    How to draw a Spline with BaseDraw?
    5 Posts 0 Posters 551 Views
      On 10/08/2008 at 14:47, xxxxxxxx wrote:
      Cinema 4D Version:   10.1
      I try to visualize a spline in the Draw() method of my Generator Object.
      The spline only exists in a SplineObject in my code, it's not existing in the ObjectManager or any virtual hierarchy. Is there any way to draw it in the editor?
      Using Line3D(const Vector & p1, const Vector& p2) to draw from one spline point to the next will not be very efficient, I suppose.
      Thanks for any tips!
      Greetings,
      Jack
        On 10/08/2008 at 15:12, xxxxxxxx wrote:
        Hi Jack 🙂
        Try: Bool DrawObject(BaseDrawHelp* bh, BaseObject* op, LONG drawpass)
        That helps you, to put in a BaseObject.
        bye
          Hi Jack 🙂
          That should help you.
          bye
            On 10/08/2008 at 15:53, xxxxxxxx wrote:
            Yeah, thanks 🙂
            I am sure that will help.
            But one more question:
            What if I have that SplineObject in a separate function?
            Should I store declare it as private in the class header to make it available in the Draw() method?
            Jack
              On 11/08/2008 at 07:54, xxxxxxxx wrote:
              Hi Jack,
              Yes, make a copy of your spline and put it in a private member. But be careful. You have to dealloc the obejct after deleting the object (in deconstructor).
