    Inserting a custom tag & more
    5 Posts 0 Posters 583 Views
      On 13/04/2008 at 15:32, xxxxxxxx wrote:
      Cinema 4D Version:   10.111
      I want to make a command plugin that does the following things.
      1. Insert two objects into the scene
      I already managed to do this. No problem.
      2. Attach a tag to one of the objects
      How do I do this? The tag I want to attach is an Expression Tag plugin that I made myself.
      3. Link the 2nd object in a link field in the 1st object
      The first object (it's a Generator Object plugin that I made myself) has some link fields in its description. I want to link the 2nd object in one of these link fields. How do I do that?
      Once again, thanks in advance!
      Greetings,
      Jack
        On 13/04/2008 at 20:20, xxxxxxxx wrote:
        2. Create the tag using BaseObject::MakeTag([insert PluginID here]). If you want to create undos as well, do it this way:
        BaseTag* tag = PluginTag::Alloc([insert PluginID here]);
        if (!tag) // error;
        baseObject->InsertTag(tag);
        baseDocument->AddUndo(UNDO_NEW, tag);
        3. Get the first object's BaseContainer and set the link:
        BaseContainer* bc = obj->GetDataInstance().
        if (bc) bc->SetLink([LINK_ID], secobj);
        Replace [LINK_ID] with the LINK id from the object's res description file.
          On 14/04/2008 at 00:04, xxxxxxxx wrote:
          Way cool, thank you very much!
          Just one additional question:
          Can I also create an UNDO for the complete action (create object + create object + create tag + link object)?
          Best regards,
          Jack
            On 14/04/2008 at 00:53, xxxxxxxx wrote:
            Btw. you can use MakeTag() to attach tags to objects.
            > \> doc->StartUndo(); \> \> BaseTag \*tag = NULL; \> tag = op->MakeTag(PLUGIN_ID); \> if(!tag) return FALSE; \> \> doc->AddUndo(UNDO_NEW, tag); \> \> doc->AddUndo(UNDO_CHANGE, tag); \> \> BaseContainer \*bc = tag->GetDataInstance(); \> bc->SetLink(LINK_ID, op2); \> \> doc->EndUndo(); \>
              On 14/04/2008 at 01:24, xxxxxxxx wrote:
              Perfect. That makes it even easier.
              Thanks!
              Greetings,
              Jack
