    • Unread
    Nodes that Iterate
    SDK Help
    0
    • H
      Helper
      On 13/11/2002 at 08:52, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Language(s) :     C++  ;  XPRESSO  ;
      Is there an example of a node that iterates through several indices while requesting the appropriate indexed data from a node wired to a iteration node's in port?
      Thanks!
      darf - bhodiNUT
      • H
        Helper
        On 13/11/2002 at 09:14, xxxxxxxx wrote:
        Parsing message: ............................ [PARSE FAILED!]
        Could you clarify what you mean? An example? (The answer is of course "no" by definition, since there are no GV examples at all, but if I understand what you mean I might be able to help... 🙂
        • H
          Helper
          On 13/11/2002 at 12:05, xxxxxxxx wrote:
          Well, I am trying to create a node that cycles through a loop executing for each index. Seems like those ITERATE enumerations running around in the headers would elude to an iterate functionality within the nodes. Is there a possibility of an example sometime?  😉
          Best Regards,
          darf - bhodiNUT
          • H
            Helper
            On 13/11/2002 at 13:36, xxxxxxxx wrote:
            Here's an example that outputs seven iterated vectors. It's a bit useless at the moment, since not very many nodes expect an iterated stream of vectors alone, but it should show the main principle.
            \>     // gviteratortest.cpp
            \>     > #include "c4d.h"
            \>     > #include "c4d_operatordata.h"
            \>     const GvOperatorID GVTESTITERATOR_ID = 1010815;
            \>     > static LONG input_ids[] = { 0 };
            \>     class GvTestIterator : public GvOperatorData
            \>     > private:
            \>     >   GvCalcTable* table;
            \>     >   GvValuesInfo ports;
            \>       Bool cached[MAX_THREADS];
            \>     >   Vector cache[MAX_THREADS];
            \>     public:
            \>     >   GvTestIterator(void) : table(NULL) {}
            \>       Bool InitCalculation(GvNode *bn, GvCalc *c, GvRun *r)
            \>     >     for (LONG i = 0; i < MAX_THREADS; ++i)
            \>     >       cached[i] = FALSE;
            \>     >       cache[i] = Vector();
            \>         return (c && c->master) &&
            \>     >            (table = c->master->AllocCalculationTable(c->cpu_count, TRUE, 16, TRUE)) &&
            \>     >            (GvBuildValuesTable(bn, ports, c, r, input_ids));
            \>       void FreeCalculation(GvNode *bn, GvCalc *c)
            \>     >     if (table && c && c->master)
            \>     >       c->master->FreeCalculationTable(table);
            \>     >       table = NULL;
            \>     >     GvFreeValuesTable(bn, ports);
            \>       Bool AddToCalculationTable(GvNode *bn, GvRun *r)
            \>     >     return (r) &&
            \>     >            (r->AddNodeToCalculationTable(bn));
            \>       Bool Calculate(GvNode *bn, GvPort *port, GvRun *r, GvCalc *c)
            \>     >     if (port && (r->GetCpuID() < MAX_THREADS) && cached[r->GetCpuID()])
            \>     >       port->SetVector(cache[r->GetCpuID()], r);
            \>     >     else
            \>     >       GvPort* itport = bn->GetOutPort(0);
            \>     >       const LONG N = 7;
            \>     >       for (LONG i = 0; i < N; ++i)
            \>     >         cache[r->GetCpuID()] = Vector(i, 2*i, 3*i);
            \>     >         cached[r->GetCpuID()] = TRUE;
            \>             r->SetCalculationTable(table);
            \>     >         itport->SetRecalculate(r, TRUE);
            \>     >         r->CalculateTable(c);
            \>     >       r->SetCalculationTable(table);
            \>     >       itport->SetRecalculate(r,TRUE);
            \>     >       table->ResetTable(r);
            \>     >     return TRUE;
            \>       static NodeData* Alloc(void) { return gNew GvTestIterator; }
            \>     Bool RegisterGvTestIterator()
            \>     >   return GvRegisterOperatorPlugin(
            \>     >     GVTESTITERATOR_ID, "Gv Test Iterator", 0,
            \>     >     GvTestIterator::Alloc, "GVtestiterator", 0,
            \>     >     ID_GV_OPCLASS_TYPE_GENERAL, ID_GV_OPGROUP_TYPE_GENERAL, 0, NULL);
            \>     // GVtestiterator.res
            \>     > CONTAINER GVtestiterator
            \>     >   NAME GVtestiterator;
            \>     >   INCLUDE GVbase;
            \>     >   GROUP ID_GVPROPERTIES
            \>     >  VECTOR GVTEST_POINTITERATOR {OUTPORT; STATICPORT; CREATEPORT; ITERATOR;}
            \>     // GVtestiterator.h
            \>     > #ifndef _GVtestiterator_H_
            \>     > #define _GVtestiterator_H_
            \>     enum
            \>     >  GVTEST_POINTITERATOR = 1010060
            \>     #endif
            \>     // GVtestiterator.str
            \>     > STRINGTABLE GVtestiterator
            \>     >   GVtestiterator "GV Test Iterator";
            \>       GVTEST_POINTITERATOR "Point iterator";
