    Color on surface
    5 Posts 0 Posters 507 Views
      On 23/06/2008 at 09:50, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Hi Folks!
      I need your help 😉
      I'm working on an ObjectData plugin and I want to set values to an object's surface by placing a texture on it, like it is possible in MoGraphs Shader-Effector.
      In other words: i want to link a texture-tag, select the channel to be used and then calculate the color of a position on the object's surface.
      I've tried it with channel->sample and shader->sample, but both are - in my opinion - independent from the texture-projection.
      I've also tried GetSurfaceData, but it demands VolumeData, that is not available in an ObjectData plugin, i think. ...or am i totally wrong?
      I hope, this question isn't that stupid 😉 I'm such a beginner in c++...
      And i searched a long time, here in the forum, without finding a hint.
      So it would help me, if you can tell me:
      a) if it's possible at all
      b) if theres a example or forum topic i missed
      c) the general approach or/and
      d) which functions/classes i should take a closer look at.
      Any help would be very appreciated,
      Mark.
        On 24/06/2008 at 00:50, xxxxxxxx wrote:
        The forum search is your friend. It took me 3 seconds to find an according thread. 😉
        Link to other thread
          On 24/06/2008 at 01:44, xxxxxxxx wrote:
          Hello 3D Designer!
          Thank you for your answer 🙂
          But it took me half a day to find this and several similar threads 😉 ... and all didn't help me, as i explained above.
          In your linked thread "uvw" is a position on the channel, with the range 0 to 1 and not the position on the object's surface ...?
          Or do i have to convert a global position on object's surface to this "uvw" coordinates? When, how to do this according to the used texture tag and projection method?
          Mark.
            On 24/06/2008 at 01:51, xxxxxxxx wrote:
            uvw is the texture coordinate on the objects surface! Simply calculate the uv coordinates of your surface and then fill the ChannelData with it. That´s how it works, that´s how MoGraph is doing it too (I highly assume...maybe if they use a TextureTag as iunput they also take care of the projection, for this look into TexData of the docs, to see how to project the coordinates!). 🙂
              On 24/06/2008 at 12:03, xxxxxxxx wrote:
              Hello 3D Designer,
              > Quote: Simply calculate the uv coordinates of your surface and then fill the ChannelData with it.
              I'm uncomfortable to say it, but it's not so "simple" for me 😉
              Is there a chance, getting a little code-snippet, to understand how i could transfer a global position on a surface into uv coordinates ...?
              I hope this wish is not too demanding but it would help me a lot. 🙂
              Thanks for your help,
              Mark.
