    VPBuffers
    28 Posts 0 Posters 16.8k Views
      On 23/06/2007 at 08:52, xxxxxxxx wrote:
      Any help?
      Renato
        On 25/06/2007 at 11:16, xxxxxxxx wrote:
          On 29/06/2007 at 10:43, xxxxxxxx wrote:
          Maybe that my question is wrong?
          Renato
            On 02/07/2007 at 03:17, xxxxxxxx wrote:
            sorry, I can't quite follow you here. you only get a shdow, diffuse and specular pass for each light and an alpha pass for each object id. do you want access to these passes?
              On 02/07/2007 at 16:41, xxxxxxxx wrote:
              Sure.. 🙂
              Renato
                On 29/07/2007 at 19:04, xxxxxxxx wrote:
                > cheers,
                > Matthias
                Please!
                28 days 😞
                  On 30/07/2007 at 01:36, xxxxxxxx wrote:
                  Hi Renato,
                  Please ask your questions in a way I can follow you. What is it you want to achieve? From your last reply I was assuming the problem has been resolved. We both are not native English spekaers so please try to word your questions are bit more clearly.
                    On 30/07/2007 at 04:33, xxxxxxxx wrote:
                    Hello Matthias,
                    what i need is get all vpbuffer in the best way.
                    I'm getting now the basic vpbuffer from render.. but seem that is better to get all them from Multipass..
                    Any suggestions?
                    Renato
                      On 31/07/2007 at 02:41, xxxxxxxx wrote:
                      I am not sure but could you not get all the information from the Multipass structure found in the PixelPost structure?
                        On 31/07/2007 at 07:35, xxxxxxxx wrote:
                        Do you need the passes after or during rendering?
                          On 31/07/2007 at 08:16, xxxxxxxx wrote:
                          i need to find all the VPBuffer opened by multipass. So i can fire pixels from vray to them 🙂
                          So i need them in Execute..
                          Renato
                            On 22/08/2007 at 19:11, xxxxxxxx wrote:
                            Hi all,
                            Here the scene that i've examined:
                            i wrote this piece of code looking for the separate light pass:
                            LONG *remapVpBuffers = (LONG* ) GeAlloc (sizeof(LONG)*33);
                                      String *remapStrings = (String* ) GeAlloc (sizeof(String)*33);
                                      remapVpBuffers[0]      = VPBUFFER_RGBA;
                                      remapVpBuffers[1]      = VPBUFFER_AMBIENT;
                                      remapVpBuffers[2]      = VPBUFFER_DIFFUSE;
                                      remapVpBuffers[3]      = VPBUFFER_SPECULAR;
                                      remapVpBuffers[4]      = VPBUFFER_SHADOW;
                                      remapVpBuffers[5]      = VPBUFFER_REFLECTION;
                                      remapVpBuffers[6]      = VPBUFFER_TRANSPARENCY;
                                      remapVpBuffers[7]      = VPBUFFER_RADIOSITY;
                                      remapVpBuffers[8]      = VPBUFFER_CAUSTICS;
                                      remapVpBuffers[9]      = VPBUFFER_ATMOSPHERE;
                                      remapVpBuffers[10]      = VPBUFFER_ATMOSPHERE_MUL;
                                      remapVpBuffers[11]      = VPBUFFER_ALLPOSTEFFECTS;
                                      remapVpBuffers[12]      = VPBUFFER_IMAGEBUILDING_PASS;
                                      remapVpBuffers[13]      = VPBUFFER_DEPTH;
                                      remapVpBuffers[14]      = VPBUFFER_MAT_COLOR;
                                      remapVpBuffers[15]      = VPBUFFER_MAT_DIFFUSION;
                                      remapVpBuffers[16]      = VPBUFFER_MAT_LUMINANCE;
                                      remapVpBuffers[17]      = VPBUFFER_MAT_TRANSPARENCY;
                                      remapVpBuffers[18]      = VPBUFFER_MAT_REFLECTION;
                                      remapVpBuffers[19]      = VPBUFFER_MAT_ENVIRONMENT;
                                      remapVpBuffers[20]      = VPBUFFER_MAT_SPECULAR;
                                      remapVpBuffers[21]      = VPBUFFER_MAT_SPECULARCOLOR;
                                      remapVpBuffers[22]      = VPBUFFER_ILLUMINATION;
                                      remapVpBuffers[23]      = VPBUFFER_OBJECTBUFFER;
                                      remapVpBuffers[24]      = VPBUFFER_POSTEFFECT;
                                      remapVpBuffers[25]      = VPBUFFER_POSTEFFECT_MUL;
                                      remapVpBuffers[26]      = VPBUFFER_AMBIENTOCCLUSION;
                                      remapVpBuffers[27]      = VPBUFFER_MAT_NORMAL;
                                      remapVpBuffers[28]      = VPBUFFER_MAT_UV;
                                      remapVpBuffers[29]      = VPBUFFER_MOTIONVECTOR;
                                      remapVpBuffers[30]      = VPBUFFER_BLEND;
                                      remapVpBuffers[31]      = VPBUFFER_LIGHTBLEND;
                                      remapVpBuffers[32]      = VPBUFFER_ALPHA;
                                      remapStrings[0]      = "VPBUFFER_RGBA";
                                      remapStrings[1]      = "VPBUFFER_AMBIENT";
                                      remapStrings[2]      = "VPBUFFER_DIFFUSE";
                                      remapStrings[3]      = "VPBUFFER_SPECULAR";
                                      remapStrings[4]      = "VPBUFFER_SHADOW";
                                      remapStrings[5]      = "VPBUFFER_REFLECTION";
                                      remapStrings[6]      = "VPBUFFER_TRANSPARENCY";
                                      remapStrings[7]      = "VPBUFFER_RADIOSITY";
                                      remapStrings[8]      = "VPBUFFER_CAUSTICS";
                                      remapStrings[9]      = "VPBUFFER_ATMOSPHERE";
                                      remapStrings[10]      = "VPBUFFER_ATMOSPHERE_MUL";
                                      remapStrings[11]      = "VPBUFFER_ALLPOSTEFFECTS";
                                      remapStrings[12]      = "VPBUFFER_IMAGEBUILDING_PASS";
                                      remapStrings[13]      = "VPBUFFER_DEPTH";
                                      remapStrings[14]      = "VPBUFFER_MAT_COLOR";
                                      remapStrings[15]      = "VPBUFFER_MAT_DIFFUSION";
                                      remapStrings[16]      = "VPBUFFER_MAT_LUMINANCE";
                                      remapStrings[17]      = "VPBUFFER_MAT_TRANSPARENCY";
                                      remapStrings[18]      = "VPBUFFER_MAT_REFLECTION";
                                      remapStrings[19]      = "VPBUFFER_MAT_ENVIRONMENT";
                                      remapStrings[20]      = "VPBUFFER_MAT_SPECULAR";
                                      remapStrings[21]      = "VPBUFFER_MAT_SPECULARCOLOR";
                                      remapStrings[22]      = "VPBUFFER_ILLUMINATION";
                                      remapStrings[23]      = "VPBUFFER_OBJECTBUFFER";
                                      remapStrings[24]      = "VPBUFFER_POSTEFFECT";
                                      remapStrings[25]      = "VPBUFFER_POSTEFFECT_MUL";
                                      remapStrings[26]      = "VPBUFFER_AMBIENTOCCLUSION";
                                      remapStrings[27]      = "VPBUFFER_MAT_NORMAL";
                                      remapStrings[28]      = "VPBUFFER_MAT_UV";
                                      remapStrings[29]      = "VPBUFFER_MOTIONVECTOR";
                                      remapStrings[30]      = "VPBUFFER_BLEND";
                                      remapStrings[31]      = "VPBUFFER_LIGHTBLEND";
                                      remapStrings[32]      = "VPBUFFER_ALPHA";
                                      GePrint ("************************************************");
                                      VPBuffer *Buffer=NULL;
                                      for (LONG lb=0; lb<33; lb++){
                                           for (LONG subId = 0; subId<50; subId++) {
                                                Buffer = render->GetBuffer(remapVpBuffers[lb],subId);
                                                if (Buffer) {
                                                     GePrint("Buf: " + remapStrings[lb]+ "   SubId: " + LongToString(subId));
                                                     if (lb == 0) break;
                            gefree etc.etc.etc..
                            Now..why all others lights layers are not in the list?
                            Thanks all
                            Renato
                              On 24/08/2007 at 17:33, xxxxxxxx wrote:
                                On 25/08/2007 at 11:34, xxxxxxxx wrote:
                                Matthias won't be back until tomorrow so hold tight! 🙂
                                  On 25/08/2007 at 13:46, xxxxxxxx wrote:
                                  Thanks Robert 🙂
                                  Can't you help me on this?
                                  Renato
                                    On 25/08/2007 at 14:36, xxxxxxxx wrote:
                                    I don't know anything about VPBuffers.
                                      On 27/08/2007 at 03:17, xxxxxxxx wrote:
                                      Here's how to browse through a multipass bitmap. For lights there is an inner loop that retrieves the data.
                                      The main bitmap should be checked with bmp->IsMultipassBitmap() first and then casted into a (MultipassBitmap* )
                                           LONG j,i,id;
                                           LONG cnt = b3d->GetLayerCount();
                                           for (i=0; i<cnt; i++)
                                                MultipassBitmap *sublayer,*layer = b3d->GetLayerNum(i);
                                                if (!layer) continue;
                                                LONG subcnt = layer->GetLayerCount();
                                                for (j=0;j<subcnt || subcnt==-1;j++)
                                                     if (subcnt>0)
                                                          sublayer   = layer->GetLayerNum(j);
                                                     else
                                                          sublayer = layer;
                                                     if (!sublayer) continue;
                                                     id = sublayer->GetParameter(MPB_USERID).GetLong();
                                        On 27/08/2007 at 10:47, xxxxxxxx wrote:
                                        Thanks Philip,
                                        but what do you mean about main bitmap?
                                        do i need to get it from Multipass::VPBitmap[0]?
                                        Renato
                                          On 28/08/2007 at 12:26, xxxxxxxx wrote:
                                          You can retrieve the main bitmap by calling
                                          MultipassBitmap *mpb = (MultipassBitmap* )renderinstance->GetBuffer(NOTOK,0);
                                            On 29/08/2007 at 08:49, xxxxxxxx wrote:
                                            Hello Philip,
                                            where:
                                            subcnt always is -1 so the internal cycle go in loop forewer.
                                            What's mean that GetLayerCount() return -1 ?
                                            cheers
                                            Renato
