Inserting a custom tag & more
On 13/04/2008 at 15:32, xxxxxxxx wrote:
Cinema 4D Version: 10.111
Platform: Windows ; Mac ; Mac OSX ;
Language(s) : C++ ;---------
Hi,I want to make a command plugin that does the following things.
1. Insert two objects into the scene
I already managed to do this. No problem.2. Attach a tag to one of the objects
How do I do this? The tag I want to attach is an Expression Tag plugin that I made myself.3. Link the 2nd object in a link field in the 1st object
The first object (it's a Generator Object plugin that I made myself) has some link fields in its description. I want to link the 2nd object in one of these link fields. How do I do that?Once again, thanks in advance!
Greetings,
Jack -
On 13/04/2008 at 20:20, xxxxxxxx wrote:
2. Create the tag using BaseObject::MakeTag([insert PluginID here]). If you want to create undos as well, do it this way:
BaseTag* tag = PluginTag::Alloc([insert PluginID here]);
if (!tag) // error;
baseObject->InsertTag(tag);
baseDocument->AddUndo(UNDO_NEW, tag);3. Get the first object's BaseContainer and set the link:
BaseContainer* bc = obj->GetDataInstance().
if (bc) bc->SetLink([LINK_ID], secobj);Replace [LINK_ID] with the LINK id from the object's res description file.
On 14/04/2008 at 00:04, xxxxxxxx wrote:
Way cool, thank you very much!
Just one additional question:
Can I also create an UNDO for the complete action (create object + create object + create tag + link object)?Best regards,
Jack -
On 14/04/2008 at 00:53, xxxxxxxx wrote:
Btw. you can use MakeTag() to attach tags to objects.
\> doc->StartUndo(); \> \> BaseTag \*tag = NULL; \> tag = op->MakeTag(PLUGIN_ID); \> if(!tag) return FALSE; \> \> doc->AddUndo(UNDO_NEW, tag); \> \> doc->AddUndo(UNDO_CHANGE, tag); \> \> BaseContainer \*bc = tag->GetDataInstance(); \> bc->SetLink(LINK_ID, op2); \> \> doc->EndUndo(); \>cheers,
Matthias -
On 14/04/2008 at 01:24, xxxxxxxx wrote:
Perfect. That makes it even easier.
Thanks!
Greetings,
Jack
