    VPBuffers
    28 Posts 0 Posters 17.1k Views
      On 27/08/2007 at 03:17, xxxxxxxx wrote:
      Here's how to browse through a multipass bitmap. For lights there is an inner loop that retrieves the data.
      The main bitmap should be checked with bmp->IsMultipassBitmap() first and then casted into a (MultipassBitmap* )
           LONG j,i,id;
           LONG cnt = b3d->GetLayerCount();
           for (i=0; i<cnt; i++)
                MultipassBitmap *sublayer,*layer = b3d->GetLayerNum(i);
                if (!layer) continue;
                LONG subcnt = layer->GetLayerCount();
                for (j=0;j<subcnt || subcnt==-1;j++)
                     if (subcnt>0)
                          sublayer   = layer->GetLayerNum(j);
                     else
                          sublayer = layer;
                     if (!sublayer) continue;
                     id = sublayer->GetParameter(MPB_USERID).GetLong();
        On 27/08/2007 at 10:47, xxxxxxxx wrote:
        Thanks Philip,
        but what do you mean about main bitmap?
        do i need to get it from Multipass::VPBitmap[0]?
        Renato
          On 28/08/2007 at 12:26, xxxxxxxx wrote:
          You can retrieve the main bitmap by calling
          MultipassBitmap *mpb = (MultipassBitmap* )renderinstance->GetBuffer(NOTOK,0);
            On 29/08/2007 at 08:49, xxxxxxxx wrote:
            Hello Philip,
            where:
            subcnt always is -1 so the internal cycle go in loop forewer.
            What's mean that GetLayerCount() return -1 ?
            cheers
            Renato
              On 29/08/2007 at 11:08, xxxxxxxx wrote:
              But Philip did this in his loop:
              Probably explicitly to avoid the infinite loop. No idea about what -1 represents here though.
                On 29/08/2007 at 11:35, xxxxxxxx wrote:
                Hello dear Robert,
                but when the subcnt == -1.. it loop
                renato
                  On 29/08/2007 at 12:29, xxxxxxxx wrote:
                  Are you sure of your types (LONG)? In actuality, all that is needed is:
                  for (j = 0; j < subcnt; ++j)
                  Since -1L is less than 0L, the loop should exit immediately. But if ULONG is used, -1L is of course 4 billion.
                  All else failing, just check for -1 on subcnt and avoid the loop altogether:
                  if (subcnt < 0)     continue;
                  for (j=0; j!=subcnt; ++j)
                    On 30/08/2007 at 01:54, xxxxxxxx wrote:
                    My excuses... one line of source code was missing!
                         LONG j,i,id;
                                   if (subcnt>0)
                                   else
                                        sublayer = layer;
                                   if (subcnt==-1) break;
                      On 30/08/2007 at 11:10, xxxxxxxx wrote:
                      Hello Philip,
                      ok now 🙂 but the objectID are the only buffers not detected with this way 😞
                      any suggestions?
                      Renato
                        On 30/08/2007 at 14:25, xxxxxxxx wrote:
                        To retrieve the alpha channels use:
                        cnt = b3d->GetAlphaLayerCount();
                             B3dBitmap *layer = b3d->GetAlphaLayerNum(i);
                             if (!id) continue;
                          On 30/08/2007 at 14:26, xxxxxxxx wrote:
                          Ah.. thanks.. i forgot that ObjectID are in fact alpha channels 🙂
                          Thanks a lot
                          Renato
