    Break Render
    11 Posts 0 Posters 752 Views
      On 11/10/2006 at 21:10, xxxxxxxx wrote:
      Cinema 4D Version:   9.0
      Hi ...
      Now I render my document using the statement below ...
      RenderDocument(doc, bc,MyProgressHook,pd, bmOutput,RENDERFLAG_EXTERNAL,NULL);
      It's working like "Render To PictureViewer"
      It's working ... but if the user want to break the render using Ctrl+Break ... it's not responding ...
      I read the threads about breaking render ...
      I try to use TestBreak ... but it's not working ...
      Please anybody can tell me in detail ...? 😉
      Thanks in advance ...
      Zaw Min Tun
        On 11/10/2006 at 23:27, xxxxxxxx wrote:
        i think you have to give it a Thread in stead of NULL.
        The thread is waiting for the testbreak and should then stop the rendering
          On 16/10/2006 at 20:41, xxxxxxxx wrote:
          But I don't know how I can make it ...
          Can you show me some code sample?
          But I'll try it again ...
          Anyway ... I really thank you ...
          Zaw Min Tun
            On 16/10/2006 at 21:00, xxxxxxxx wrote:
            Take a look at the section of code where RenderDocument() is called in simplematerial.cpp and particlevolume.cpp in the plugins:cinema4dsdk folder. There you see how they get the thread.
              On 16/10/2006 at 21:25, xxxxxxxx wrote:
              Then I take a look at them ...
              I pray they can really help me ... 😉
              I've already spent nearly 5 days on this ...
              Zaw Min Tun
              ありがとう ... 本当に ...
                On 16/10/2006 at 21:56, xxxxxxxx wrote:
                My plugin is a dialog plugin ...
                When the user presses a button ... The user will see the Picture Viewer rendering ...
                When redering is done the user will get a bitmap file ...
                But while rendering ... the user cannot have a break on that render ... bcos I render like this ...
                Some old threads told me to use TestBreak() ...
                For that I create a class called myThread ...
                class myThread:public Thread
                     myThread();
                     virtual void Main(void);
                myThread::myThread()
                void myThread::Main(void)
                Then when I call RenderDocument() ...
                myThread *thdRender=new myThread;
                RenderDocument(doc, bc,MyProgressHook,pd, bmOutput,RENDERFLAG_EXTERNAL,thdRender->Get());
                If I did like above ... the code that I wrote in MyProgressHook was not running ...
                And if I insert the line thdRender->TestBreak() ... it's not still working ...
                But I'd go on ... 😉
                Zaw Min Tun ...
                  On 16/10/2006 at 22:37, xxxxxxxx wrote:
                  If you want to use your own thread to test for breaks, make sure that it is running!
                  You're going to need to call thdRender->Start() before calling RenderDocument() and End() afterwards. You will also need to implement myThread::TestDBreak() unless you want a deadlock situation.
                  Try something like this and see if it works:
                       myThread();
                       virtual Bool TestDBreak();
                  // This tests for the Esc key to break the thread
                  Bool myThread::TestDBreak()
                       BaseContainer     keyinput;
                       return (GetInputEvent(BFM_INPUT_KEYBOARD, keyinput) && (keyinput.GetLong(BFM_INPUT_CHANNEL) == KEY_ESC));
                  if (!thdRender->Start(TRUE)) // Error starting thread
                  thdRender->End();
                    On 17/10/2006 at 20:12, xxxxxxxx wrote:
                    Really thank you again ...
                    Now I try to check if ESC is pressed ( in ProgressHook ) ... and it's OK ... The plugin knows when ESC is pressed ... But I don't know how to stop the rendering ...
                    I forgot to tell that I'm still using NULL as the last parameter instead of thdRender->Get() ... bcos' if I didn't use NULL ... the code I'm writing in ProgressHook is not working ...
                    In ProgressHook I call the ShowBitmap with the current bitmap ... So it's changing all the time while rendering ...
                    So I'm a bit lost ...
                    But Robert ... you answers helped a lot ...
                    And I hope you will go on ... 😉
                    Zaw Min Tun
                      On 18/10/2006 at 02:13, xxxxxxxx wrote:
                      Hmmm, the way the documentation reads, RenderDocument() should be using the passed Thread as a sort of 'overlord' to test for a user break. This should stop the render automatically - theoretically and assuming these points.
                      One question though: Are you using a clone of the BaseDocument!!? As the docs state: Must be a clone of the real document! This might have an impact.
                        On 19/10/2006 at 00:10, xxxxxxxx wrote:
                        Yeah ...
                        When I use the clone doc ... the way it's working really changed ... I can use ESC to stop rendering ...
                        But after stopping the render ... C4D also stop responding ... When the ESC is pressed ... I ended the thread ...
                        What more do I need to do?
                        But I think I can move a new step ... 😉
                        Thank you a lot ...
                        Zaw Min Tun
                          On 19/10/2006 at 01:12, xxxxxxxx wrote:
                          Hello ... Robert ...
                          I came here to let you know that now it's working ... and to say thank you ...
                          Thank you ... a lot ...
                          May god bless each and every one ...
                          Zaw Min Tun
