    bitmap button madness
    18 Posts 0 Posters 1.4k Views
      On 29/03/2008 at 13:33, xxxxxxxx wrote:
      Try this in the str file and see if it helps:
      STRINGTABLE Tmyplugintag
           Tmyplugintag               "My Plugin Tag";
      That is, remove the text associated with the bitmap button.
      See if SetDParameter() and GetDParameter() ever get called with IMAGINARY_PREVIEW id (doing a GePrint() is simple enough here). Also check that the code is executed in Message() and that the filename actually exists - you can do this:
      Filename bg = GeGetPluginPath()+Filename("res")+Filename("imaginary.tif");
      if (!GeFExist(bg)) GePrint("File Not Found!");
      I have to admit that I've never tried displaying a bitmap button in the AM before (except via a Tool plugin which uses a SubDialog to display AM elements) - mainly because there hasn't been a need for it.
        On 29/03/2008 at 13:58, xxxxxxxx wrote:
        ok, after debugging my brain it works now. even though i KNOW i changed the filename to "imaginary.tif" it somehow changed back to "lookatcamera.tif". i guess programming at 5am is not the best approach 😄
        so here i stand a bit embarrassed and deeply thankful for your time. at least i am sure of this: it won't be my last question 😄
        thanks again and now to something completely different:
        trying to get a dropdown/cycle description to work....
        cu later,
        Yakuza
          On 29/03/2008 at 15:05, xxxxxxxx wrote:
          dropdown/cycle is easy:
          1. Set the type as LONG.
          2. In the res file, add a CYCLE section inside the LONG description (for example) :
          // Rotation Order
          LONG          IPP_RORDER
               ANIM OFF;
               CYCLE
                    IPP_RORDER_NONE;
                    IPP_RORDER_XYZ;
                    IPP_RORDER_XZY;
                    IPP_RORDER_YXZ;
                    IPP_RORDER_YZX;
                    IPP_RORDER_ZXY;
                    IPP_RORDER_ZYX;
          The cycle values should be enumerated in the Tmyplugintag.h file and numbered from 0 to N-1 (where N is the number of choices). The text in the Tmyplugintag.str file.
          If you need 'dynamic' dropdown elements (names and/or counts will change), you'll need to do this in GetDDescription() and omit the CYCLE section from the res file.
            On 29/03/2008 at 16:21, xxxxxxxx wrote:
            oh, thanks, that was not actually a question, but now that you answered it works fine ;D
            anyway, i'm still having some troubles updating the bitmapbutton. i am trying to load a movie frame from the movie given in the filename description. unfortunately its not showing up using:
            Bool bool_p= TRUE;
            if(bm->Init(bg, 1, &bool;_p) == IMAGE_OK)
            GePrint("IMAGE_OK " + LongToString(bool_p));
            it prints IMAGE_OK and confirms its a movie when it is one. also having issues resizing it.
            i will try some stuff and ask again tomorrow slightly more detailed if i can't get this right too.
            Yakuza
              On 29/03/2008 at 17:50, xxxxxxxx wrote:
              yeah, i got it, just don't get how i did it ;D
                On 30/03/2008 at 07:45, xxxxxxxx wrote:
                well, next question. my problem is to update the bitmapbutton. it should show the file in the filename description but only does that when the button is pressed. how to fake pushing the button when the filename is changed? with a message? i tried but no success.
                thank you for your ideas.
                Yakuza
                  On 31/03/2008 at 06:42, xxxxxxxx wrote:
                  The dirty parameter of the BitmapButtonStruct should be increased for every update.
                  Btw. there are lots of old threads about BitmapButtons on the forum where you can find most of this stuff explained.
                    On 01/04/2008 at 10:47, xxxxxxxx wrote:
                    hi matthias,
                    if these threads or the sdk documentation would have helped i certainly would not post my questions here 🙂
                    the hint with the incrementation of the dirty parameter was indeed very helpful, my bitmapbutton finally works as intended. thank you very much again.
                    Yakuza
                      On 10/07/2009 at 12:45, xxxxxxxx wrote:
                      Hey guys...
                      I must be missing something... I got the above example type code to work and my buttons display fine now.  I also added the "BUTTON" attribute in the .res file so I can see it push in and pop back out as I click on it, but...
                      The problem is that I'm not getting any MSG_DESCRIPTION_COMMAND message when I click on one of these (I do get notified for some regular text-based buttons in the same description).
                      Any ideas?
                      Thanks.
                        On 10/07/2009 at 12:57, xxxxxxxx wrote:
                        Ignore the above... the answer is in this thread.
