    BitmapButton in Descriptions Events
    2 Posts 0 Posters 794 Views
    • H Offline
      Helper
      On 14/07/2004 at 13:01, xxxxxxxx wrote:
      Cinema 4D Version:   8.503
      Platform:
      Hi!
      I have a number of Bitmapbuttons in the Description of a Generator Object and I would like to catch the Events when they are pressed down.
      Some posts on Bitmapbuttons suggest it works to listen for the MSG_DESCRIPTION_COMMAND Message, when the Bitmapbutton is set to BUTTON in the Resource file, but this Message does not appear to be sent.
      Also there is a function in the BitmapButton CustomGUI to set a callback, but I don't know how to set it when I use the BitmapButton in a Resource. How do I get to the pointer to the actual BitmapButtonCustomGui?
      Any help would be greatly appreciated!
      Best Regards
      Timm Dapper
      • H Offline
        Helper
        On 20/07/2004 at 02:12, xxxxxxxx wrote:
        Sorry if any previous post was misleading. The messaging works slightly differently for bitmap buttons. This is how you would detect it:
            Bool MyNode::SetDParameter(GeListNode *node, const DescID &id, const GeData &t_data, LONG &flags)
              switch(id[0].id)
              case BITMAPBUTTON_ID:
                  if (flags&DESCFLAGS_USERINTERACTION)
                    /// user clicked on button
                  break;
              return ObjectData::SetDParameter(node, id, t_data, flags);
