    IN_EXLUDE
    14 Posts 0 Posters 1.8k Views
      On 05/12/2006 at 04:39, xxxxxxxx wrote:
      Yes, the coordinates (in space) should be the same.
        On 05/12/2006 at 06:26, xxxxxxxx wrote:
        If you are going for position, rotation, scale, then this should suffice:
        // Just for reference, set wherever you do this
        BaseObject* tagObj;
        BaseObject* dropObj;
        dropObj->SetMg(tagObj->GetMg());
        That'll set the dropped object's global matrix to match that of the object with the tag plugin.
        If you just want position, then you will need to do a little more work:
        SetGlobalPosition(dropObj, tagObj->GetMg().off);
        // Set Object's Global Position
        void SetGlobalPosition(BaseObject* obj, const Vector& pos)
             Matrix     mg = obj->GetMg();
             mg.off = pos;
             obj->SetMg(mg);
          On 08/12/2006 at 02:18, xxxxxxxx wrote:
          Thx for this kuroyume.
          But my problem is that i don't know how to access the IN_EXCLUDE field. I need an operation like:
          dropObj = (dropped item in IN_EXCLUDE field)
          hope somebody knows what i mean ^^
            On 08/12/2006 at 09:47, xxxxxxxx wrote:
            Maybe this link will help?
            Forum Thread
              On 11/12/2006 at 06:35, xxxxxxxx wrote:
              Here a little example of a modified Execute function that prints the name of the objects in the in/exclude list.
              LONG LookAtCamera::Execute(PluginTag *tag, BaseDocument *doc, BaseObject *op, BaseThread *bt, LONG priority, LONG flags)
                   BaseContainer *data = tag->GetDataInstance();
                   InExcludeData *mylist = (InExcludeData* )data->GetCustomDataType(LOOKATCAMERAEXP_LIST,CUSTOMDATATYPE_INEXCLUDE_LIST);
                   if (!mylist ) return LOAD_NOMEM;
                   LONG objcnt = mylist->GetObjectCount();
                   LONG i;
                   for(i=0; i<objcnt; i++)
                        GePrint(mylist->ObjectFromIndex(doc, i)->GetName());
                   return EXECUTION_RESULT_OK;
              hope this helps
                On 12/12/2006 at 00:26, xxxxxxxx wrote:
                Thanks for this kuroyume and Matthias. Think this will work
                  On 12/12/2006 at 06:28, xxxxxxxx wrote:
                  OK the thing with the IN_EXCLUDE field works now. But i got a little problem with the following source:
                  InExcludeData *mylist = (InExcludeData* )data->GetCustomDataType(ID_DROP_YP,CUSTOMDATATYPE_INEXCLUDE_LIST);
                  for(LONG i=0; i<objcnt; i++)
                  Vector posnew = (100,100,100);
                  BaseContainer *drpndata = mylist->ObjectFromIndex(doc, i)->GetDataInstance();
                  drpndata->SetVector(ID_BASEOBJECT_POSITION,newpos);
                  I want to change the position vector of the dropped in data to posnew and i thought this should work, but it doesn't. Any ideas???
                  Or is there a way to change position like this:
                  BaseObject *drpndata = mylist->ObjectFromIndex(doc, i); ***
                  drpndata->SetPos(posnew);
                  *** I know this doesn't work, but is there a way to convert the IN_EXCLUDE mylist to a BaseObject to acccess the SetPos function???
                    On 12/12/2006 at 09:23, xxxxxxxx wrote:
                    You have to cast the result of ObjectFromIndex, for instance like this:
                    BaseObject *drpndata = (BaseObject* )mylist->ObjectFromIndex(doc, i);
                      On 12/12/2006 at 11:24, xxxxxxxx wrote:
                      This works really great. Thanks a lot Matthias
                        On 15/12/2006 at 00:17, xxxxxxxx wrote:
                        Another question, concerning layouting the IN_EXCLUDE field. Is there a way to specify the size of the IN_EXCLUDE field, cause my field is to small to add e.g. an cylinder object so you have to scroll in the field.
                          On 18/12/2006 at 07:10, xxxxxxxx wrote:
                          You have to set SCALE_V in the descriptio for both the GROUP and the description element, little example:
                          GROUP ID_TAGPROPERTIES
                               SCALE_V;
                               IN_EXCLUDE LOOKATCAMERAEXP_LIST { NUM_FLAGS 0; SCALE_V; ACCEPT { Obase; } }
                            On 19/12/2006 at 01:52, xxxxxxxx wrote:
                            OK thanks for that Matthias. But i got still more questions 🙂
                            Is there a way to limit the number of objects, that can be dropped in the IN_EXCLUDE field?
