    Break Render
    11 Posts 0 Posters 1.1k Views
      On 11/10/2006 at 23:27, xxxxxxxx wrote:
      i think you have to give it a Thread in stead of NULL.
      The thread is waiting for the testbreak and should then stop the rendering
        On 16/10/2006 at 20:41, xxxxxxxx wrote:
        But I don't know how I can make it ...
        Can you show me some code sample?
        But I'll try it again ...
        Anyway ... I really thank you ...
        Zaw Min Tun
          On 16/10/2006 at 21:00, xxxxxxxx wrote:
          Take a look at the section of code where RenderDocument() is called in simplematerial.cpp and particlevolume.cpp in the plugins:cinema4dsdk folder. There you see how they get the thread.
            On 16/10/2006 at 21:25, xxxxxxxx wrote:
            Then I take a look at them ...
            I pray they can really help me ... 😉
            I've already spent nearly 5 days on this ...
            Zaw Min Tun
            ありがとう ... 本当に ...
              On 16/10/2006 at 21:56, xxxxxxxx wrote:
              My plugin is a dialog plugin ...
              When the user presses a button ... The user will see the Picture Viewer rendering ...
              When redering is done the user will get a bitmap file ...
              But while rendering ... the user cannot have a break on that render ... bcos I render like this ...
              RenderDocument(doc, bc,MyProgressHook,pd, bmOutput,RENDERFLAG_EXTERNAL,NULL);
              Some old threads told me to use TestBreak() ...
              For that I create a class called myThread ...
              class myThread:public Thread
                   myThread();
                   virtual void Main(void);
              myThread::myThread()
              void myThread::Main(void)
              Then when I call RenderDocument() ...
              myThread *thdRender=new myThread;
              RenderDocument(doc, bc,MyProgressHook,pd, bmOutput,RENDERFLAG_EXTERNAL,thdRender->Get());
              If I did like above ... the code that I wrote in MyProgressHook was not running ...
              And if I insert the line thdRender->TestBreak() ... it's not still working ...
              But I'd go on ... 😉
              Zaw Min Tun ...
                On 16/10/2006 at 22:37, xxxxxxxx wrote:
                If you want to use your own thread to test for breaks, make sure that it is running!
                You're going to need to call thdRender->Start() before calling RenderDocument() and End() afterwards. You will also need to implement myThread::TestDBreak() unless you want a deadlock situation.
                Try something like this and see if it works:
                     myThread();
                     virtual Bool TestDBreak();
                // This tests for the Esc key to break the thread
                Bool myThread::TestDBreak()
                     BaseContainer     keyinput;
                     return (GetInputEvent(BFM_INPUT_KEYBOARD, keyinput) && (keyinput.GetLong(BFM_INPUT_CHANNEL) == KEY_ESC));
                if (!thdRender->Start(TRUE)) // Error starting thread
                thdRender->End();
                  On 17/10/2006 at 20:12, xxxxxxxx wrote:
                  Really thank you again ...
                  Now I try to check if ESC is pressed ( in ProgressHook ) ... and it's OK ... The plugin knows when ESC is pressed ... But I don't know how to stop the rendering ...
                  I forgot to tell that I'm still using NULL as the last parameter instead of thdRender->Get() ... bcos' if I didn't use NULL ... the code I'm writing in ProgressHook is not working ...
                  In ProgressHook I call the ShowBitmap with the current bitmap ... So it's changing all the time while rendering ...
                  So I'm a bit lost ...
                  But Robert ... you answers helped a lot ...
                  And I hope you will go on ... 😉
                  Zaw Min Tun
                    On 18/10/2006 at 02:13, xxxxxxxx wrote:
                    Hmmm, the way the documentation reads, RenderDocument() should be using the passed Thread as a sort of 'overlord' to test for a user break. This should stop the render automatically - theoretically and assuming these points.
                    One question though: Are you using a clone of the BaseDocument!!? As the docs state: Must be a clone of the real document! This might have an impact.
                      On 19/10/2006 at 00:10, xxxxxxxx wrote:
                      Yeah ...
                      When I use the clone doc ... the way it's working really changed ... I can use ESC to stop rendering ...
                      But after stopping the render ... C4D also stop responding ... When the ESC is pressed ... I ended the thread ...
                      What more do I need to do?
                      But I think I can move a new step ... 😉
                      Thank you a lot ...
                      Zaw Min Tun
                        On 19/10/2006 at 01:12, xxxxxxxx wrote:
                        Hello ... Robert ...
                        I came here to let you know that now it's working ... and to say thank you ...
                        Thank you ... a lot ...
                        May god bless each and every one ...
                        Zaw Min Tun
