    IN_EXLUDE
    14 Posts 0 Posters 1.4k Views
      On 05/12/2006 at 02:40, xxxxxxxx wrote:
      Cinema 4D Version:   9.507
      Hi
      in one of my description files which belongs to a tagplugin is an IN_EXLUDE field where i want to drop in other objects. If the user drops an object into the IN_EXLUDE field, the dropped in object should get the same position as the owner object of the tag plugin.
      Can somebody help me with that?
        On 05/12/2006 at 04:00, xxxxxxxx wrote:
        What do you mean with same position, the same postion in 3D space?
          On 05/12/2006 at 04:39, xxxxxxxx wrote:
          Yes, the coordinates (in space) should be the same.
            On 05/12/2006 at 06:26, xxxxxxxx wrote:
            If you are going for position, rotation, scale, then this should suffice:
            // Just for reference, set wherever you do this
            BaseObject* tagObj;
            BaseObject* dropObj;
            dropObj->SetMg(tagObj->GetMg());
            That'll set the dropped object's global matrix to match that of the object with the tag plugin.
            If you just want position, then you will need to do a little more work:
            SetGlobalPosition(dropObj, tagObj->GetMg().off);
            // Set Object's Global Position
            void SetGlobalPosition(BaseObject* obj, const Vector& pos)
                 Matrix     mg = obj->GetMg();
                 mg.off = pos;
                 obj->SetMg(mg);
              On 08/12/2006 at 02:18, xxxxxxxx wrote:
              Thx for this kuroyume.
              But my problem is that i don't know how to access the IN_EXCLUDE field. I need an operation like:
              dropObj = (dropped item in IN_EXCLUDE field)
              hope somebody knows what i mean ^^
                On 08/12/2006 at 09:47, xxxxxxxx wrote:
                Maybe this link will help?
                Forum Thread
                  On 11/12/2006 at 06:35, xxxxxxxx wrote:
                  Here a little example of a modified Execute function that prints the name of the objects in the in/exclude list.
                  LONG LookAtCamera::Execute(PluginTag *tag, BaseDocument *doc, BaseObject *op, BaseThread *bt, LONG priority, LONG flags)
                       BaseContainer *data = tag->GetDataInstance();
                       InExcludeData *mylist = (InExcludeData* )data->GetCustomDataType(LOOKATCAMERAEXP_LIST,CUSTOMDATATYPE_INEXCLUDE_LIST);
                       if (!mylist ) return LOAD_NOMEM;
                       LONG objcnt = mylist->GetObjectCount();
                       LONG i;
                       for(i=0; i<objcnt; i++)
                            GePrint(mylist->ObjectFromIndex(doc, i)->GetName());
                       return EXECUTION_RESULT_OK;
                  hope this helps
                    On 12/12/2006 at 00:26, xxxxxxxx wrote:
                    Thanks for this kuroyume and Matthias. Think this will work
                      On 12/12/2006 at 06:28, xxxxxxxx wrote:
                      OK the thing with the IN_EXCLUDE field works now. But i got a little problem with the following source:
                      InExcludeData *mylist = (InExcludeData* )data->GetCustomDataType(ID_DROP_YP,CUSTOMDATATYPE_INEXCLUDE_LIST);
                      for(LONG i=0; i<objcnt; i++)
                      Vector posnew = (100,100,100);
                      BaseContainer *drpndata = mylist->ObjectFromIndex(doc, i)->GetDataInstance();
                      drpndata->SetVector(ID_BASEOBJECT_POSITION,newpos);
                      I want to change the position vector of the dropped in data to posnew and i thought this should work, but it doesn't. Any ideas???
                      Or is there a way to change position like this:
                      BaseObject *drpndata = mylist->ObjectFromIndex(doc, i); ***
                      drpndata->SetPos(posnew);
                      *** I know this doesn't work, but is there a way to convert the IN_EXCLUDE mylist to a BaseObject to acccess the SetPos function???
                        On 12/12/2006 at 09:23, xxxxxxxx wrote:
                        You have to cast the result of ObjectFromIndex, for instance like this:
                        BaseObject *drpndata = (BaseObject* )mylist->ObjectFromIndex(doc, i);
                          On 12/12/2006 at 11:24, xxxxxxxx wrote:
                          This works really great. Thanks a lot Matthias
                            On 15/12/2006 at 00:17, xxxxxxxx wrote:
                            Another question, concerning layouting the IN_EXCLUDE field. Is there a way to specify the size of the IN_EXCLUDE field, cause my field is to small to add e.g. an cylinder object so you have to scroll in the field.
                              On 18/12/2006 at 07:10, xxxxxxxx wrote:
                              You have to set SCALE_V in the descriptio for both the GROUP and the description element, little example:
                              GROUP ID_TAGPROPERTIES
                                   SCALE_V;
                                   IN_EXCLUDE LOOKATCAMERAEXP_LIST { NUM_FLAGS 0; SCALE_V; ACCEPT { Obase; } }
                                On 19/12/2006 at 01:52, xxxxxxxx wrote:
                                OK thanks for that Matthias. But i got still more questions 🙂
                                Is there a way to limit the number of objects, that can be dropped in the IN_EXCLUDE field?
