    Creating new Expresso result node?
    4 Posts 0 Posters 825 Views
      On 31/08/2008 at 13:02, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Platform:      Mac OSX  ;
      Language(s) :     C++  ;  XPRESSO  ;
      I would like to write my own XPresso result node, adding further data "types" to the list. Is there a documented way to do this?
      Is there any XPresso node plugin code available?
      Thanks!
      Kabe
        On 31/08/2008 at 15:15, xxxxxxxx wrote:
        Hi Kabe 🙂
        How are you? The class GvOperatorData should do that for you.
        Override the methods and register this class to get your own node.
        Here is an example:
        *click*
        Search keyword: GvOperatorData
        In the SDK you find an example to create custom datatypes - take a look 🙂
        Bye...
          On 01/09/2008 at 00:52, xxxxxxxx wrote:
          Here is the source of Cinema's Result node, hope this helps:
          > \> #include "gvresult.h" \> \> class GvResultOperator : public GvOperatorData \> { \>           INSTANCEOF(GvResultOperator,GvOperatorData) \> \>      private: \>           String                    result; \>           GvDynamicData     data; \>           GvValue\*               v1; \>                 \>      private: \>           GvResultOperator(void); \>           virtual ~GvResultOperator(void); \> \>      public: \> \>           virtual const String     GetDetailedText(GvNode \*bn); \>           virtual const String     GetText(GvNode \*bn); \> \>           virtual Bool                         iCreateOperator(GvNode \*bn); \>           virtual Bool                         iGetPortDescription(GvNode \*bn, GvPortIO port, LONG id, GvPortDescription \*pd); \> \>           virtual Bool                         AddToCalculationTable(GvNode \*bn, GvRun \*r); \> \>           virtual Bool                         InitCalculation(GvNode \*bn, GvCalc \*c, GvRun \*r); \>           virtual void                         FreeCalculation(GvNode \*bn, GvCalc \*c); \>           virtual Bool                         Calculate(GvNode \*bn, GvPort \*port, GvRun \*r, GvCalc \*c); \> \>           virtual Bool                         SetDParameter(GeListNode \*node, const DescID &id;,const GeData &t;\_data,LONG &flags;); \>           virtual Bool                         GetDDescription(GeListNode \*node,Description \*description,LONG &flags;); \> \>           static NodeData\*               Alloc(void) { return gNew GvResultOperator; } \> \> }; \> \> //////////////////////////////// \>
          > \> #include "operators.h" \> #include "gv_result_operator.h" \> #include "lib_description.h" \> \> //////////////////////////////// \> \> GvResultOperator::GvResultOperator(void) \> { \> \> } \> \> GvResultOperator::~GvResultOperator(void) \> { \> \> } \> \> //////////////////////////////// \> \> Bool GvResultOperator::iCreateOperator(GvNode \*bn) \> { \>      bn->SetShowPortNamesState(FALSE); \>      BaseContainer \*bc = bn->GetOpContainerInstance(); if (!bc) return FALSE; \>      bc->SetLong(GV_DYNAMIC_DATATYPE,ID_GV_DATA_TYPE_REAL); \>      return SUPER::iCreateOperator(bn); \> } \> \> const String GvResultOperator::GetDetailedText(GvNode \*bn) \> { \>      return GvGetOperatorDetailedText(this,bn); \> } \> \> const String GvResultOperator::GetText(GvNode \*bn) \> { \>      return result; \> } \> \> //////////////////////////////// \> \> Bool GvResultOperator::iGetPortDescription(GvNode \*bn, GvPortIO port, LONG id, GvPortDescription \*pd) \> { \>      if (!SUPER::iGetPortDescription(bn,port,id,pd)) return FALSE; \> \>      GvDataInfo \*info = GvGetDataInfo(bn,GV_DYNAMIC_DATATYPE); \>      if (!info) return FALSE; \> \>      switch (id) \>      { \>           case GV_RESULT_INPUT: \>           case GV_RESULT_OUTPUT: \>                pd->data_id = info->data_handler->data_id; \>           break; \>      } \>      return TRUE; \> } \> \> //////////////////////////////// \> \> Bool GvResultOperator::SetDParameter(GeListNode \*node, const DescID &id;,const GeData &t;\_data,LONG &flags;) \> { \>      if (!SUPER::SetDParameter(node,id,t_data,flags)) return FALSE; \> \>      switch (id[0].id) \>      { \>           case GV_DYNAMIC_DATATYPE: \>           { \>                GvNode \*bn = (GvNode\* )node; \> \>                if (!GvCheckDataInfo(bn,GV_DYNAMIC_DATATYPE)) return FALSE; \>                if (!bn->SetPortType(bn->GetInPort(0),GV_RESULT_INPUT)) return FALSE; \>                if (!bn->SetPortType(bn->GetOutPort(0),GV_RESULT_OUTPUT)) return FALSE; \>           } \>           break; \>      } \>      return TRUE; \> } \> \> Bool GvResultOperator::GetDDescription(GeListNode \*node,Description \*description,LONG &flags;) \> { \>      if (!SUPER::GetDDescription(node,description,flags)) return FALSE; \> \>      if (flags & DESCFLAGS_DESC_LOADED) \>      { \>           BaseContainer \*bc = description->GetParameterI(DescLevel(GV_DYNAMIC_DATATYPE),NULL); \>           if (bc) \>           { \>                BaseContainer types; \>                GvGetWorld()->GetDataTypes(types,GV_DATA_OPTIONS_NONE,GV_CALC_STR); \>                bc->SetData(DESC_CYCLE,types); \>           } \>      } \>      return TRUE; \> } \> \> //////////////////////////////// \> \> Bool GvResultOperator::AddToCalculationTable(GvNode \*bn, GvRun \*r) \> { \>      return r->AddNodeToCalculationTable(bn); \> } \> \> Bool GvResultOperator::InitCalculation(GvNode \*bn, GvCalc \*c, GvRun \*r) \> { \>      v1 = bn->AllocCalculationHandler(GV_RESULT_INPUT,c,r,0); if (!v1) return FALSE; \>      return GvAllocDynamicData(bn,data,c,GV_DYNAMIC_DATATYPE); \> } \> \> void GvResultOperator::FreeCalculation(GvNode \*bn, GvCalc \*c) \> { \>      bn->FreeCalculationHandler(v1); \>      GvFreeDynamicData(data); \> } \> \> Bool GvResultOperator::Calculate(GvNode \*bn, GvPort \*port, GvRun \*r, GvCalc \*c) \> { \>      if (!v1->Calculate(bn,GV_PORT_INPUT,r,c)) return FALSE; \>      if (!v1->GetPort()->CalculateRawData(NULL,&result;,r,GV_CALC_STR)) return FALSE; \> \>      return bn->GetOutPort(0)->CopyPortData(v1->GetPort(),r); \> } \> \> //////////////////////////////// \>
          Also don't forget to check the description files (gvresult.res, gvresult.h, gvresult.str) for the node's interface description.
            On 02/09/2008 at 11:23, xxxxxxxx wrote:
            Thanks a million!
            Kabe
