    Triangulate?
    11 Posts 0 Posters 793 Views
    • H Offline
      Helper
      On 10/03/2007 at 03:42, xxxxxxxx wrote:
      Cinema 4D Version:   9.1
      Platform:   Windows  ;
      Im writing a plugin to export C4D scenes to indigo XML format. When i export to .obj format(3ds gets triangulated automatically) i need to triangulate the mesh before export. how do i do that?
      heres a code snippet:
      Bool ExportXML::ExportObject(BaseObject *bo, BaseDocument *doc, Bool objExport, Filename fn, Bool meshLight)
      BaseDocument *doc_dummy = BaseDocument::Alloc();
      BaseTag *baset;
      GeData gedata;
      Material *tagmat;
      Material *clonetagmat;
      //Vector tempVector;
      //Vector vector;
      if (meshLight == 0)
      //COPY MATERIAL
      //COPY OBJECT
      //SET POS 0,0,0 and ROTATION
      Matrix matrix = baseobj->GetMg();
      matrix.off.x = 0;
      matrix.off.y = 0;
      matrix.off.z = 0;
      //rotete if .obj 0 1 0
      if(objExport == 1)
      //x
      matrix.v1.x = 1;
      matrix.v1.y = 0;
      matrix.v1.z = 0;
      //y
      matrix.v2.x = 0;
      matrix.v2.y = 0;
      matrix.v2.z = -1;
      //z
      matrix.v3.x = 0;
      matrix.v3.y = 1;
      matrix.v3.z = 0;
      baseobj->SetMg(matrix,FALSE);
      if (meshLight == 0)
      //SET MAT
      if(objExport == 1)
      // triangulate here
      //EXPORT
      if (objExport == 1) SaveDocument(doc_dummy,fn,TRUE,FORMAT_OBJEXPORT);
      else SaveDocument(doc_dummy,fn,TRUE,FORMAT_3DSEXPORT);
      doc_dummy->Free(doc_dummy);
      return TRUE;
      • H Offline
        Helper
        On 10/03/2007 at 09:05, xxxxxxxx wrote:
        Have you tried Triangulate()? 🙂
        If your object isn't polygonal, you'll need to convert it to be so first using either BaseDocument::Polygonize() or SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT,...).
        • H Offline
          Helper
          On 10/03/2007 at 10:05, xxxxxxxx wrote:
          yes, i saw thet function in the documentation, but i have no clue wherei should get the values from
          Bool Triangulate(Vector* padr, LONG pcnt, CPolygon** vadr, LONG* vcnt)
          • H Offline
            Helper
            On 10/03/2007 at 12:13, xxxxxxxx wrote:
            Straight from the polygon object:
            BaseObject* obj; // Your starting object
            PolygonObject* pobj = ToPoly(obj);
            Vector* padr = pobj->GetPoint();
            LONG pcnt = pobj->GetPointCount()
            if (!pcnt) return FALSE; // - or some error handling. This object has no points (and no useful polygons)
            // These point to the newly created polygon triangle array and the number of triangles - don't forget to GeFree(tripolys) when you are done with the array!
            CPolygon* tripolys;
            LONG tricount;
            if (!Triangulate(padr, pcnt, &tripolys;, &tricount;)) return FALSE; // Failed to triangulate
            if (!(tripolys && tricount)) return FALSE; // tripolys=NULL or tricount=0L
            Then use these polygons instead of the ones on the original object - use the original points as they don't get changed during triangulation.
            • H Offline
              Helper
              On 27/03/2007 at 14:17, xxxxxxxx wrote:
              thank you so far, but i still dont get what to do with the array.
              • H Offline
                Helper
                On 27/03/2007 at 14:44, xxxxxxxx wrote:
                Ah, you are using the built-in Cinema 4D OBJ export. There are two ways to do this then:
                1. Triangulate using SendModelingCommand(MCOMMAND_TRIANGULATE) and get the result to use for export - you'll probably want to InsertObject() this result into the dummy document. Follow the MCOMMAND_CURRENTSTATETOOBJECT example in this case.
                2. Use the tripoly array to update the Polygon object. This will require calling PolygonObject::ResizeObject() with the current vertex array size and new polygon array size, filling in its polygon array with the tripoly array info, and then using the original Polygon object for export.
                • H Offline
                  Helper
                  On 31/03/2007 at 00:54, xxxxxxxx wrote:
                  thank you very much, works great.
                  • H Offline
                    Helper
                    On 22/04/2008 at 10:50, xxxxxxxx wrote:
                    ok, first of all, sry for ressurrecting such an old topic.
                    I'm still have problems with triangulation.
                    Until now i was using SendModelingCommand(MCOMMAND_TRIANGULATE, Mdd), and it works fine.
                    But when i use Triangulate() the way kuroyume described, they alway come out mixed up, i cant get i to work:
                    help?
                    • H Offline
                      Helper
                      On 23/04/2008 at 14:58, xxxxxxxx wrote:
                      did i understand something wrong?
                      no idea, anyone?
                      • H Offline
                        Helper
                        On 02/01/2009 at 05:13, xxxxxxxx wrote:
                        Hey, I just got the very same problem.
                        Found any solution yet?
                        Or is there working example code for the MCOMMAND_TRIANGULATE? Can't get that to work, either.
                        Thanks in advance!
                        Jack
                        • H Offline
                          Helper
                          On 06/01/2009 at 03:23, xxxxxxxx wrote:
                          Triangulate() is not really meant to be used for existing polygon meshes but rather for example to create triangles from a point cloud.
                          > Quote: _Or is there working example code for the MCOMMAND_TRIANGULATE?
                          _
                          That's actually pretty easy, here an example:
                          > \> Bool MenuTest::Execute(BaseDocument \*doc) \> { \>      StopAllThreads(); \> \>      BaseObject \*op = doc->GetActiveObject(); \>      if(!op) return TRUE; \> \>      if(op->GetType() == Opolygon) \>      { \>           ModelingCommandData md; \>           md.doc = doc; \>           md.op = op; \> \>           SendModelingCommand(MCOMMAND_TRIANGULATE, md); \>      } \>       \>      return TRUE; \> } \>
                          cheers,
                          Matthias
