    VPBuffers
    28 Posts 0 Posters 17.1k Views
      On 31/07/2007 at 08:16, xxxxxxxx wrote:
      i need to find all the VPBuffer opened by multipass. So i can fire pixels from vray to them 🙂
      So i need them in Execute..
      Renato
        On 22/08/2007 at 19:11, xxxxxxxx wrote:
        Hi all,
        Here the scene that i've examined:
        i wrote this piece of code looking for the separate light pass:
        LONG *remapVpBuffers = (LONG* ) GeAlloc (sizeof(LONG)*33);
                  String *remapStrings = (String* ) GeAlloc (sizeof(String)*33);
                  remapVpBuffers[0]      = VPBUFFER_RGBA;
                  remapVpBuffers[1]      = VPBUFFER_AMBIENT;
                  remapVpBuffers[2]      = VPBUFFER_DIFFUSE;
                  remapVpBuffers[3]      = VPBUFFER_SPECULAR;
                  remapVpBuffers[4]      = VPBUFFER_SHADOW;
                  remapVpBuffers[5]      = VPBUFFER_REFLECTION;
                  remapVpBuffers[6]      = VPBUFFER_TRANSPARENCY;
                  remapVpBuffers[7]      = VPBUFFER_RADIOSITY;
                  remapVpBuffers[8]      = VPBUFFER_CAUSTICS;
                  remapVpBuffers[9]      = VPBUFFER_ATMOSPHERE;
                  remapVpBuffers[10]      = VPBUFFER_ATMOSPHERE_MUL;
                  remapVpBuffers[11]      = VPBUFFER_ALLPOSTEFFECTS;
                  remapVpBuffers[12]      = VPBUFFER_IMAGEBUILDING_PASS;
                  remapVpBuffers[13]      = VPBUFFER_DEPTH;
                  remapVpBuffers[14]      = VPBUFFER_MAT_COLOR;
                  remapVpBuffers[15]      = VPBUFFER_MAT_DIFFUSION;
                  remapVpBuffers[16]      = VPBUFFER_MAT_LUMINANCE;
                  remapVpBuffers[17]      = VPBUFFER_MAT_TRANSPARENCY;
                  remapVpBuffers[18]      = VPBUFFER_MAT_REFLECTION;
                  remapVpBuffers[19]      = VPBUFFER_MAT_ENVIRONMENT;
                  remapVpBuffers[20]      = VPBUFFER_MAT_SPECULAR;
                  remapVpBuffers[21]      = VPBUFFER_MAT_SPECULARCOLOR;
                  remapVpBuffers[22]      = VPBUFFER_ILLUMINATION;
                  remapVpBuffers[23]      = VPBUFFER_OBJECTBUFFER;
                  remapVpBuffers[24]      = VPBUFFER_POSTEFFECT;
                  remapVpBuffers[25]      = VPBUFFER_POSTEFFECT_MUL;
                  remapVpBuffers[26]      = VPBUFFER_AMBIENTOCCLUSION;
                  remapVpBuffers[27]      = VPBUFFER_MAT_NORMAL;
                  remapVpBuffers[28]      = VPBUFFER_MAT_UV;
                  remapVpBuffers[29]      = VPBUFFER_MOTIONVECTOR;
                  remapVpBuffers[30]      = VPBUFFER_BLEND;
                  remapVpBuffers[31]      = VPBUFFER_LIGHTBLEND;
                  remapVpBuffers[32]      = VPBUFFER_ALPHA;
                  remapStrings[0]      = "VPBUFFER_RGBA";
                  remapStrings[1]      = "VPBUFFER_AMBIENT";
                  remapStrings[2]      = "VPBUFFER_DIFFUSE";
                  remapStrings[3]      = "VPBUFFER_SPECULAR";
                  remapStrings[4]      = "VPBUFFER_SHADOW";
                  remapStrings[5]      = "VPBUFFER_REFLECTION";
                  remapStrings[6]      = "VPBUFFER_TRANSPARENCY";
                  remapStrings[7]      = "VPBUFFER_RADIOSITY";
                  remapStrings[8]      = "VPBUFFER_CAUSTICS";
                  remapStrings[9]      = "VPBUFFER_ATMOSPHERE";
                  remapStrings[10]      = "VPBUFFER_ATMOSPHERE_MUL";
                  remapStrings[11]      = "VPBUFFER_ALLPOSTEFFECTS";
                  remapStrings[12]      = "VPBUFFER_IMAGEBUILDING_PASS";
                  remapStrings[13]      = "VPBUFFER_DEPTH";
                  remapStrings[14]      = "VPBUFFER_MAT_COLOR";
                  remapStrings[15]      = "VPBUFFER_MAT_DIFFUSION";
                  remapStrings[16]      = "VPBUFFER_MAT_LUMINANCE";
                  remapStrings[17]      = "VPBUFFER_MAT_TRANSPARENCY";
                  remapStrings[18]      = "VPBUFFER_MAT_REFLECTION";
                  remapStrings[19]      = "VPBUFFER_MAT_ENVIRONMENT";
                  remapStrings[20]      = "VPBUFFER_MAT_SPECULAR";
                  remapStrings[21]      = "VPBUFFER_MAT_SPECULARCOLOR";
                  remapStrings[22]      = "VPBUFFER_ILLUMINATION";
                  remapStrings[23]      = "VPBUFFER_OBJECTBUFFER";
                  remapStrings[24]      = "VPBUFFER_POSTEFFECT";
                  remapStrings[25]      = "VPBUFFER_POSTEFFECT_MUL";
                  remapStrings[26]      = "VPBUFFER_AMBIENTOCCLUSION";
                  remapStrings[27]      = "VPBUFFER_MAT_NORMAL";
                  remapStrings[28]      = "VPBUFFER_MAT_UV";
                  remapStrings[29]      = "VPBUFFER_MOTIONVECTOR";
                  remapStrings[30]      = "VPBUFFER_BLEND";
                  remapStrings[31]      = "VPBUFFER_LIGHTBLEND";
                  remapStrings[32]      = "VPBUFFER_ALPHA";
                  GePrint ("************************************************");
                  VPBuffer *Buffer=NULL;
                  for (LONG lb=0; lb<33; lb++){
                       for (LONG subId = 0; subId<50; subId++) {
                            Buffer = render->GetBuffer(remapVpBuffers[lb],subId);
                            if (Buffer) {
                                 GePrint("Buf: " + remapStrings[lb]+ "   SubId: " + LongToString(subId));
                                 if (lb == 0) break;
        gefree etc.etc.etc..
        Now..why all others lights layers are not in the list?
        Thanks all
        Renato
          On 24/08/2007 at 17:33, xxxxxxxx wrote:
            On 25/08/2007 at 11:34, xxxxxxxx wrote:
            Matthias won't be back until tomorrow so hold tight! 🙂
              On 25/08/2007 at 13:46, xxxxxxxx wrote:
              Thanks Robert 🙂
              Can't you help me on this?
              Renato
                On 25/08/2007 at 14:36, xxxxxxxx wrote:
                I don't know anything about VPBuffers.
                  On 27/08/2007 at 03:17, xxxxxxxx wrote:
                  Here's how to browse through a multipass bitmap. For lights there is an inner loop that retrieves the data.
                  The main bitmap should be checked with bmp->IsMultipassBitmap() first and then casted into a (MultipassBitmap* )
                       LONG j,i,id;
                       LONG cnt = b3d->GetLayerCount();
                       for (i=0; i<cnt; i++)
                            MultipassBitmap *sublayer,*layer = b3d->GetLayerNum(i);
                            if (!layer) continue;
                            LONG subcnt = layer->GetLayerCount();
                            for (j=0;j<subcnt || subcnt==-1;j++)
                                 if (subcnt>0)
                                      sublayer   = layer->GetLayerNum(j);
                                 else
                                      sublayer = layer;
                                 if (!sublayer) continue;
                                 id = sublayer->GetParameter(MPB_USERID).GetLong();
                    On 27/08/2007 at 10:47, xxxxxxxx wrote:
                    Thanks Philip,
                    but what do you mean about main bitmap?
                    do i need to get it from Multipass::VPBitmap[0]?
                    Renato
                      On 28/08/2007 at 12:26, xxxxxxxx wrote:
                      You can retrieve the main bitmap by calling
                      MultipassBitmap *mpb = (MultipassBitmap* )renderinstance->GetBuffer(NOTOK,0);
                        On 29/08/2007 at 08:49, xxxxxxxx wrote:
                        Hello Philip,
                        where:
                        subcnt always is -1 so the internal cycle go in loop forewer.
                        What's mean that GetLayerCount() return -1 ?
                        cheers
                        Renato
                          On 29/08/2007 at 11:08, xxxxxxxx wrote:
                          But Philip did this in his loop:
                          Probably explicitly to avoid the infinite loop. No idea about what -1 represents here though.
                            On 29/08/2007 at 11:35, xxxxxxxx wrote:
                            Hello dear Robert,
                            but when the subcnt == -1.. it loop
                            renato
                              On 29/08/2007 at 12:29, xxxxxxxx wrote:
                              Are you sure of your types (LONG)? In actuality, all that is needed is:
                              for (j = 0; j < subcnt; ++j)
                              Since -1L is less than 0L, the loop should exit immediately. But if ULONG is used, -1L is of course 4 billion.
                              All else failing, just check for -1 on subcnt and avoid the loop altogether:
                              if (subcnt < 0)     continue;
                              for (j=0; j!=subcnt; ++j)
                                On 30/08/2007 at 01:54, xxxxxxxx wrote:
                                My excuses... one line of source code was missing!
                                     LONG j,i,id;
                                               if (subcnt>0)
                                               else
                                                    sublayer = layer;
                                               if (subcnt==-1) break;
                                  On 30/08/2007 at 11:10, xxxxxxxx wrote:
                                  Hello Philip,
                                  ok now 🙂 but the objectID are the only buffers not detected with this way 😞
                                  any suggestions?
                                  Renato
                                    On 30/08/2007 at 14:25, xxxxxxxx wrote:
                                    To retrieve the alpha channels use:
                                    cnt = b3d->GetAlphaLayerCount();
                                         B3dBitmap *layer = b3d->GetAlphaLayerNum(i);
                                         if (!id) continue;
                                      On 30/08/2007 at 14:26, xxxxxxxx wrote:
                                      Ah.. thanks.. i forgot that ObjectID are in fact alpha channels 🙂
                                      Thanks a lot
                                      Renato
