How to draw a Spline with BaseDraw?
On 10/08/2008 at 14:47, xxxxxxxx wrote:
Cinema 4D Version: 10.1
Platform: Windows ; Mac OSX ;
Language(s) : C++ ;---------
Hi,I try to visualize a spline in the Draw() method of my Generator Object.
The spline only exists in a SplineObject in my code, it's not existing in the ObjectManager or any virtual hierarchy. Is there any way to draw it in the editor?
Using Line3D(const Vector & p1, const Vector& p2) to draw from one spline point to the next will not be very efficient, I suppose.
Thanks for any tips!
Greetings,
Jack -
On 10/08/2008 at 15:12, xxxxxxxx wrote:
Hi Jack
Try: Bool DrawObject(BaseDrawHelp* bh, BaseObject* op, LONG drawpass)
That helps you, to put in a BaseObject.bye
Hi Jack
That should help you.bye
On 10/08/2008 at 15:53, xxxxxxxx wrote:
Yeah, thanks
I am sure that will help.But one more question:
What if I have that SplineObject in a separate function?
Should I store declare it as private in the class header to make it available in the Draw() method?Cheers,
Jack -
On 11/08/2008 at 07:54, xxxxxxxx wrote:
Hi Jack,
Yes, make a copy of your spline and put it in a private member. But be careful. You have to dealloc the obejct after deleting the object (in deconstructor).
