    how to get texture file names path?
    5 Posts 0 Posters 638 Views
      On 21/09/2008 at 23:55, xxxxxxxx wrote:
      Cinema 4D Version:
      I want to get full path of texture but follow code fn.GetString() can't get full path.
      this is my snippet code:
      void getTextureFileName(string& strOutFileName)
      string g_sBaseDir;
       BaseContainer ctr = GetActiveDocument()->GetAllTextures();
       BrowseContainer bc(&ctr);
       LONG id;
       GeData *dat;
       while (bc.GetNext(&id, &dat))
        Filename fn = dat->GetFilename();
        String strFilePath;
        String strFileName( fn.GetString());
              strFilePath = strFileName;
        LONG iLen = strFilePath.GetCStringLen(St8bit)+1;
        char* pName = bNew CHAR[iLen];
        memset(pName,0, sizeof(CHAR)*iLen);
        strFilePath.GetCString( pName,iLen, St8bit);
        string strOutName(pName);
              bDelete(pName);
        pName = NULL;
      strOutFileName += strOutName ;
      strOutFileName += "|";
        On 22/09/2008 at 00:30, xxxxxxxx wrote:
        Will..not..work.
        //Material* mat;
        BaseChannel* bchan = mat->GetChannel(CHANNEL_COLOR);
        BaseContainer bdata = bchan->GetData();
        Filename fn = bdata.GetFilename(BASECHANNEL_SUGGESTEDFOLDER)+Filename(bdata.GetString(BASECHANNEL_TEXTURE));
        The texture image is stored in two places as you see - path and file specifiers.
          On 22/09/2008 at 01:42, xxxxxxxx wrote:
          //Material* mat;
           the code Will  get nothing. why?
            On 22/09/2008 at 15:19, xxxxxxxx wrote:
            That is only an example. There is more than CHANNEL_COLOR - like CHANNEL_BUMP, CHANNEL_DISPLACEMENT, CHANNEL_DIFFUSION, etc. etc. etc. And this only can get at the channel texture map not at shaders or deeper in (like fusion layers).
            I'm pretty sure that it does indeed work since I use it in my own code. Here are some links:
            http://www.plugincafe.com/forum/display_topic_threads.asp?ForumID=4&TopicID;=3212&PagePosition;=29
            http://www.plugincafe.com/forum/display_topic_threads.asp?ForumID=4&TopicID;=2775&PagePosition;=61
              On 23/09/2008 at 02:37, xxxxxxxx wrote:
              thanks robert,my problem was resolved, this is my snippet code:
               string g_sBaseDir;
               BaseMaterial* mat = GetActiveDocument()->GetFirstMaterial();
              while(mat)
                BaseChannel* pChannel = mat->GetChannel(CHANNEL_COLOR);
                if (pChannel)
                 Filename path = pChannel->GetData().GetFilename(BASECHANNEL_SUGGESTEDFOLDER);
                 if(!path.Content())     path = GetActiveDocument()->GetDocumentPath();
                 Filename file = pChannel->GetData().GetString(BASECHANNEL_TEXTURE);
                 if ( file.GetString().GetCStringLen(St8bit)< 0 ||  file.GetString().GetCStringLen(St8bit) ==  0)
                  mat = mat->GetNext();
                  continue;
                 path = path+file;
              String strTexturePath( path.GetString());
              LONG iPathLen = strTexturePath.GetCStringLen(St8bit)+1;
                 char* pTextureName = bNew CHAR[iPathLen];
                 memset(pTextureName,0, sizeof(CHAR)*iPathLen);
              strTexturePath.GetCString( pTextureName,iPathLen, St8bit);
                 string strOutTexturePath(pTextureName);
              bDelete(pTextureName);
                 pTextureName = NULL;
                 DBG_LOG("strOutTexturePath=%s",strOutTexturePath.c_str());
                 if ( strOutTexturePath.length() > 0 )
              if (strOutTexturePath.find(':') != string::npos)
              strOutFileName += strOutTexturePath.c_str();
                  else
              Filename filedir = ::GeGetStartupPath();
              String strFilePathDir( filedir.GetString());
              LONG iPathLen = strFilePathDir.GetCStringLen(St8bit)+1;
              char* pDirName = bNew CHAR[iPathLen];
                   memset(pDirName,0, sizeof(CHAR)*iPathLen);
              strFilePathDir.GetCString( pDirName,iPathLen, St8bit);
                   string strOutDirName(pDirName);
              bDelete(pDirName);
                   pDirName = NULL;
                   g_sBaseDir = strOutDirName;
              strOutFileName += g_sBaseDir.c_str();
                   strOutFileName += "\";
              int Version = GetC4DVersion();
              if ( Version < 10000)
                      strOutFileName += "tex\";
                  //MessageDialog( strOutFileName.c_str() );
               if ( strOutFileName.length() > 0)
                strOutFileName = strOutFileName.substr(0, strOutFileName.rfind('|'));
