    FillPortsMenu
    15 Posts 0 Posters 1.4k Views
      On 16/06/2008 at 06:32, xxxxxxxx wrote:
      Hi!
      correct me if i am wrong...
      base->GetLong(<GV_MESSAGE_FIRST_DATA_ID+0>, 0))
      The part in the angle brackets is a constant....
        On 16/06/2008 at 08:50, xxxxxxxx wrote:
        Yes sure you are right..what's wrong ?
        Jan
          On 16/06/2008 at 14:36, xxxxxxxx wrote:
          What happens?
          When I take your code and change "plussign" to + it works...
            On 17/06/2008 at 06:47, xxxxxxxx wrote:
            Yes, it may sound ridiculous but you see, in this forum editor i cannot type the "plus".
            If i do, it disappears from the text in the "Post Preview" like magic, thats why i replaced it with the "plussign", exactly as you said in your last mail.
            This may be somewhat confusing but the code works fine indeed. The node is ready.
            Thanks again.
              On 18/06/2008 at 11:43, xxxxxxxx wrote:
              Well, my node isn't quite ready...
              Now that i have added a port, how can a user remove it if he/she wants to?
              Clicking on it with the right mouse shows a disabled 'Delete Port' in the popup.
              Ok this should be done with GetDEnabling yes?
              But a GePrint shows that this function is not called at the right time.
              And if it was, how would i find the id of the 'Delete Port'. Adding a 'Delete Port' in the 'FillPortMenu' adds just another 'Delete Port'.
              Jan
                On 19/06/2008 at 23:49, xxxxxxxx wrote:
                Hi!
                I am back 🙂
                Change the settings in your res file.
                CONTAINER PythonNode
                     NAME JanaNode;
                     INCLUDE GVbase;
                GROUP ID_GVPORTS
                          LONG in_long {INPORT;}
                Add CREATEPORT, MULTIPLE, etc...depends on what you need.
                  On 20/06/2008 at 04:33, xxxxxxxx wrote:
                  Mmmm, you're an expert Shawni. Respect.
                  I had defined my ports as {INPORT; STATICPORT;}
                  Thanks a million.
                  Regards,
                  Jan
                    On 20/06/2008 at 05:38, xxxxxxxx wrote:
                    Hi!
                    nice to see that it works.
                    In your case: Do you mix "Createport" and "Multiple"?
                    bye
                      On 21/06/2008 at 09:18, xxxxxxxx wrote:
                      Well, eeeeh, i use neither...
                      You mean in the iCreate or in the res file or something?
                      I Just create a node from scratch. And it works.
                      Hey, do yo know a way to find out when an object from the Object manager is dropped into the XPresso Editor, and when   a connection is made (wire)?
                      I need to trace the connection from my node all the way to a (direct or indirect) connected object(s).
                      Jan
                        On 21/06/2008 at 11:09, xxxxxxxx wrote:
                        hi!
                        Create an object input-port. Use "GVGENERALOBJECT" in your res file.
                        In the calculate file, get the BaseLink2D from the port and cast it to an BaseObject.
                        bye
                          On 21/06/2008 at 13:27, xxxxxxxx wrote:
                          hi Shawni,
                          You mention a 'BaseLink2D' but you mean a 'BaseList2D'?
                          I know, but that delivers only a directly connected node. Of course you could follow the chain forward to an object, but i think i prefer a message when an object from the manager is dropped. Something like a DRAG_RECEIVE, but then for the XPresso editor.
                          What i need is to get a pointer to the object that is the final target of my node, although several nodes might or might not be in between me and my target.
                          Jan
                            On 22/06/2008 at 02:04, xxxxxxxx wrote:
                            Hi!
                            I'm sorry. I ment a BaseLink, not a BaseLink2D.
                            You could listen for CoreMessage(). Perhaps you receive your Drag_Receive.
                            Print out the id and check the constant.
                            bye.
                            p.s. if you have information about getting objects, please let me know.
