    Sampling Shader
    21 Posts 0 Posters 13.0k Views
      On 06/01/2007 at 05:46, xxxxxxxx wrote:
      Hello Samir,
      I don't use BaseChannel::Sample but PluginShader::Sample.
      Will be good to have secure informations from maxon. I hope that tomorrow someone will reply to my open question.
      If i pass the VD to che CD.. nothing change. The PluginShader (SLA) use always the cd.p for both 3D or 2D coordinate.
      Happy new year to you 🙂
      Renato
        On 06/01/2007 at 14:40, xxxxxxxx wrote:
        But you SHALL use BaseChannel::Sample INSTEAD OF Pluginshader::Sample, because PluginShader::Sample is the sampled point in cd->p! And BaseChannel::Sample is the only alternative I see. 🙂
        PluginShader::Sample will always give you the result of cd->p, passing vd won´t help, because it´s for ChannelData calculations, not for 3D shader calculations as the docs clearly state.
          On 06/01/2007 at 16:17, xxxxxxxx wrote:
          Interesting, but how i can get BaseChannel from my custom material?
          Renato
            On 07/01/2007 at 06:45, xxxxxxxx wrote:
            If it´s your own material you could use your own code for sampling I´d assume? Would also be faster than calling an SDK function.
            However, you get the channel of a plugin material with BaseMaterial::GetChannel(NULL);
              On 07/01/2007 at 06:52, xxxxxxxx wrote:
              Hello Katachi,
              ok, but i've some channel inside, Diffuse, Specular, Lighting, Mirror, Glass etc. 🙂
              How i can get the correct basechannel if i point it with null?
              Can i cast it from plugin shader.. maybe.
              Renato
                On 07/01/2007 at 09:49, xxxxxxxx wrote:
                Hello Katachi,
                i done some try.. and BaseMaterial::GetChannel is return always NULL with GetChannel(NULL) or GetChannel(IDofMyShaderLINK).
                Any Help?
                Renato
                  On 07/01/2007 at 12:29, xxxxxxxx wrote:
                  It seems that it only works with normal materials. (I misunderstood the description). Does it work for "normal" 3D materials, like the SLA shaders?
                  For your own materials you need to do your own sampling most probably (although I think there must be a way to sample...but the support is terrible here at the moment)
                    On 07/01/2007 at 13:53, xxxxxxxx wrote:
                    Thanks anyway Katachi,
                    i'm sure that there is a standard way to sample a c4d shader 🙂 I'm sure thant Tomorrow someone will help me to close this job 🙂
                    Renato
                      On 07/01/2007 at 19:43, xxxxxxxx wrote:
                      Let´s hope so. I also would like to know. 🙂
                        On 08/01/2007 at 09:12, xxxxxxxx wrote:
                        .. i hope that from today the maxon support will be operative... 🙂
                        Renato
                          On 11/01/2007 at 11:45, xxxxxxxx wrote:
                          Sorry for the delay. Shouldn't that be GetChannel(CHANNEL_COLOR) and not GetChannel(NULL), if your plugin shader is in the color channel for example? Then you should be able to use BaseChannel::Sample(), I think. As Katachi says, this is the only function that will allow you to sample an arbitrary point.
                            On 11/01/2007 at 11:51, xxxxxxxx wrote:
                            Hi Mikael,
                            It work also with a Custom Material?
                            Renato
                              On 11/01/2007 at 12:06, xxxxxxxx wrote:
                              No, for PluginMaterial (if that's what you mean) there are only the BaseMaterial sampling functions, afaics, for example CalcSurface().
                                On 11/01/2007 at 12:33, xxxxxxxx wrote:
                                Mikael,
                                i only need to sample shader color of each custom "channel".
                                There is a Vray Material with some shaderlink inside.
                                Some for diffuse, some for specular, mirror, glass etc.
                                I see that there are no problems to sample each shader linked in it.. but i need to know how to pass and retrieve UVW or 3D coordinate to the shaders.
                                Renato
                                  On 18/01/2007 at 00:02, xxxxxxxx wrote:
                                  Hm, it looks like that's a limitation of accessing the shaders directly, without access to their channels. But perhaps you could clone the shaders and insert them into dummy BaseChannels in order to call BaseChannel::Sample?
                                    On 18/01/2007 at 06:13, xxxxxxxx wrote:
                                    when rendering? uhm..
                                    let me think about it.
                                    Renato
                                      On 18/01/2007 at 12:41, xxxxxxxx wrote:
                                      Yeah. Preferably as a pre-step, I guess, in order not having to clone for every calculation.
                                        On 18/01/2007 at 13:47, xxxxxxxx wrote:
                                        yes, i need to make a copy of material... initialising then call the sample.
                                        Thanks for now
                                        Renato T.
                                          On 21/01/2007 at 06:38, xxxxxxxx wrote:
                                          Mikael,
                                          how i can put the parent shader in a new material with all shader tree?
                                          Renato
