj->GetPolygonCount()); \> TriangulatePolygonObject(OrgObj, doc, TriObj); \>
      Op is a plane, a landscape or any converted polygon object. Always the same NULL result.
      Tahnks for any help!
      Jack
        On 02/01/2009 at 08:30, xxxxxxxx wrote:
        i believe the object you specify in ModelingCommandData is modified and result is supposed to be NULL.
          On 02/01/2009 at 10:06, xxxxxxxx wrote:
          I don't understand. Modified? You mean it's different from the original object in the document?
          Well, I tried to create a temporary document and insert the polygon object there before calling the modeling command (some example by Matthias showed how to do that). But it didn't change the result at all.
          I really have no idea... Also, I still wonder why the Triangulate() function simply outputs a load of crap.
          Jack
            On 02/01/2009 at 11:22, xxxxxxxx wrote:
            The triangulation occurs directly on the original object.
              On 02/01/2009 at 12:03, xxxxxxxx wrote:
              Ah, OK, that wasn't clear to me. Thanks Robert 🙂
              But it is still not working as expected.
              As I understood it, the following code should work:
              > Bool TriangulatePolygonObject(PolygonObject \*op, BaseDocument \*doc, PolygonObject \*res) \> { \>      res = (PolygonObject\* )(op->GetClone(COPY_NO_ANIMATION|COPY_NO_BITS|COPY_NO_INTERNALS, NULL)); \>      res->SetMg(op->GetMg()); \> \>      ModelingCommandData cd; \>      cd.doc = doc; \>      cd.op = res; \>      return SendModelingCommand(MCOMMAND_TRIANGULATE, cd); \> }
              But if e.g. op is a polygon object containing one quad polygon, performing - >GetPolygonCount() on resulting object res still only returns 1. Even better: If I get the points coordinates of this one polygon, they are all 0.
              Damn, how hard can it be to triangulate a simple object?
              Jack
                On 02/01/2009 at 12:21, xxxxxxxx wrote:
                Addition: It seems that the object actually IS correctly triangulated. When I add the following line before returning the result...
                > GePrint("Poly count: " + LongToString(res->GetPolygonCount()));
                ...it outputs "Poly count: 2" in the console.
                But when I call the function and try to get the poly count in the main function...
                > PolygonObject \*OrgObj = ToPoly(op); \> \> PolygonObject \*TriObj = PolygonObject::Alloc(OrgObj->GetPointCount(), OrgObj->GetPolygonCount()); \> \> TriangulatePolygonObject(OrgObj, doc, TriObj); \> \> GePrint("Poly count: " + LongToString(TriObj->GetPolygonCount()));
                ...it outputs "Poly count: 1" again. If I declare TriObj as NULL, it is still NULL after calling TriangulatePolygonObject(), but inside TriangulatePolygonObject() the pointer res is not NULL, since it's getting a clone of the original object.
                I really don't understand. Sorry. I bet it's something totally stupid. It seems that everything I do to res just works inside TriangulatePolygonObject(), but the result is not stored in the original object whose pointer was passed to the function.
                Greetings,
                Jack
                  On 02/01/2009 at 13:18, xxxxxxxx wrote:
                  Just for the archives: Solved the problem. But I have no idea why it didn't work like I showed in the 2 postings above.
                  Solution is here.
                  > Bool TriangulatePolygonObject(PolygonObject \*op, BaseDocument \*doc)//, PolygonObject \*res) \> { \>      ModelingCommandData cd; \>      cd.doc = doc; \>      cd.op = op; \>      Bool result = SendModelingCommand(MCOMMAND_TRIANGULATE, cd); \>      return result; \> } \>
                  Cloning the original object has to be done *before* the function is called. I now do it like this:
                  > PolygonObject \*OrgObj = ToPoly(op); \> PolygonObject \*TriObj = (PolygonObject\* )(OrgObj->GetClone(COPY_NO_ANIMATION|COPY_NO_BITS|COPY_NO_INTERNALS, NULL)); \> if (!TriangulatePolygonObject(TriObj, doc)) return FALSE; \>
                  Now TriObj contains the triangulated geometry. Don't forget to free it after use 😉
                  Greetings,
                  Jack
                    On 06/01/2009 at 03:26, xxxxxxxx wrote:
                    Ah, so solved your problem on your own. Glad it worked out.
                      On 06/01/2009 at 05:18, xxxxxxxx wrote:
                      Yeah, but I solved by pure chance.
                      Still don't understand the reason 😉
                      Greetings,
                      Jack
