    Sampling Shader
    21 Posts 0 Posters 13.2k Views
      On 08/01/2007 at 09:12, xxxxxxxx wrote:
      .. i hope that from today the maxon support will be operative... 🙂
      Renato
        On 11/01/2007 at 11:45, xxxxxxxx wrote:
        Sorry for the delay. Shouldn't that be GetChannel(CHANNEL_COLOR) and not GetChannel(NULL), if your plugin shader is in the color channel for example? Then you should be able to use BaseChannel::Sample(), I think. As Katachi says, this is the only function that will allow you to sample an arbitrary point.
          On 11/01/2007 at 11:51, xxxxxxxx wrote:
          Hi Mikael,
          It work also with a Custom Material?
          Renato
            On 11/01/2007 at 12:06, xxxxxxxx wrote:
            No, for PluginMaterial (if that's what you mean) there are only the BaseMaterial sampling functions, afaics, for example CalcSurface().
              On 11/01/2007 at 12:33, xxxxxxxx wrote:
              Mikael,
              i only need to sample shader color of each custom "channel".
              There is a Vray Material with some shaderlink inside.
              Some for diffuse, some for specular, mirror, glass etc.
              I see that there are no problems to sample each shader linked in it.. but i need to know how to pass and retrieve UVW or 3D coordinate to the shaders.
              Renato
                On 18/01/2007 at 00:02, xxxxxxxx wrote:
                Hm, it looks like that's a limitation of accessing the shaders directly, without access to their channels. But perhaps you could clone the shaders and insert them into dummy BaseChannels in order to call BaseChannel::Sample?
                  On 18/01/2007 at 06:13, xxxxxxxx wrote:
                  when rendering? uhm..
                  let me think about it.
                  Renato
                    On 18/01/2007 at 12:41, xxxxxxxx wrote:
                    Yeah. Preferably as a pre-step, I guess, in order not having to clone for every calculation.
                      On 18/01/2007 at 13:47, xxxxxxxx wrote:
                      yes, i need to make a copy of material... initialising then call the sample.
                      Thanks for now
                      Renato T.
                        On 21/01/2007 at 06:38, xxxxxxxx wrote:
                        Mikael,
                        how i can put the parent shader in a new material with all shader tree?
                        Renato
