    Extracting the Texturename from a Materia
    3 Posts 0 Posters 548 Views
    • H Offline
      Helper
      On 19/04/2007 at 00:32, xxxxxxxx wrote:
      Cinema 4D Version:   9.6
      Platform:
      I need the Texturename (and path) from the colorchannel in a material.
      Following the examples I found here, thats my code:
      BaseMaterial* mat = P406Exporter.doc->GetFirstMaterial();
      BaseChannel* pChannel = mat->GetChannel(CHANNEL_COLOR);
      if (pChannel)
      // Extract full image file path
      Filename suggestedFolder = pChannel->GetData().GetFilename(BASECHANNEL_SUGGESTEDFOLDER);
      String map = pChannel->GetData().GetString(BASECHANNEL_TEXTURE);
      Filename fullpath = suggestedFolder + Filename(map);
      But the filename is always empty.
      GenerateTexturePath(P406Exporter.doc->GetDocumentPath(), Filename(pChannel->GetData().GetString(BASECHANNEL_TEXTURE)), Filename(), &path;) ;
      This one returns an empty filename too.
      I had no problems accessing other values in the different channels, but this seems to be stored different than the other values.
      I find it a little confusing how the values are stored and I somehow never now how to access them (getParameter, getContainer, getData, getDataInstance)
      Any suggestions are welcome
      • H Offline
        Helper
        On 19/04/2007 at 01:08, xxxxxxxx wrote:
        This is how you get the complete path including the name of the file for your texture. bc is the BaseContainer of the BaseChannel.
        Filename path = bc.GetFilename(BASECHANNEL_SUGGESTEDFOLDER);
        if(!path.Content())      path = doc->GetDocumentPath();
        Filename file = bc.GetString(BASECHANNEL_TEXTURE);
        path = path+file;
        GePrint(path.GetString());
        hope this helps
        cheers,
        Matthias
        • H Offline
          Helper
          On 19/04/2007 at 02:11, xxxxxxxx wrote:
          Yes, it works perfectly.
          Thanks for the help
